Author Topic: leoxsys LEO NANO 150N usb wireless adapter on linux mint 16 not working  (Read 15247 times)
Re: leoxsys LEO NANO 150N usb wireless adapter on linux mint 16 not working
« Reply #15 on: March 22, 2014, 12:00:31 pm »
Are you able to ping both your routers IP and the IP of Google.com ?
What's the output from:
ping -c 5 173.194.34.131
ping -c 5 <ip.address.of.router>
Offline nvs
« Reply #16 on: March 22, 2014, 01:32:45 pm »
No, I cannot even ping 192.168.2.1 the IP address of my Belkin router with the connection wifi1, a hidden network, listed below.
I probably need to do something in ipv4 setting but don't know what. It has only one entry method "Automatic DHCP"
earth system-connections # cat wifi1
[connection]
id=wifi1
uuid=d2033f03-1280-4b44-83b4-0428249ca6ac
type=802-11-wireless
[802-11-wireless]
ssid=SKS
mode=infrastructure
bssid=EC:1A:59:90:40:6C
mac-address=12:34:56:00:09:43
security=802-11-wireless-security
[802-11-wireless-security]
key-mgmt=wpa-psk
psk=*********
[ipv4]
method=auto
[ipv6]
method=auto
« Reply #17 on: March 22, 2014, 06:09:13 pm »
For now disable mac address filtering and unhide the network SSID in your router .. you can enable them again later, but for now it's complicating things, I want to see if the network adapter/drivers are actually working properly or not.
In network manager delete any wireless connections.
click the networkmanager icon in your system tray .. is your network listed ?
if so, click on it to connect .. enter your Mint password and wireless key .. did it connect ?
is the internet available ?
« Last Edit: March 22, 2014, 06:15:19 pm by Mark Greaves (PCNetSpec) »
Offline nvs
« Reply #18 on: March 25, 2014, 06:48:06 pm »
Sorry for the delay. I was visiting my sister in Mumbai. Now I am back to U.S. I hope my registration will be forever.
I will ask my niece-in-law who is unfamiliar with linux but well-versed in windows to make changes to configuration
that you will recommend.
After I set the router to default configuration I got connected to the router but not to the internet. Here is what I got.
[email protected] ~ $ sudo cat /etc/NetworkManager/system-connections/*b*
[sudo] password for ravi:
[connection]
id=Auto belkin.06C
uuid=8ca4e7bd-088c-4c51-8aac-4add9bbe5a2e
[802-11-wireless]
ssid=belkin.06C
mode=infrastructure
key-mgmt=wpa-psk
auth-alg=open
psk=********
[ipv4]
method=auto
[ipv6]
method=auto
[email protected] ~ $ ping -c5 192.168.2.1
PING 192.168.2.1 (192.168.2.1) 56(84) bytes of data.
64 bytes from 192.168.2.1: icmp_seq=1 ttl=30 time=1.56 ms
64 bytes from 192.168.2.1: icmp_seq=2 ttl=30 time=1.37 ms
64 bytes from 192.168.2.1: icmp_seq=3 ttl=30 time=1.41 ms
64 bytes from 192.168.2.1: icmp_seq=4 ttl=30 time=1.53 ms
64 bytes from 192.168.2.1: icmp_seq=5 ttl=30 time=1.50 ms
--- 192.168.2.1 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 1.376/1.478/1.567/0.080 ms
Networking screen for belkin.06C shows
belkin.06C
Connected
Hardware Assress 12:34:56:00:09:43
Security WPA, WPA2
Strength Excellent
Link Speed 54 Mb/s
IP Address 192.168.2.2
Default Route 192.168.2.1
DNS 192.168.2.1
DNS address above is that of the router. The network connection has no routing information added.
« Reply #19 on: March 25, 2014, 08:45:44 pm »
So what happens now if you try pinging google.com by IP
ping -c 5 173.194.41.166
Offline SeZo
« Reply #20 on: March 25, 2014, 08:54:41 pm »
You could also try to trace it to see how far it gets:
sudo traceroute -I 173.194.41.166
Offline nvs
« Reply #21 on: March 26, 2014, 07:24:07 pm »
It reports that the network is unreachable. When I added mtnl name server ip address in ipv4 setting and
left DHCP automatic it gave the same result.
« Reply #22 on: March 26, 2014, 07:28:40 pm »
so you can ping the router, but not the web ?
can you access you routers web interface (wirelessly) ?
« Last Edit: March 27, 2014, 09:30:34 pm by Mark Greaves (PCNetSpec) »
Offline chemicalfan
« Reply #23 on: March 27, 2014, 09:07:45 am »
And the wired connection works perfectly? If you connect an Ethernet cable to router, you can access the internet?
Could be some kind of filter/firewall issue within the router....you'll probably need to connect the cable anyway to access those settings
Offline mandeepmails
hi there,
i went through the all steps with ubuntu14.04 and Leoxsys (posted most of the commands output so that you can guide me, where i'm missing
[email protected]:~$ iwconfig
[email protected]:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:e0:4c:64:05:d2
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::2e0:4cff:fe64:5d2/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:20 errors:0 dropped:0 overruns:0 frame:0
          TX packets:70 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2487 (2.4 KB)  TX bytes:10076 (10.0 KB)
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:157 errors:0 dropped:0 overruns:0 frame:0
          TX packets:157 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:11378 (11.3 KB)  TX bytes:11378 (11.3 KB)
[email protected]:~$ lsusb
Bus 001 Device 002: ID 148f:7601 Ralink Technology, Corp.
Bus 004 Device 002: ID 046d:c52e Logitech, Inc.
[email protected]:~$ uname -r
3.13.0-29-generic
[email protected]:~$ uname -a
Linux desktop 3.13.0-29-generic #53-Ubuntu SMP Wed Jun 4 21:02:19 UTC 2014 i686 i686 i686 GNU/Linux
[email protected]:~$ sudo lshw -C network
[sudo] password for yaj:
  *-network
       physical id: 0
       bus info: [email protected]:01:00.0
       logical name: eth0
       version: 02
       serial: 00:e0:4c:64:05:d2
       capacity: 100Mbit/s
       width: 64 bits
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.1.2 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:40 ioport:e800(size=256) memory:fdfff000-fdffffff memory:fdfe0000-fdfeffff
[email protected]:~$ sudo modprobe mt7601Usta
modprobe: FATAL: Module mt7601Usta not found.
[email protected]:~$ lsmod
Module                  Size  Used by
bnep                   18895  2
rfcomm                 53664  0
bluetooth             342263  10 bnep,rfcomm
joydev                 17101  0
hid_generic            12492  0
snd_hda_codec_realtek    51029  1
usbhid                 46997  0
snd_hda_intel          42730  3
snd_hda_codec         164067  2 snd_hda_codec_realtek,snd_hda_intel
hid                    87604  2 hid_generic,usbhid
snd_hwdep              13272  1 snd_hda_codec
snd_pcm                85501  2 snd_hda_codec,snd_hda_intel
snd_page_alloc         14230  2 snd_pcm,snd_hda_intel
gpio_ich               13229  0
snd_seq_midi           13132  0
snd_seq_midi_event     14475  1 snd_seq_midi
i915                  705574  3
snd_rawmidi            25135  1 snd_seq_midi
snd_seq                55383  2 snd_seq_midi_event,snd_seq_midi
video                  18903  1 i915
snd_seq_device         14137  3 snd_seq,snd_rawmidi,snd_seq_midi
drm_kms_helper         46907  1 i915
snd_timer              28584  2 snd_pcm,snd_seq
drm                   243792  4 i915,drm_kms_helper
snd                    60871  16 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
lpc_ich                16864  0
i2c_algo_bit           13197  1 i915
soundcore              12600  1 snd
serio_raw              13230  0
mac_hid                13037  0
parport_pc             31981  1
ppdev                  17391  0
lp                     13299  0
parport                40836  3 lp,ppdev,parport_pc
psmouse                91033  0
r8169                  61562  0
mii                    13654  1 r8169
[email protected]:~$ sudo modprobe -r mt7601Usta
Did you compile the driver without error ?
Sorry to keep you waiting..
Yes, i followed and all steps as mentioned (ditto) on top of that i clearly observed the results in terminal alongwith each and every command i executed..there were no errors.
One close observation though, on top right menu (Network) i don't have wireless even mentioned..
In case i haven't answered your concern still, i can again execute the all commands again and this times attach the whole terminal results/logs in text file.
Thanks so much for helping me out.
This:-
kinda tells me the driver can't have compiled/installed correctly.
Can you try again .. but keep an eye out for errors .. particularly when you run the:
make
sudo make install
commands.
Offline hinumol
« Reply #28 on: September 17, 2020, 09:36:55 am »
Dear all,
I am new user in kali linux, I am using kali from virtualbox windows 10. I tried many time connect my Leo-hg150N usb adapter in kali linux, I can't Possible connect. I commant sudo iwconfig that is showing only wlan0 only. I have internet connect but that only ethernet modem did't show my usb adapter name. and tried airodump-ng wlan0mon. but not get bssid. can you help me...?
thanks & regards
Hinu
« Last Edit: September 17, 2020, 10:50:38 am by Keith »
Online Keith
« Reply #29 on: September 17, 2020, 11:14:17 am »
Hello Hinu  - and welcome to the Forum.
Kali Linux looks very dubious to me.  I found on https://www.linuxmint.com/download_lmde.php "  Kali Linux is made for the express purpose of penetration testing. It is built on the Debian codebase and is created by a security firm known as Offensive Security."
And on https://www.quora.com/What-are-differences-between-Linux-Mint-and-Kali-Linux?share=1  "1 advantage of kali over other distros is it can mount ntfs partitions even when not safely turned off from windows or its hibernated. and you can install other general purpose software as per needed.
For general purpose use, Mint would be the better option and there is much more support for it.   What are you using Kali for?
For a start, try:
iwlist scan | grep ESSID
and post the output here.  Is your router or modem listed?
keith
« Last Edit: September 17, 2020, 11:23:58 am by Keith »
