Author Topic: [SOLVED] Want (or rather NEED to) install Window$ help diag problem... Need help  (Read 8731 times)
Offline pooky2483
I am having speed problems with my broadband and VM will not help any further as I am not running Window$, so I am having to see if I can install my copy of XP in place of where I have installed one of my Ubuntu or variants.
All my HD's are formatted to EXT4 so I know I'm going to have to format a partition to NTFS to install XP.
Is it as easy as installing Ubuntu to a partition or is there more involved?
« Last Edit: July 13, 2014, 01:47:32 pm by pooky2483 »
Kubuntu 18.04LTS 64bit|KDE 5.47.0|Plasma 5.12.19|QT 5.9.5|Linux 5.4.0.54-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Offline SeZo
No, it is not as easy as that. Remeber according to Windows there IS no other operating system out there.
I would suggest (if you have a spare HDD) to remove ALL disks that contain other operating systems and leave in place the one you can dedicate to XP.
There should be no partitions on this drive prior to install. In other words, you dedicate the HDD and machine to XP.
Offline pooky2483
I'm sure I can manage that. I have Kubuntu 14.04 on sda and I've given up using it as it seems rather unstable as it keeps crashing.
Do I just install as normal on sda (I know in window$ its called something else). Is there anything I need to do about the grub after installing XP?
Offline pooky2483
I've done a search (which was a rare find) to install Window$ SECOND and have Ubuntu as a first install instead of the usual Window$.
http://apcmag.com/how_to_dual_boot_linux_and_windows_xp_linux_installed_first.htm#null
Offline pooky2483
I have got my XP Install disc and decided to wipe sda and put XP on it, BUT...
When booting and selecting to install XP on sda it will not install it either when the HD is formatted to NTFS or wiped and unformatted. am I doing something wrong???
When trying to install XP, I am informed that XP is unable to be installed due to the HD not being NTFS and given the option to go back and format it but when I do that, it still comes up with 'unable to install' because of the HD's format.
I am using GParted in Ubuntu 14.04 to format sda.
Offline SeZo
If you are installing XP on to the first drive (/dev/sda) then from gparted delete all partitions so it is all free space, then go Device->Create Partition Table->MSDOS and stop there.
Then use the XP install disk to create the partitions during install.
Offline pooky2483
I've tried that, I wipe the HD so it shows 'unallocated' then highlight the drive again then select 'Device' then select 'Create Partition Table'.
Then reboot to install XP but it still comes up with 'Unable to install'
Offline chemicalfan
If you delete the partition table and don't create a new one (i.e. leave as unallocated), does XP install then?
Offline pooky2483
Not that I can recall.
I have tried many different variations but will have a last attempt at setting partition table and file system at unallocated and then set to msdos and unallocated.
I don't want to hear that the HD is dead  ;) as it was booting perfectly fine with Kubuntu 14.04.
Offline pooky2483
Just had a look at what I can set the partition table to and there is no setting to set it to nothing, only;
msdos
aix
amiga
bsd
dvh
gpt
mac
pc98
sun
loop
Offline chemicalfan
You don't *HAVE* to set it, just delete the partition table and leave it at that
Offline pooky2483
Tried it and it is still failing to install, saying it's not a valid XP partition or something, even after the installation disk partitions it.
Offline SeZo
You could try to follow the instructions from here and see if you get anywhere.
Could the drive still have a corrupt partition table with an invalid GPT signature.
http://askubuntu.com/questions/287352/ubuntu-13-04-installation-does-not-detect-windows-7
Offline pooky2483
Tried that Mark but it's still failing to install as its coming up with 'not a valid XP partition'
