Author Topic: Voice recording...Cassette to PC  (Read 7547 times)
Re: Voice recording...Cassette to PC
« Reply #15 on: September 05, 2014, 02:12:20 pm »
What's the output from:
lsmod | grep snd
Jocklad 1
  • Guest
« Reply #16 on: September 05, 2014, 02:14:37 pm »
[email protected] ~ $ lsmod | grep snd
snd_usb_audio         153617  0
snd_usbmidi_lib        29215  1 snd_usb_audio
snd_hda_codec_idt      54645  1
snd_hda_intel          56451  3
snd_hda_codec         192906  2 snd_hda_codec_idt,snd_hda_intel
snd_hwdep              13602  2 snd_usb_audio,snd_hda_codec
snd_pcm               102099  3 snd_usb_audio,snd_hda_codec,snd_hda_intel
snd_page_alloc         18710  2 snd_pcm,snd_hda_intel
snd_seq_midi           13324  0
snd_seq_midi_event     14899  1 snd_seq_midi
snd_rawmidi            30144  2 snd_usbmidi_lib,snd_seq_midi
snd_seq                61560  2 snd_seq_midi_event,snd_seq_midi
snd_seq_device         14497  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              29482  2 snd_pcm,snd_seq
snd                    69322  18 snd_usb_audio,snd_hwdep,snd_timer,snd_hda_codec_idt,snd_pcm,snd_seq,snd_rawmidi,snd_usbmidi_lib,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
soundcore              12680  1 snd
« Reply #17 on: September 05, 2014, 02:39:07 pm »
When this device is plugged into Windows, how does it present itself ? .. as a sound card, or as a mass storage device ?
and what's the output from:
cat /proc/asound/cards
« Last Edit: September 05, 2014, 02:44:08 pm by Mark Greaves (PCNetSpec) »
Jocklad 1
  • Guest
« Reply #18 on: September 05, 2014, 03:14:00 pm »
 Its just showing as a "Cassettemate" program Mark.
[email protected] ~ $ cat /proc/asound/cards
 0 [Intel          ]: HDA-Intel - HDA Intel
                      HDA Intel at 0xdff3c000 irq 42
« Reply #19 on: September 05, 2014, 03:27:02 pm »
Not the program...
When you plug it into Windows .. down by the clock (system tray) there'll be a panel applet for disconnecting the USB device .. is it listed in that as a "mass storage device" or as a "sound card" or similar ?
Jocklad 1
  • Guest
« Reply #20 on: September 05, 2014, 03:35:55 pm »
 Im getting USB Composite device and USB PnP audio device.
 Jocklad
« Reply #21 on: September 05, 2014, 05:07:38 pm »
OK, I don't think there's any "easy" way to do this...
The snd_usb_audio module doesn't contain the idVendor:idProduct string for that device (0d8c:0131) so has no way of knowing what to do with it (so it appears to immediately disconnect).
I'm not saying it would be impossible .. if you could figure out a custom udev rule(s) .. but it would probably be extremely hard.
I think your best bet is to hope the ID string gets addecd at some point in the future.
« Last Edit: September 05, 2014, 05:09:34 pm by Mark Greaves (PCNetSpec) »
Jocklad 1
  • Guest
« Reply #22 on: September 05, 2014, 05:34:43 pm »
 Thanks for your time and patience Mark.
 Its hardly something that would be in daily use so not worth spending more of
 your valuable time on.
 Thanks again,
 Jocklad  :) :)
« Reply #23 on: September 05, 2014, 09:01:33 pm »
If it becomes important in the future, I suppose you could install Windows in a VM with USB passthrough ;)
Jocklad 1
  • Guest
« Reply #24 on: September 05, 2014, 10:04:25 pm »
 The whole idea of this was to preserve very precious and irreplaceable Data on a cassette that was recorded 30 years ago.
 As I said I have in a roundabout way between Windows and Linux now have this in Mp3 format with plenty of copies.
 Thanks to all who helped me with this.
  Jocklad  :) :) :) :) :)
Emegra
  • Guest
« Reply #25 on: September 05, 2014, 10:12:14 pm »
Glad you got what you wanted in the end,
I felt a bit responsible when you bought it on my suggestion and it didn't work with your Linux PC, but it will make me more careful what I suggest to people in future
Jocklad 1
  • Guest
« Reply #26 on: September 05, 2014, 10:19:47 pm »
 Not at all Graeme.
 If you had not directed me to the cassette capture machine I would have been lost.
 Direct copy from line-out....line-in was very poor audio quality.
 With yours and Marks help it is now done.
 Many thanks
Jocklad
« Reply #27 on: October 03, 2014, 10:15:39 pm »
I'm a bit late with this, but you might be interested to look at this link: http://linuxers.org/tutorial/ffmpeg-tutorial-beginners for future reference.
I haven't tried it yet but I have the same needs as you and shall give it a go as it seems particularly easy to implement.
Jocklad 1
  • Guest
« Reply #28 on: October 03, 2014, 10:22:33 pm »
 Thanks Keith will have a good look at that.... :) :)
 Jocklad
