Author Topic: leoxsys LEO NANO 150N usb wireless adapter on linux mint 16 not working  (Read 15154 times)
Offline nvs
Cannot connect to internet leoxsys LEO NANO 150N wireless usb adapter even after
going through all the steps of topic 11154 on my linux mint 16 (petra) desktop.
The vendor ID 148f is MediaTek and 7601 is productID. Is there a linux driver for 7601
that can be compiled and integrated in the system?
The relevant outputs are listed below.
[email protected] ~ $ inxi -n
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:20:ed:ff:ff:ff
           Card-2: Ralink
           IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
[email protected] ~ $ uname -a
Linux mint 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013 i686 i686 i686 GNU/Linux
[email protected] ~ $ lsusb
Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp.
[email protected] ~ $ sudo lshw -C network
  *-network
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       physical id: 0
       bus info: [email protected]:02:00.0
       logical name: eth0
       version: 02
       serial: 00:20:ed:ff:ff:ff
       capacity: 1Gbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.2.2 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:42 ioport:d000(size=256) memory:e1110000-e1110fff memory:e1100000-e110ffff memory:e1120000-e112ffff
Hi nvs, and welcome to the forum :)
Whilst I've never tried compiling these against the 3.11 kernel, they certainly compile against 3.8
In best Blue Peter fashion .. here's one I prepared earlier:
http://peppermintos.net/viewtopic.php?p=41805#p41805
I'll repost my instructions here though:-
Ralink wireless driver 148f:7601 (for wireless adapters with the Ralink MT7601U chipset)
Make sure you have an active internet connection (connect to your router by an ethernet cable if you need to), then open a terminal and run these commands in sequence:
mkdir ~/MT7601-Driver
cd ~/MT7601-Driver
wget https://dl.dropboxusercontent.com/u/11876059/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913.tar.gz
tar xvf DPO_MT7601U_LinuxSTA_3.0.0.4_20130913.tar.gz
cd ~/MT7601-Driver/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913
make
sudo make install
sudo modprobe mt7601Usta
Did wireless spring to life ?
If so, check it survives a reboot.
« Last Edit: March 18, 2014, 12:37:50 pm by Mark Greaves (PCNetSpec) »
Offline nvs
Mark,
You are great. It worked and survived reboot.
Thank you very much.
nvs
You're most welcome :)
Offline nvs
I tried to set up a wireless network connection from menu->preferences->network connections and entered connection name, SSID of my Belkin router,
mode infrastructure, router mac address for BSSID, and USB mac address for device mac address. In the router I added usb mac address in wireless access
control list and in wlan section of lan interface. With that set up I tried to connect to internet after disconnecting the wired connection. I could not connect to internet.
What am I doing wrong?
 inxi -n
           Card-2: Ralink driver: rt2870
           IF: ra0 state: down mac: 12:34:56:00:09:43
After executing ifup -a,
 inxi -n
ra0 state remains down.
OK, it seems to have gone back to using the rt2870 driver
What's the output from:
Offline nvs
  *-network
       physical id: 0
       logical name: eth0
       version: 02
       capacity: 1Gbit/s
       width: 64 bits
  *-network DISABLED
       physical id: 1
       logical name: ra0
       serial: 12:34:56:00:09:43
       configuration: broadcast=yes driver=RALINK WLAN multicast=yes wireless=Ralink STA
Bus 001 Device 002: ID 148f:7601 Ralink Technology, Corp.
Bus 004 Device 002: ID 045e:00cb Microsoft Corp. Basic Optical Mouse v2.0
[email protected] ~ $ sudo lsmod | grep 7601
mt7601Usta            744038  0
post the full output from
lsmod
rfkill list
« Last Edit: March 20, 2014, 12:37:13 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
@nvs
If your copy and pasting these commands into the terminal, the second command should be
rfkill list
« Last Edit: March 20, 2014, 12:09:12 pm by Emegra »
fixed above .. thanks Emegra :)
Offline nvs
Re: leoxsys LEO NANO 150N usb wireless adapter on linux mint 16 not working
« Reply #10 on: March 20, 2014, 01:30:57 pm »
[email protected] ~ $ lsmod
Module                  Size  Used by
cfg80211              401436  0
bnep                   18893  2
rfcomm                 53664  0
bluetooth             323534  10 bnep,rfcomm
binfmt_misc            13140  1
coretemp               13195  0
gpio_ich               13229  0
ppdev                  17391  0
mt7601Usta            744038  0
snd_hda_codec_realtek    45473  1
snd_hda_intel          42658  3
snd_hda_codec         164003  2 snd_hda_codec_realtek,snd_hda_intel
microcode              18830  0
snd_hwdep              13272  1 snd_hda_codec
snd_pcm                89488  2 snd_hda_codec,snd_hda_intel
dm_multipath           22402  0
scsi_dh                14458  1 dm_multipath
snd_page_alloc         14230  2 snd_pcm,snd_hda_intel
snd_seq_midi           13132  0
snd_seq_midi_event     14475  1 snd_seq_midi
snd_rawmidi            25094  1 snd_seq_midi
lpc_ich                16864  0
snd_seq                55383  2 snd_seq_midi_event,snd_seq_midi
serio_raw              13189  0
snd_seq_device         14137  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              24447  2 snd_pcm,snd_seq
parport_pc             31981  1
snd                    60790  16 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
mac_hid                13037  0
soundcore              12600  1 snd
lp                     13299  0
parport                40795  3 lp,ppdev,parport_pc
hid_generic            12492  0
usbhid                 47361  0
hid                    87192  2 hid_generic,usbhid
dm_mirror              21715  0
dm_region_hash         15984  1 dm_mirror
dm_log                 18072  2 dm_region_hash,dm_mirror
i915                  589697  3
video                  18777  1 i915
i2c_algo_bit           13197  1 i915
drm_kms_helper         46867  1 i915
drm                   242354  4 i915,drm_kms_helper
r8169                  61434  0
mii                    13654  1 r8169
[email protected] ~ $ rfkill list
« Reply #11 on: March 20, 2014, 02:24:37 pm »
Undo whatever you did .. ie. delete all wireless connections in networkmanager.
Then reboot.
Are you sure you haven't disabled wireless with a hardware switch ?
I'm baffled by your not having any output from "rfkill list" .. and why the card has become "disabled"
Does removing the driver, then reinserting it make a difference ?:
sudo modprobe -r mt7601Usta
Offline nvs
« Reply #12 on: March 20, 2014, 06:13:02 pm »
After I deleted WiFi1 only Ethernet connection 1 is left as shown below.
[email protected] /etc/NetworkManager/system-connections $ ls
[email protected] ~ $ sudo modprobe -r mt7601Usta
[sudo] password for ravi:
[email protected] ~ $ sudo modprobe mt7601Usta
After that I created WiFi1 as indicated here
[email protected] ~ $ sudo cat /etc/NetworkManager/system-connections/WiFi1
[connection]
id=WiFi1
uuid=70f89d0d-4558-4133-b5a4-a8e8fa12105e
type=802-11-wireless
[802-11-wireless]
ssid=SKS
mode=adhoc
bssid=EC:1A:59:90:40:6C
mac-address=12:34:56:00:09:43
security=802-11-wireless-security
[802-11-wireless-security]
key-mgmt=wpa-psk
proto=rsn;
pairwise=ccmp;
group=ccmp;
psk=wh0ami?!
[ipv4]
method=auto
[ipv6]
method=auto
When I disconnected the wired Ethernet connection and I tried to switch on wireless connection
the connection name HOME appeared. Trying to turn that on repeatedly kept asking for password
authentication but never established connection. I deleted that connection. Rebooted the system.
Created a new connection with mode Ad-hoc.
[connection]
id=WiFi1
[802-11-wireless]
ssid=SKS
mode=adhoc
key-mgmt=wpa-psk
proto=rsn;
pairwise=ccmp;
group=ccmp;
psk=********
[ipv4]
method=auto
[ipv6]
method=auto
Now clicking on the network icon at bottom right, disonnecting wired connection and clicking on
wireless shows unavailable and automatically creates a connection “Auto HOME” and goes into
authentication loop endlessly generating additional “Auto HOME” connections.
I am frustrated and ready to give up.  Anyway, it is 11:30 and I feel sleepy. Will resume tomorrow.
« Reply #13 on: March 20, 2014, 06:24:18 pm »
Why are you manually creating the connection ? .. is your wireless hidden ?
and why are you setting it as an adhoc network
Offline nvs
« Reply #14 on: March 22, 2014, 09:36:45 am »
Yes, I have set router to not broadcast SSID and I have also entered LEO NANO
ethernet address in wireless access control list and in the WLAN section of the LAN
interface.
After reading your comment I changed the Belkin router configuration to default
configuration and that created a wireless connection “Auto belkin.06C” listed below.
earth system-connections # cat Auto\ belkin.06C
[connection]
id=Auto belkin.06C
uuid=2bd95e60-74ca-4850-9bc7-37af1dc76fe1
[802-11-wireless]
ssid=belkin.06C
mode=infrastructure
key-mgmt=wpa-psk
auth-alg=open
psk=********
[ipv4]
method=auto
[ipv6]
method=auto
This connection is established but I cannot connect to the internet.
