Author Topic: Printer Problem(Solved)  (Read 10689 times)
Offline Degsy
  • Sr. Member
Re: Printer Problem(Solved)
« Reply #15 on: February 21, 2014, 09:25:41 pm »
Yes, the box containing the figure does allow me to delete and reinsert a different number.
« Reply #16 on: February 21, 2014, 09:30:14 pm »
Keep looking in the router settings then .. somewhere in there there must be a setting that allows you to change the DHCP pool size/range
« Reply #17 on: February 21, 2014, 09:34:57 pm »
So on this screen you cannot change
Size of Client IP Pool: 253
to
Size of Client IP Pool: 200
and click submit ?
Offline Degsy
  • Sr. Member
« Reply #18 on: February 21, 2014, 09:44:31 pm »
Yes, I can do that, sorry, thought that was what I had said originally, it was certainly what I meant.
Degsy
Should I go ahead and change to 200 and submit?
« Reply #19 on: February 21, 2014, 10:01:27 pm »
YES :)
Offline Degsy
  • Sr. Member
« Reply #20 on: February 21, 2014, 10:03:39 pm »
OK, that is done and submitted.
Degsy
« Reply #21 on: February 21, 2014, 10:52:03 pm »
Great .. Whilst I try to dig up a manual .. has the printer got a little screen on it ?
possibly for (my) future reference:
http://h10032.www1.hp.com/ctg/Manual/c03353113.pdf
« Last Edit: February 21, 2014, 10:56:44 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
« Reply #22 on: February 21, 2014, 11:55:32 pm »
Yes, the printer has a control panel.
« Reply #23 on: February 22, 2014, 12:16:25 pm »
OK, tbe static IP you wsant to assign to you pinter is:-
192.168.1.210
there are usually 2 methods to do this
1) navigate the printers control panel .. dunno how much I can help with this as I can't see the options
2) set it through the printers built in websever .. see the video on this page:
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/printers-and-all-in-ones/print-a-diagnostic-page/1972074076001/Assigning%20Your%20HP%20Printer%20a%20Static%20IP%20Address/video/
Offline Degsy
  • Sr. Member
« Reply #24 on: February 22, 2014, 12:51:22 pm »
Thanks for the info, just one question, did you really mean 192.168.1,210 or should that have been 192.168.1.201 as we changed the pool to 200, doesn't that mean a max of 192.168.1,201?
« Reply #25 on: February 22, 2014, 12:57:33 pm »
192.168.1.210
the pool currently runs for 200 addreesses starting at 192.168.1.2 .. so it will be 192.168.1.2  -->  192.168.1.202 (inclusive)
So you can used any IP's from 192.168.1.203  --> 192.168.1.254 (inclusive) for static IP's ;)
I just chose 210 arbitrarily.
Offline Degsy
  • Sr. Member
« Reply #26 on: February 22, 2014, 02:51:19 pm »
Thanks for the explanation, just trying to understand what  I am doing and also why. Will try this out later, get back to you if I have further queries. Once again, thanks for your help.
Degsy :D
« Reply #27 on: February 22, 2014, 02:58:26 pm »
You're welcome :)
Offline Degsy
  • Sr. Member
« Reply #28 on: February 24, 2014, 12:35:09 pm »
Just for the sake of completeness, have manually assigned the suggested IP address to the HP printer and set up the desktop and laptop to recognise the new set up. Delighted to say it is all systems go now.
Once again many thanks for your time and helpful advice, much appreciated.
Degsy
« Reply #29 on: February 24, 2014, 02:16:09 pm »
No problem :)
