Author Topic: Problem with 14.04 (Solved)  (Read 19194 times)
Offline Degsy
  • Sr. Member
Re: Problem with 14.04
« Reply #60 on: October 14, 2014, 04:13:45 pm »
Here is the output
derek@derek-System-Product-Name:~$ gedit /etc/apt/sources.list
(gedit:2471): Gtk-WARNING **: GtkScrolledWindow 0x8f0b3b8 is mapped but visible child GtkScrollbar 0x8f0d7c8 is not mapped
(gedit:2471): Gtk-WARNING **: GtkScrolledWindow 0x8f0b3b8 is mapped but visible child GtkScrollbar 0x8f0d950 is not mapped
# deb cdrom:[Ubuntu 11.04 _Natty Narwhal_ - Release i386 (20110427.1)]/ natty main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb cdrom:[Ubuntu 14.04 LTS _Trusty Tahr_ - Release i386 (20140417)]/ trusty main restricted
deb http://gb.archive.ubuntu.com/ubuntu/ trusty main restricted
deb-src http://gb.archive.ubuntu.com/ubuntu/ trusty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://gb.archive.ubuntu.com/ubuntu/ trusty-updates main restricted
deb-src http://gb.archive.ubuntu.com/ubuntu/ trusty-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://gb.archive.ubuntu.com/ubuntu/ trusty universe
deb-src http://gb.archive.ubuntu.com/ubuntu/ trusty universe
deb http://gb.archive.ubuntu.com/ubuntu/ trusty-updates universe
deb-src http://gb.archive.ubuntu.com/ubuntu/ trusty-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://gb.archive.ubuntu.com/ubuntu/ trusty multiverse
deb-src http://gb.archive.ubuntu.com/ubuntu/ trusty multiverse
deb http://gb.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
deb-src http://gb.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://gb.archive.ubuntu.com/ubuntu/ natty-backports main restricted universe multiverse
# deb-src http://gb.archive.ubuntu.com/ubuntu/ natty-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu trusty-security main restricted
deb-src http://security.ubuntu.com/ubuntu trusty-security main restricted
deb http://security.ubuntu.com/ubuntu trusty-security universe
deb-src http://security.ubuntu.com/ubuntu trusty-security universe
deb http://security.ubuntu.com/ubuntu trusty-security multiverse
deb-src http://security.ubuntu.com/ubuntu trusty-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu natty partner
# deb-src http://archive.canonical.com/ubuntu natty partner
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
deb http://extras.ubuntu.com/ubuntu trusty main
deb-src http://extras.ubuntu.com/ubuntu trusty main
This has been posted using the old kernel, so yes Internet is connected.
Thanks,
Degsy
« Reply #61 on: October 14, 2014, 06:38:16 pm »
Run:
sudo cp -v /etc/apt/sources.list /etc/apt/sources.list.original
and comment out the line:-
so it now reads:
# deb cdrom:[Ubuntu 14.04 LTS _Trusty Tahr_ - Release i386 (20140417)]/ trusty main restricted
SAVE the file and exit gedit.
Back in the terminal run:
sudo apt-get install linux-headers-generic build-essential dkms synaptic nvidia-331-updates
When finished, close the terminal and go to "Additional Drivers" and see if it will let you activate the nvidia 331 updates driver.
Offline Degsy
  • Sr. Member
« Reply #62 on: October 14, 2014, 07:31:42 pm »
Yeeeeeeeeeesssssssss!!!!!!!!!
Thank you Mark and everybody else who has been offering their help, the last advice worked, booted into straight away without problem, sending this from Ubuntu 14.04 using the latest kernel
Thanks again everybody, so sorry this has been such a long drawn out road but you have get me there.
Just wish i understood everything that I had done following your advice.
Cheers,
Degsy
Offline Degsy
  • Sr. Member
« Reply #63 on: October 14, 2014, 07:52:56 pm »
I now notice that the Software updater is offering updates, is it safe for me to run the Updater and update the system?
I feel sure it is but just want to check, dont want to b$ll$x the system after all the help I have had to get it up and running.
Degsy
« Reply #64 on: October 14, 2014, 09:57:28 pm »
Well you'll have to update some time .. so yeah, let em rip and let us know how it goes :)
If it updates without issue, can you also remember to mark this topic (SOLVED) .. TIA :)
« Last Edit: October 14, 2014, 10:05:27 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
« Reply #65 on: October 14, 2014, 11:16:14 pm »
Carried out the updates and rebooted, no problems encountered so have marked the topic solved.
Once again many thanks to all those who have helped with this.
Cheers,
Degsy
Re: Problem with 14.04 (Solved)
« Reply #66 on: October 14, 2014, 11:47:45 pm »
For my part, you're welcome :)
Offline chemicalfan
« Reply #67 on: October 15, 2014, 08:34:10 am »
Glad to see you got it sorted  ;D
Guess the nouveau driver isn't the "safe pair of hands" I've always thought it to be!
(every day is a school day!)
Offline Degsy
  • Sr. Member
« Reply #68 on: October 15, 2014, 09:34:49 am »
This is probably not a question that is easy to answer but it appears to me ( and I know little) that by inserting the # and commenting out that line the system was able to update and allow me to get the proprietary drivers, so how did that line that needed the # get there in the first place?
Regards,
Degsy
Offline chemicalfan
« Reply #69 on: October 15, 2014, 01:09:41 pm »
I'm not 100% sure, it could be a bug in the upgrade process that inserted it?
