Website
Home
Forum
Help
Search
Calendar
Media
Blog
Login
Register
Support
Printers and Scanners
Printer Problem(Solved)
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: Printer Problem(Solved) (Read 11295 times)
Degsy
Sr. Member
Gender:
I am getting there, but it is very slow going!
on:
February 21, 2014, 04:10:53 pm »
Hi Guys,
Having a problem again with my HP Photosmart 5520 All-in One, cant get it to print on either my Laptop or Desktop.
Laptop is running Peppermint 4 64 bit, and the printer has worked in the past. Desktop running Ubuntu 12.04, again been able to print and scan etc in the past now get the same error on both machines as follows:
HPLIP Device Status. Photosmart_5520_series Printer (192.168.1.2)
Device Communication Error (5012)
The printer is connected wirelessly, and just for info, prints no problem from my iPad2.
Your help and input, as always would be much appreciated.
Many thanks in advance,
Degsy.
Last Edit: February 21, 2014, 04:49:49 pm by Degsy
Logged
Degsy
Sr. Member
Gender:
Re: Printer Problem(Solved)
Reply #1 on:
February 21, 2014, 04:48:53 pm »
Hi Everyone,
Very pleased to say that I Have managed to sort this problem out now, it was as simple as setting up the Printer again in Device Manager, though why this went awry in the first place I just don't know, anyway the outcome is satisfactory and I am now able to print again from the Laptop. I assume the problem will be solved in the same way on the Desktop, just haven't had time to try iot yet.
Thanks again, Degsy
Logged
Reply #1 on:
Mark Greaves (PCNetSpec)
Hero Member
Gender:
"-rw-rw-rw-" .. The Number Of The Beast
Reply #2 on:
February 21, 2014, 04:53:47 pm »
Is this a networked printer .. if so the IP address it gets from the router may have changed .. give it a static IP address
Logged
WARNING
: You are logged into reality as 'root'
Degsy
Sr. Member
Gender:
Reply #3 on:
February 21, 2014, 06:00:31 pm »
It is network printer, how do I give it a static address please Mark?
Logged
Hero Member
Gender:
Reply #4 on:
February 21, 2014, 06:16:43 pm »
OK to do it properly, you'll need to know -
a) your routers IP address
b) the start and finishing addresses of the routers DHCP pool
c) how to change the printers IP address from the printers own control panel
Do you know these things ?
Logged
WARNING
Reply #4 on:
Degsy
Sr. Member
Gender:
Reply #5 on:
February 21, 2014, 06:23:32 pm »
Hi Mark, to answer your questions in a word, No, I don't know these things.
Logged
Hero Member
Gender:
Reply #6 on:
February 21, 2014, 06:32:36 pm »
OK, right-click the networkmanager icon in the system tray, and select "Connection Information" .. what does it say next to
IP Address: ??.??.??.??
Default Route: ??.??.??.??
Last Edit: February 21, 2014, 06:35:53 pm by Mark Greaves (PCNetSpec)
Logged
WARNING
Degsy
Sr. Member
Gender:
Reply #7 on:
February 21, 2014, 06:41:01 pm »
IP Address: 192.168.1.2, and
Default Route: 192.168.1.1.
Hope this is alright,
Degsy
Logged
Hero Member
Gender:
Reply #8 on:
February 21, 2014, 07:25:41 pm »
OK, your routers IP is likely to be
192.168.1.1
What is the make/model of your router ? .. was it supplied by your ISP ? .. and have you changed it's default login password at any stage ?
Logged
WARNING
Reply #8 on:
Degsy
Sr. Member
Gender:
Reply #9 on:
February 21, 2014, 07:51:06 pm »
The router is Huawei Echolife HG520s and was supplied by talktalk, my ISP. I have not changed the login password, only the Security Password.
Degsy
Logged
Hero Member
Gender:
Reply #10 on:
February 21, 2014, 08:12:20 pm »
So if you enter this into your web browsers address bar:
192.168.21.1
then hit enter .. are you prompted for the router login/password .. and are you able to log into the router ?
Logged
WARNING
Degsy
Sr. Member
Gender:
Reply #11 on:
February 21, 2014, 08:18:40 pm »
I assume that you meant 192.168.1.1 and yes can log in to the router,
Degsy
Logged
Hero Member
Gender:
Reply #12 on:
February 21, 2014, 08:50:20 pm »
Opps .. bear with me, half way into a bottle of 12 year old Appleton Estate Rum
Yeah that's what I meant.
OK. log into the router and see if you can find anything that references "DHCP Pool" or DHCP range" which gives you an IP range similar to
192.168.1.2 ---> 192.168.1.254
And let me know what those starting and finishing addresses are.
Logged
WARNING
Degsy
Sr. Member
Gender:
Reply #13 on:
February 21, 2014, 09:08:39 pm »
Logged in and hopefully this is the info you asked for:
Client IP Pool Starting Address: 192.168.1.2
Size of Client Pool: 253
Does that look like the right thing?
Degsy
Logged
Hero Member
Gender:
Reply #14 on:
February 21, 2014, 09:17:47 pm »
Yeah that looks right
.. if a bit weird (normally they'd give the starting snd ending IP rather than the number of IP's.
But who cares .. is it possible to change the
Size of client pool"
to say
200
(which I figure will represent 192.168.1.2 --> 192.168.1.201 [inclusive])
Last Edit: February 21, 2014, 09:20:36 pm by Mark Greaves (PCNetSpec)
Logged
WARNING
Print
Pages: [
1
2
Go Up
« previous
next »
Support
