Author Topic: Can't log into Peppermint  (Read 1376 times)
Emegra
  • Guest
« on: April 24, 2014, 11:57:49 am »
Hi guys
Ok I've managed to do something embarrassingly stupid, when logging in this morning I decided to see what the Cairo Dock (Gnome) session was all about, and it didn't load up properly there was no menu and other things on the panel didn't show up, so as I had no menu or log out button  I managed to open the terminal and reboot, when it rebooted it bypassed the Login screen and went straight into Cairo Dock (Gnome) , so I managed to switch user using a Cairo Dock applet and got into Guest account and from there was able to log out and get to the login screen, the problem is that when I select my main account (Graeme) I can't select Peppermint from the drop down menu I only get the Cairo Dock (Gnome) option I get both choices with either Guest or other but not with my main account, so I'm effectively locked out
« Last Edit: April 24, 2014, 12:08:12 pm by Emegra »
Re: Can't log into Peppermint
« Reply #1 on: April 24, 2014, 06:35:18 pm »
What is the output from:
cat /usr/share/xsessions/peppermint.desktop
Emegra
  • Guest
« Reply #2 on: April 24, 2014, 06:41:34 pm »
HI Mark
Panic's over, the thought occurred to me driving home tonight that I have Timeshift installed and set to do weekly snapshots so I was able to open Timeshift via the terminal, restored back to the last snapshot and everything's back
That's something I wont be trying again
Sorry about that  :-[
« Reply #3 on: April 24, 2014, 06:43:44 pm »
No problem .. glad you got it sorted :)
