Author Topic: A little help with fstab (SOLVED)  (Read 8598 times)
Emegra
  • Guest
« on: February 07, 2014, 07:20:59 pm »
Hi guys
Over the past few weeks I've been switching over from Freenas to Openmediavault on my NAS and it's finally done and stable at last, I have 6 shares all visible in Gigolo, I would like to mount the shares in /mnt which requires editing  /etc/fstab file something I'm not competent enough to do myself.
any help would be much appreciated
Many thanks
« Last Edit: February 08, 2014, 08:07:00 am by Emegra »
Re: A little help with fstab
« Reply #1 on: February 07, 2014, 07:31:25 pm »
Okeydokey .. what's the output from:
sudo fdisk -l
sudo blkid
mount
and the current contents of
gedit /etc/fstab
Emegra
  • Guest
« Reply #2 on: February 07, 2014, 07:34:57 pm »
graeme@Linux1 ~ $ sudo fdisk -l
[sudo] password for graeme:
Disk /dev/sda: 360.1 GB, 360080695296 bytes
255 heads, 63 sectors/track, 43777 cylinders, total 703282608 sectors
Disk identifier: 0x00000001
/dev/sda1   *        2048   358106348   179052150+   7  HPFS/NTFS/exFAT
/dev/sda2       358107134   703281151   172587009    5  Extended
/dev/sda5       358107136   699107327   170500096   83  Linux
/dev/sda6       699109376   703281151     2085888   82  Linux swap / Solaris
graeme@Linux1 ~ $ sudo blkid
/dev/sda1: LABEL="Windows 7" UUID="02CAA59322478EE4" TYPE="ntfs"
/dev/sda5: UUID="034e3cfc-8511-446b-98eb-9e88283cf12a" TYPE="ext4"
/dev/sda6: UUID="50359b49-a810-460e-befa-9616af24bcba" TYPE="swap"
graeme@Linux1 ~ $ mount
/dev/sda5 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
gvfsd-fuse on /run/user/graeme/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=graeme)
graeme@Linux1 ~ $
# / was on /dev/sda5 during installation
UUID=034e3cfc-8511-446b-98eb-9e88283cf12a /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda6 during installation
UUID=50359b49-a810-460e-befa-9616af24bcba none            swap    sw              0       0
« Reply #3 on: February 07, 2014, 07:57:19 pm »
Am I missing something .. I can only see one HDD there.
Emegra
  • Guest
« Reply #4 on: February 07, 2014, 08:29:22 pm »
There is only one HDD, did you want that information from the PC or the NAS ?
« Reply #5 on: February 07, 2014, 09:56:55 pm »
Oh, hang on .. you're trying to mount remote shares ?
has the NAS got a static IP ?
Can you mount the shares through gigolo .. THEN post the output from:
mount
Emegra
  • Guest
« Reply #6 on: February 07, 2014, 10:01:42 pm »
Yes
Yes 192.168.2.50
Yes
graeme@Linux1 ~ $
« Last Edit: February 07, 2014, 10:07:14 pm by Emegra »
« Reply #7 on: February 07, 2014, 10:07:33 pm »
OK, that didn't give me what I wanted  :o .. were the shares mounted through gigolo when you ran "mount" to list the mounts ?
Do you know the path to the shares .. such as
//192.168.2.50/share/video
//192.168.2.50/share/music
etc ?
If not, navigate to the share in file manager .. then what does it say in the file manager address bar ?
and do the shares require login credentials ?
« Last Edit: February 07, 2014, 10:16:14 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
« Reply #8 on: February 07, 2014, 10:17:55 pm »
Doyou know the path to the shares .. such as
They are all samba shares, on 192.168.2.50, the share names are
family-tree
graeme
pat
multimedia
movies
backups
utilities
Emegra
  • Guest
« Reply #9 on: February 07, 2014, 10:21:32 pm »
No they are all set for any user no password
« Reply #10 on: February 07, 2014, 10:25:13 pm »
just to be 100% sure .. can you open file manager, and in the address bar enter:
smb://192.168.2.50/family-tree
and hit enter
smb://192.168.2.50/graeme
smb://192.168.2.50/pat
smb://192.168.2.50/multimedia
smb://192.168.2.50/movies
smb://192.168.2.50/backups
smb://192.168.2.50/utilities
were all the shares contents visible as expected ?
Emegra
  • Guest
« Reply #11 on: February 07, 2014, 10:29:10 pm »
Yes
« Reply #12 on: February 07, 2014, 10:34:51 pm »
OK, first let's create the mount points:
sudo mkdir -p /mnt/NAS
cd /mnt/NAS
sudo mkdir family-tree graeme pat multimedia movies backups utilities
close the terminal and confirm those directories exist in /mnt/NAS
or just post the output from:
ls -a /mnt
« Last Edit: February 07, 2014, 10:37:13 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
« Reply #13 on: February 07, 2014, 10:37:20 pm »
ok thats worked fine all the share folders are located at /mnt/NAS
« Reply #14 on: February 07, 2014, 10:41:26 pm »
Backup fstab .. just in case:
sudo cp -v /etc/fstab /etc/fstab.backup
then we'll mount the sharesss through ftsab one at a time.
