Author Topic: Updating error..(Solved)  (Read 3392 times)
Jocklad 1
  • Guest
« on: October 05, 2014, 07:58:25 am »
 When running sudo apt-get update in Terminal getting the following error message.:
 W: GPG error: http://ppa.launchpad.net trusty Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4DF9B28CA252A784
[email protected] ~ $
Gratefull for any help.
Jocklad
« Last Edit: October 05, 2014, 01:03:26 pm by Jocklad 1 »
Re: Updating error..
« Reply #1 on: October 05, 2014, 12:48:45 pm »
run:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 4DF9B28CA252A784
then try:
sudo apt-get udate
again.
Jocklad 1
  • Guest
« Reply #2 on: October 05, 2014, 01:03:01 pm »
 No errors.
 That fixed it Mark.
 Thanks again  :) :) :)
 Jocklad
Re: Updating error..(Solved)
« Reply #3 on: October 07, 2014, 12:18:48 am »
NP :)
