Author Topic: A little help with fstab (SOLVED)  (Read 8990 times)
Re: A little help with fstab
« Reply #30 on: February 07, 2014, 11:21:45 pm »
is this Peppermint 4 ?
Emegra
  • Guest
« Reply #31 on: February 07, 2014, 11:22:19 pm »
Yes
« Reply #32 on: February 07, 2014, 11:23:41 pm »
So what's the output from
mount
Emegra
  • Guest
« Reply #33 on: February 07, 2014, 11:24:39 pm »
[email protected] ~ $ mount
/dev/sda5 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
gvfsd-fuse on /run/user/graeme/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=graeme)
gvfsd-fuse on /home/graeme/.gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev)
« Reply #34 on: February 07, 2014, 11:28:04 pm »
run:
sudo mount -a
then post the output from:
mount
is this PC connected wirelessly ?
Emegra
  • Guest
« Reply #35 on: February 07, 2014, 11:30:48 pm »
[email protected] ~ $ sudo mount -a
[sudo] password for graeme:
//192.168.2.50/family-tree on /mnt/NAS/family-tree type cifs (rw)
//192.168.2.50/graeme on /mnt/NAS/graeme type cifs (rw)
//192.168.2.50/pat on /mnt/NAS/pat type cifs (rw)
//192.168.2.50/multimedia on /mnt/NAS/multimedia type cifs (rw)
//192.168.2.50/movies on /mnt/NAS/movies type cifs (rw)
//192.168.2.50/backups on /mnt/NAS/backups type cifs (rw)
//192.168.2.50/utilities on /mnt/NAS/utilities type cifs (rw)
Yes but the NAS is connected directly to the router via ethernet
« Reply #36 on: February 07, 2014, 11:39:45 pm »
OK something tells me the shares are being brought up earlier than the network .. which is odd as cifs should wait :/
I know in PM3 you had to use smbfs and add a switch to tell it to wait.
Erm .. you may have to gimme till tomorrow to search for a solution as that switch doesn't work with cifs
You online tomorrow ?
try shutting down .. then restarting the PC .. see if that works ?
is this the respin or the original PM4 ?
« Last Edit: February 07, 2014, 11:41:23 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
« Reply #37 on: February 07, 2014, 11:42:55 pm »
Yeah I'll be on in the afternoon, my grandaughter stays with us from 5pm and I try to spend the evening with her on a saturday
« Reply #38 on: February 07, 2014, 11:44:34 pm »
is this the respin ?
what's the output from:
dpkg -l | grep smb
dpkg -l | grep cifs
Emegra
  • Guest
« Reply #39 on: February 07, 2014, 11:49:43 pm »
No it was installed with a pre respin disc and updated
[email protected] ~ $ dpkg -l | grep smb
ii  libsmbclient:i386                         2:3.6.9-1ubuntu1.2                       i386         shared library for communication with SMB/CIFS servers
ii  python-smbc                               1.0.13-0ubuntu4                          i386         Python bindings for Samba clients (libsmbclient)
ii  smbclient                                 2:3.6.9-1ubuntu1.2                       i386         command-line SMB/CIFS clients for Unix
[email protected] ~ $ dpkg -l | grep cifs
ii  cifs-utils                                2:5.5-1ubuntu2                           i386         Common Internet File System utilities
« Last Edit: February 07, 2014, 11:51:14 pm by Emegra »
« Reply #40 on: February 07, 2014, 11:56:23 pm »
OK, leave it with me till tomorrow..
We have 2 options here .. figure out why cifs isn't waiting for the network to come up .. or possibly run a script with a delay that runs "mount -a"
We'll figure it out :)
Odd that cifs waits on my system .. and keeps attempting to connect till it gets there.
Have you still got gigolo installed, and are the mounts set to automount in that ?
Emegra
  • Guest
« Reply #41 on: February 08, 2014, 12:05:58 am »
Yes Gigolo is still installed and all shares set to automount, would it be worth trying  un-installing Gigolo and rebooting again ?
« Reply #42 on: February 08, 2014, 12:08:16 am »
I doubt if it'll make a difference, but worth a shot .. until tomorrow, you'd just need to run:
sudo mount -a
after rebooting.
Emegra
  • Guest
« Reply #43 on: February 08, 2014, 12:11:02 am »
ok see you tomorrow then thanks again for your help
« Reply #44 on: February 08, 2014, 01:26:42 am »
Try this...
sudo gedit /etc/network/if-up.d/my-custom-mountall
when a BLANK file opens, make it read:-
#!/bin/sh
mount -a
SAVE the file, and close gedit.
Back in the terminal run:
sudo chmod +x /etc/network/if-up.d/my-custom-mountall
reboot to test.
If that doesn't work .. just delete the /etc/network/if-up.d/my-custom-mountall file.
