Author Topic: pepper flash  (Read 1976 times)
Offline banko
  • Full Member
pepper flash
« on: May 20, 2014, 10:23:35 am »
since installing LM17 cinnamon, it shows pepper flash is installed, but when using chromium sites that require flash tell me to install flash,
I uninstalled and re-installed (with synaptic) but the message still comes up, and I cannot watch any videos.
sorry to be a pain ,but any help will be appreciated.
Re: pepper flash
« Reply #1 on: May 20, 2014, 11:17:32 am »
run:
sudo updatedb
then post the output from:
locate libpepflashplayer.so
Offline banko
  • Full Member
Re: pepper flash
« Reply #2 on: May 20, 2014, 11:27:13 am »
results
keith@keith-Lenovo-G550 ~ $ sudo updatedb
[sudo] password for keith:
keith@keith-Lenovo-G550 ~ $ locate libpepflashplayer.so
/usr/lib/pepperflashplugin-nonfree/libpepflashplayer.so
Re: pepper flash
« Reply #3 on: May 20, 2014, 11:33:07 am »
does flash work in Chromium if you run it from the command line with this command:
chromium-browser --ppapi-flash-path=/usr/lib/pepperflashplugin-nonfree/libpepflashplayer.so --ppapi-flash-version=13.0.0.206
Offline banko
  • Full Member
Re: pepper flash
« Reply #4 on: May 20, 2014, 12:11:45 pm »
no luck with that Mark
you tube, bbc, and birdforum all ask for plug in to be installed
Re: pepper flash
« Reply #5 on: May 20, 2014, 12:32:25 pm »
did it specifically mention the "Flash" plugin was the one that's missing ?
if so .....
Easiest solution would be to ditch Chromium and install Chrome.
But if you MUST have Chromium, let me know and we'll try downloading pepperflash from my dropbox
« Last Edit: May 20, 2014, 12:36:53 pm by Mark Greaves (PCNetSpec) »
Offline banko
  • Full Member
Re: pepper flash
« Reply #6 on: May 20, 2014, 12:46:25 pm »
HA HA I hope I don't sound totally stupid ;)
but I cannot find chrome in either synaptic or the software centre.
so how do i install,
I'll be perfectly happy with chrome BTW.
Re: pepper flash
« Reply #7 on: May 20, 2014, 12:51:56 pm »
http://www.google.com/intl/en_uk/chrome/browser/
be sure to download the .deb version for either 32bit or 64bit .. depending on which version of Mint you're using.
Once downloaded, double-click the .deb file to install.
Offline banko
  • Full Member
Re: pepper flash
« Reply #8 on: May 20, 2014, 01:11:42 pm »
downloaded and working perfect.
so I'm very very happy now thanks :D :D :D :D :D :D
many thanks for your time.
Re: pepper flash
« Reply #9 on: May 20, 2014, 01:12:16 pm »
no problem :)
Offline chemicalfan
Re: pepper flash
« Reply #10 on: May 20, 2014, 02:24:25 pm »
Out of interest, what is it in Chrome that isn't in Chromium, that makes the websites happy?
Re: pepper flash
« Reply #11 on: May 20, 2014, 02:26:43 pm »
I'm gonna take a guess here that the pepperflashplugin-nonfree installation is corrupt
Chrome will be using its own version, not the system wide one.
Pure GUESS though.
