Author Topic: [SOLVED] Want (or rather NEED to) install Window$ help diag problem... Need help  (Read 8743 times)
Offline SeZo
Are sure you do not mix Megabits and Megabytes?
Those two speeds are roughly equivalent if Kubuntu 24.69 is expressed in MB/s and the XP 155.72 Mb/s
You can use Google's simple MB/Mb converter
Offline chemicalfan
That's weird, speedtest is just a website, it shouldn't matter how it's accessed at the client end. It should behave the same regardless of whether it's XP, Linux, Mac, Android, or iPad. Do you get consistant results in a given OS if you run it repeatedly?
Offline pooky2483
Kubuntu 18.04LTS 64bit|KDE 5.47.0|Plasma 5.12.19|QT 5.9.5|Linux 5.4.0.54-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Are these with an ethernet cable, or wireless ?
Offline pooky2483
Cable as we’ve only got the one pooter ATM
Offline pooky2483
More speedtest results; The latest at the top are good D/L speeds XP, bad ones Kubuntu.
This doesn't make ANY sense...
If you're in an XP VM inside Kubuntu, Kubuntu (as far as I understand it) still has control of the ethernet adapter.
Are there "real world" differences in the time taken to download a file ?
What's the output from:
ifconfig
Offline pooky2483
[email protected]:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:24:8c:bc:10:83
          inet addr:192.168.0.2  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::224:8cff:febc:1083/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2426557 errors:0 dropped:0 overruns:0 frame:0
          TX packets:768852 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3237771862 (3.2 GB)  TX bytes:260764196 (260.7 MB)
          Interrupt:42 Base address:0x8000
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:39531 errors:0 dropped:0 overruns:0 frame:0
          TX packets:39531 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:4356271 (4.3 MB)  TX bytes:4356271 (4.3 MB)
Offline pooky2483
Dont quite get what you mean by 'Are there real world differences'
I mean, does it repeatedly take longer to download a "real" file in Kubuntu than windows .. or are you solely relying on the numbers given to you by the speedtest site ?
Have yo tried disabling IPv6 ?
« Last Edit: July 09, 2014, 02:16:45 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
IPv6 is disabled.
I just downloaded XPSP3 in Kubuntu and the fastest DL speed I saw was 4Mbps and in XP it went to 8Mbps
You're still relying on figures .. did it actually take longer ?
Just in case it IS something in your Kubuntu setup .. have you tried from say a Ubuntu or Peppermint LiveCD/LiveUSB ?
« Last Edit: July 09, 2014, 02:41:50 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
I'll try that in a bit Mark, the boss (Mrs pooky) has got me doing a bit of gardening putting plants in the front garden lol
I take it from your other topic that Kubuntu is actually quicker than XP in "real world" tests :)
http://linuxforums.org.uk/index.php?topic=11920.msg95837#msg95837
Offline pooky2483
... A LOT quicker judging by the times...
