Author Topic: Update manager stops  (Read 2876 times)
Offline spidey-westland
« on: May 08, 2014, 07:27:48 pm »
Howdy,
If fire up "update manager" and install all, I see a message: cannot : dpkg -- assert-multi-arch.
How do repair this?
regards
Spidey-Westland
Re: Update manager stops
« Reply #1 on: May 09, 2014, 02:55:58 am »
Run:
then post any output from:
sudo dpkg --configure -a
