Author Topic: Where do I get drivers for an Epson SX 130 (SOLVED)  (Read 6431 times)
Offline donwatson
  • Getting older
« on: July 20, 2014, 05:16:13 pm »
I have installed Peppermint 5 on this machine but I only have a Windross disc that came with the Epson SX130 Printer/Scanner.
Where can I download the Linux drivers.
Don W
« Last Edit: July 20, 2014, 11:33:56 pm by donwatson »
Novatech build
External 2TiB HD
Re: Where do I get drivers for an Epson SX 130
« Reply #1 on: July 20, 2014, 05:49:11 pm »
Output from:
uname -a
please.
I'm getting a real sense on deja vous here ;)
Offline donwatson
  • Getting older
« Reply #2 on: July 20, 2014, 06:39:15 pm »
don@ldwatson ~ $ uname -a
Linux ldwatson 3.13.0-32-generic #57-Ubuntu SMP Tue Jul 15 03:51:12 UTC 2014 i686 i686 i686 GNU/Linux
don@ldwatson ~ $
Is this what you want ?
My grandson was using this machine in Win 7 and when I shut down there was 32 updates.
I would like to remove all trace of windross and just run Peppermint. Shall I start a new thread in Peppermint Forum.
Don W
Novatech build
External 2TiB HD
« Reply #3 on: July 20, 2014, 06:55:49 pm »
probably best
As for the SX130 drivers .. I'd expect these to still work:
http://linuxforums.org.uk/index.php?topic=11487.msg92257#msg92257
hence my "deja vous" comment ;)
Offline donwatson
  • Getting older
« Reply #4 on: July 20, 2014, 07:22:55 pm »
I have downloaded the first line but I get a 404 error not found
Don W
Novatech build
External 2TiB HD
« Reply #5 on: July 20, 2014, 07:32:07 pm »
OK, gimme a sec
« Reply #6 on: July 20, 2014, 07:39:14 pm »
« Last Edit: July 20, 2014, 07:41:54 pm by Mark Greaves (PCNetSpec) »
Offline donwatson
  • Getting older
« Reply #7 on: July 20, 2014, 09:28:29 pm »
I have installed the printer and printed an impressive test page.
Thank you again.
Don W
PS I will use the thread I started in Peppermint if I have any problems.
Novatech build
External 2TiB HD
« Reply #8 on: July 20, 2014, 10:52:11 pm »
Great .. and you're welcome.
Please remember to mark the topic (SOLVED) if you consider it so .. you can do this by editing the FIRST posting in this topic and changing:-
Subject: Where do I get drivers for an Epson SX 130 (SOLVED)
Thanks in advance :)
Offline donwatson
  • Getting older
« Reply #9 on: July 26, 2014, 04:15:29 pm »
OK, try these links .. and install them in this order too:-
epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
iscan-data_1.29.0-2_all.deb
iscan_2.29.3-1~usb0.1.ltdl7_i386.deb
Where can I get the 64 bit drivers for this Epson SX130 ?
When I use these drivers the first says , after installing, "Broken Dependencies"
Novatech build
External 2TiB HD
Offline donwatson
  • Getting older
Re: Where do I get drivers for an Epson SX 130 (SOLVED)
« Reply #11 on: July 26, 2014, 05:43:07 pm »
Thanks Mark,
I have carried out the above instructions and printed the test sheet, all is well.
Thanks again.
Are you running a firewall ?
« Last Edit: July 26, 2014, 06:07:05 pm by Mark Greaves (PCNetSpec) »
Novatech build
External 2TiB HD
Offline donwatson
  • Getting older
« Reply #12 on: July 27, 2014, 03:20:32 pm »
Thanks Mark,
Thanks again.
I don't think so ?
Novatech build
External 2TiB HD
« Reply #13 on: July 27, 2014, 03:51:01 pm »
Sorry, I must have added that accidentally .. it was meant to go elsewhere  :-[
Offline donwatson
  • Getting older
« Reply #14 on: July 27, 2014, 05:09:40 pm »
 :-X
Novatech build
External 2TiB HD
