Author Topic: Problem with Ralink RT3290 after automatic update of Ubuntu 12.04  (Read 11484 times)
Offline adit_alit
Before, I already had this problem for 2 times and already solved with tutorial on this web (http://rricketts.com/installing-ralink-rt3290-wireless-drivers-in-ubuntu-12-04/).
But on July 18th 2014, I did an update with which I forgot the detail (it was not from the list, it was like installing a new update for hardware), and then the wifi cannot work until now. I already tried several ways on other website but still it did not work at all.
Is there any upgrade that Linux made within above date? Which could make all the old tutorial didn't work?
Pls help...........
Re: Problem with Ralink RT3290 after automatic update of Ubuntu 12.04
« Reply #1 on: July 21, 2014, 01:30:57 pm »
Does wireless work if you boot the previous kernel ?
Offline adit_alit
« Reply #2 on: July 22, 2014, 05:17:29 am »
Still not working
« Reply #3 on: July 22, 2014, 04:52:53 pm »
OK, can you post the output from:
sudo lshw -C network
lsusb
lspci -vnn | grep -i net
iwconfig
ifconfig
rfkill list
iwlist scanning
Offline adit_alit
« Reply #4 on: August 05, 2014, 11:01:35 am »
 *-network UNCLAIMED
       product: RT3290 Wireless 802.11n 1T/1R PCIe
       vendor: Ralink corp.
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 32 bits
       configuration: latency=0
       resources: memory:92510000-9251ffff
  *-network
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 07
       serial: a0:1d:48:d2:b6:71
       capacity: 100Mbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.1.101 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:41 ioport:3000(size=256) memory:92404000-92404fff memory:92400000-92403fff memory:7eb00000-7eb0ffff
lsusb
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 002: ID 04f2:b40d Chicony Electronics Co., Ltd
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0fca:8004 Research In Motion, Ltd. Blackberry Handheld
01:00.0 Network controller [0280]: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe [1814:3290]
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 07)
iwconfig
ifconfig
eth0      Link encap:Ethernet  HWaddr a0:1d:48:d2:b6:71
          inet addr:192.168.1.101  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::a21d:48ff:fed2:b671/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:444423 errors:0 dropped:0 overruns:0 frame:0
          TX packets:284105 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:496495409 (496.4 MB)  TX bytes:35490331 (35.4 MB)
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:11718 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11718 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1260740 (1.2 MB)  TX bytes:1260740 (1.2 MB)
rfkill list
NOTHING HAPPENED
iwlist scanning
PLEASE HELP WITH TUTORIAL / STEPS
Thank you
Offline chemicalfan
« Reply #5 on: August 05, 2014, 11:21:42 am »
Can you post up the results of:
lsmod
And also:
dmesg | grep -i net
« Reply #6 on: August 05, 2014, 02:20:47 pm »
Can you also run:
sudo updatedb
and then post the output from:
uname -a
locate rt3290sta.ko
modinfo rt3290sta
You say the instructions from ricketts used to work .. where did they fail this time ?
« Last Edit: August 05, 2014, 02:29:38 pm by Mark Greaves (PCNetSpec) »
Offline adit_alit
« Reply #7 on: August 06, 2014, 07:05:53 am »
I don't know either, like I said, I already used Ricketts instruction twice and it works, but after updating something, then it couldn't work at all.
lsmod
Module                  Size  Used by
bnep                   19884  2
rfcomm                 74748  0
bluetooth             411140  10 bnep,rfcomm
parport_pc             32866  0
ppdev                  17711  0
uvcvideo               82247  0
snd_hda_codec_hdmi     46945  1
videobuf2_core         40972  1 uvcvideo
snd_hda_codec_realtek    62235  1
videodev              139761  2 uvcvideo,videobuf2_core
binfmt_misc            17508  1
videobuf2_vmalloc      13216  1 uvcvideo
videobuf2_memops       13362  1 videobuf2_vmalloc
usb_storage            66714  0
snd_hda_intel          57222  3
snd_hda_codec         199156  3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
i915                  821500  3
snd_hwdep              13613  1 snd_hda_codec
snd_pcm               107140  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_seq_midi           13324  0
snd_rawmidi            30465  1 snd_seq_midi
rtsx_pci_ms            18320  0
snd_seq_midi_event     14899  1 snd_seq_midi
drm_kms_helper         53540  1 i915
memstick               16968  1 rtsx_pci_ms
dm_multipath           27401  0
psmouse               113295  0
drm                   308868  4 i915,drm_kms_helper
snd_seq                66061  2 snd_seq_midi,snd_seq_midi_event
joydev                 17575  0
rtsx_pci_sdmmc         23667  0
scsi_dh                14873  1 dm_multipath
rtsx_pci               46133  2 rtsx_pci_ms,rtsx_pci_sdmmc
snd_timer              30038  2 snd_pcm,snd_seq
snd_seq_device         14497  3 snd_seq_midi,snd_rawmidi,snd_seq
serio_raw              13462  1
mac_hid                13253  0
snd                    69754  17 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq_midi,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
hp_wmi                 18202  0
sparse_keymap          13890  1 hp_wmi
hp_accel               26012  0
i2c_algo_bit           13564  1 i915
lis3lv02d              20280  1 hp_accel
mei_me                 18674  0
soundcore              12680  1 snd
mei                    87127  1 mei_me
video                  19914  1 i915
snd_page_alloc         18798  2 snd_hda_intel,snd_pcm
lpc_ich                21163  0
wmi                    19363  1 hp_wmi
input_polldev          13896  1 lis3lv02d
hp_wireless            12637  0
disable_mmc            13007  0
lp                     17799  0
parport                42481  3 parport_pc,ppdev,lp
dm_mirror              22356  0
dm_region_hash         21010  1 dm_mirror
dm_log                 18527  2 dm_mirror,dm_region_hash
btrfs                 867337  0
ahci                   30063  2
libahci                32669  1 ahci
r8169                  73299  0
mii                    13981  1 r8169
raid6_pq               97812  1 btrfs
xor                    21411  1 btrfs
libcrc32c              12644  1 btrfs
dmesg | grep -i net
[    0.142824] NET: Registered protocol family 16
[    3.400823] NetLabel: Initializing
[    3.400825] NetLabel:  domain hash size = 128
[    3.400826] NetLabel:  protocols = UNLABELED CIPSOv4
[    3.400841] NetLabel:  unlabeled traffic allowed by default
[    3.416395] NET: Registered protocol family 2
[    3.416791] NET: Registered protocol family 1
[    3.848789] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    3.849159] audit: initializing netlink socket (disabled)
[    4.659664] NET: Registered protocol family 10
[    4.659852] NET: Registered protocol family 17
[    4.806509] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    9.686485] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   15.703639] type=1400 audit(1407205806.535:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=973 comm="apparmor_parser"
[   15.703673] type=1400 audit(1407205806.535:6): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=979 comm="apparmor_parser"
[   15.704289] type=1400 audit(1407205806.535:8): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=973 comm="apparmor_parser"
[   15.704311] type=1400 audit(1407205806.535:10): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=979 comm="apparmor_parser"
[   19.368947] NET: Registered protocol family 31
[   19.839139] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.706167] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   22.706826] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   24.381263] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9331.659531] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9334.245021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[21072.001855] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[21085.891168] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[21087.490746] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[21968.495249] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[21984.991120] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[23164.037982] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[23347.813272] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Offline adit_alit
« Reply #8 on: August 06, 2014, 07:14:11 am »
Already run sudo updatedb
uname -a
Linux aditya-HP-Pavilion-14-Notebook-PC 3.13.0-32-generic #57~precise1-Ubuntu SMP Tue Jul 15 03:51:20 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
locate rt3290sta.ko
/home/aditya/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt3290sta.ko.cmd
/home/aditya/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt3290sta.ko
/lib/modules/3.13.0-32-generic/kernel/drivers/net/wireless/rt3290sta.ko
/lib/modules/3.5.0-52-generic/kernel/drivers/net/wireless/rt3290sta.ko
/lib/modules/3.5.0-54-generic/kernel/drivers/net/wireless/rt3290sta.ko
modinfo rt3290sta
filename:       /lib/modules/3.13.0-32-generic/kernel/drivers/net/wireless/rt3290sta.ko
version:        2.6.0.0_rev1
srcversion:     13F483178C6DF2E02D874C3
alias:          pci:v00001814d00003290sv*sd*bc*sc*i*
depends:
vermagic:       3.5.0-54-generic SMP mod_unload modversions
parm:           mac:rt28xx: wireless mac addr (charp)
Offline chemicalfan
« Reply #9 on: August 06, 2014, 09:40:17 am »
If you run the following, does wireless then work?
sudo modprobe rt3290sta
« Reply #10 on: August 06, 2014, 01:21:07 pm »
1814:3290 should now be covered by the rt2800pci kernel module, so there should be no need to install the outdated rt3290sta driver (which by the way won't compile against the 3.13 kernel .. I just tried).
Does wireless start working if you run:
sudo modprobe -r rt3290sta
sudo modprobe rt2800pci
What's the contents of
gedit /etc/modprobe.d/blacklist.conf
gedit /etc/modules
Did 12.04 really *automatically* update it's kernel from the 3.5 series to 3.13  :o
As I said the 3.13 kernels rt2800pci driver has now been patched and should work perfectly with your adapter .. but I'm putting this link here for reference "just in case"
Patched fork of the rt3290sta driver that will compile in 3.13 can be found here:
https://github.com/pkeeper/rt3290sta
that links iis only for future reference  (I don't advise you use this, rt2800pci is a better option in kernel 3.13)
« Last Edit: August 06, 2014, 02:17:24 pm by Mark Greaves (PCNetSpec) »
Offline chemicalfan
« Reply #11 on: August 06, 2014, 02:13:07 pm »
I think "sudo modprobe -r rt3290sta" will fail, as that module isn't loaded at the moment (although, it will be after my comment!).
Don't worry about it, just carry on.
Re the kernel auto-upgrade: People slate Mint for not auto-upgrading the kernel, making it opt-in! lol
Offline adit_alit
« Reply #12 on: August 07, 2014, 05:32:07 am »
gedit /etc/modules
Thank you very much Mark Greaves... :)
It's working now.
But what is actually happened with my laptop? The most important thing is, what should I do if this problem occurs again in the future?
Offline chemicalfan
« Reply #13 on: August 07, 2014, 08:53:05 am »
It shouldn't happen again, as the problem was the new kernel that was (auto)installed contained a new driver, which conflicted with the old one that was necessary with the old kernel. The "modprobe -r" command removed the old driver, leaving the new one to do its thing!
« Reply #14 on: August 07, 2014, 09:56:08 am »
If you've un-blacklisted rt2800pci
and blacklisted rt3290sta
everything should be fine from now on, even after kernel updates as rt2800pci comes with the kernel.
What happened was the rt3290sta (staging) driver would need recompiling (against the new kernel) every time you received a kernel update .. but they changed some stuff in kernels >=3.11 so that driver will no longer compile, and Ralink haven't released an updated version.
Luckily the open source rt2800pci drivers have improved their support for your adapter.
Originally rt2800pci wasn't a very good driver for your adapter and kept dropping the connection, so people blacklisted it (so it doesn't autoload) and compiled the staging driver .. but rt2800pci (since a patch was accepted into kernel 3.12) is now the driver of choice for your adapter.
« Last Edit: August 07, 2014, 10:08:53 am by Mark Greaves (PCNetSpec) »
