Author Topic: Do I update?  (Read 3703 times)
Offline Degsy
  • Sr. Member
Do I update?
« on: March 09, 2014, 01:53:57 pm »
Hi everyone,
Hopefully this is a very quick question to answer.
I have an HP 5520 all in one which is wirelessly connected to my laptop, desktop and (iPad) (ignore the last word Mark), I have a static IP as per your instructions previously, all is working well, just got a notification that there is an update from HP, should I continue with this or just ignore the update? Don't want to mess up when everything is working fine.
I am hoping the answer is a straight "Yes " or "No".
TIA, Degsy
Re: Do I update?
« Reply #1 on: March 09, 2014, 02:00:12 pm »
I take it you're getting this message either in WinLOL or on the iPiad-too-much ?
Or is it a Linux update that's being offered through your update-manager ?
« Last Edit: March 09, 2014, 02:03:26 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
Re: Do I update?
« Reply #2 on: March 09, 2014, 03:28:08 pm »
Sorry, should have been a bit more specific, the update is offered to HPLIP 3.xxxxxx whatever the number was, I think by HP on my Ubuntu 12.04 desktop. Just wondered if I did the update if it would affect the smooth operation of the Printer/Scanner which is working well since with your help I set a static IP.
Degsy
Re: Do I update?
« Reply #3 on: March 09, 2014, 03:45:43 pm »
So is it being offered by the update manager ?
if so, say yes and accept the update.
Offline Degsy
  • Sr. Member
Re: Do I update?
« Reply #4 on: March 09, 2014, 03:51:17 pm »
Thanks, Mark, will carry out the update shortly.
Degsy.
Re: Do I update?
« Reply #5 on: March 09, 2014, 03:58:58 pm »
I doubt if it'll remove the printer .. but if it does, it's dead easy to re-add an HP printer :)
