Author Topic: Docky bookmarks not working in mint17 64bit mate (Resolved)  (Read 4513 times)
Offline Tramlink
  • Is the mist clearing
It seems that the file and desktop manager in mint 17 has been changed to Caja and is not compatible with Docky bookmarks helper.
"Changes to the bookmarks on the dock are synced to Nautilus' bookmarks".
It is a pain not to have my bookmarks on the dock is it possible to change the file/desktop manager back to Nautilus?
« Last Edit: July 16, 2014, 03:33:31 pm by Tramlink »
Re: Docky bookmarks not working in mint17 64bit mate
« Reply #1 on: July 15, 2014, 03:01:44 pm »
If you create a bookmark in Caja, which of these 2 files does it show up in
gedit ~/.gtk-bookmarks
gedit ~/.config/gtk-3.0/bookmarks
Offline Tramlink
« Reply #2 on: July 15, 2014, 04:40:50 pm »
Book marks in Caja show up in option one.
« Reply #3 on: July 15, 2014, 04:48:40 pm »
I'm pretty sure nautilus now saves it's bookmarks in ~/.config/gtk-3.0/bookmarks .. so try making that a symlink to ~/.gtk-bookmarks
Try this:
mv -v ~/.config/gtk-3.0/bookmarks ~/.config/gtk-3.0/bookmarks-original
ln -sv ~/.gtk-bookmarks ~/.config/gtk-3.0/bookmarks
You may then either need to restart docky, or log off/on.
To undo:
rm -v ~/.config/gtk-3.0/bookmarks
mv -v ~/.config/gtk-3.0/bookmarks-original ~/.config/gtk-3.0/bookmarks
then if necessary, log off/on.
« Last Edit: July 15, 2014, 04:59:54 pm by Mark Greaves (PCNetSpec) »
Offline Tramlink
« Reply #4 on: July 15, 2014, 09:00:27 pm »
There is no change to the operation of the bookmarks........  the folders are shown on the dock but when clicked nothing happens. i.e. the folder dose not open.
« Reply #5 on: July 15, 2014, 09:11:21 pm »
OK, I'm going to guess that docky attempts to run nautilus when the bookmark is clicked.
We can create a script called nautilus that launches caya instead.
But first I want to check that there isn't one there already.
What happens if you run:
nautilus
and what's the output from:
ls -al /usr/bin/nautilus
Offline Tramlink
« Reply #6 on: July 15, 2014, 10:13:59 pm »
userone@Office2 ~ $ nautilus
The program 'nautilus' is currently not installed. You can install it by typing:
sudo apt-get install nautilus
userone@Office2 ~ $ ls -al /usr/bin/nautilus
ls: cannot access /usr/bin/nautilus: No such file or directory
userone@Office2 ~ $
« Reply #7 on: July 15, 2014, 11:29:53 pm »
OK, let's try this:
sudo gedit /usr/bin/nautilus
and make it read:-
    #!/bin/bash
    exec caja $3
    exit 0
SAVE the file and exit gedit .. now run:
sudo chmod +x /usr/bin/nautilus
now what happens if you run:
nautilus
if caja starts .. now try the docky bookmarks.
Offline Tramlink
« Reply #8 on: July 16, 2014, 09:40:16 am »
Hi, caja starts OK but the book marks still do not open.
« Reply #9 on: July 16, 2014, 01:26:13 pm »
Close Docky
Open Caja
Right-click any FOLDER
Select "Open with > Other Application..."
Select Caja
Make sure "Remember this application" (or whatever dialog Caja uses to remember file types) is checked
Click Open
Restart Docky
Offline Tramlink
Re: Docky bookmarks not working in mint17 64bit mate (Resolved)
« Reply #10 on: July 16, 2014, 03:34:23 pm »
Yes that fixed the problem.........................Thanks.
« Reply #11 on: July 16, 2014, 03:48:45 pm »
You're welcome ...
You can probably undo the other things we did if you want, but it won't hurt to leave them either.
Offline Tramlink
« Reply #12 on: July 16, 2014, 04:49:32 pm »
OK thanks again only the VPN issue to sort out now.....
