Author Topic: Trying to install Fuse (ZX Spectrum emulator) on Mint 16 MATE  (Read 10476 times)
Offline Morgan700
Re: Trying to install Fuse (ZX Spectrum emulator) on Mint 16 MATE
« Reply #15 on: November 08, 2014, 03:43:38 pm »
Wonderful Mark, got it going. With sound and everything, thanks!
I did, however, get a couple of error messages during the install:
Selecting previously unselected package fuse-emulator-common.
(Reading database ... 197240 files and directories currently installed.)
Unpacking fuse-emulator-common (from fuse-emulator-common_1.1.1+dfsg1-2_all.deb) ...
Selecting previously unselected package fuse-emulator-gtk.
Unpacking fuse-emulator-gtk (from fuse-emulator-gtk_1.1.1+dfsg1-2_i386.deb) ...
Selecting previously unselected package spectrum-roms.
Unpacking spectrum-roms (from spectrum-roms_20081224-3_all.deb) ...
dpkg: dependency problems prevent configuration of fuse-emulator-gtk:
 fuse-emulator-gtk depends on libspectrum8 (>= 1.1.1); however:
  Version of libspectrum8 on system is 1.0.0-2build1.
dpkg: error processing fuse-emulator-gtk (--install):
 dependency problems - leaving unconfigured
Setting up spectrum-roms (20081224-3) ...
Setting up fuse-emulator-common (1.1.1+dfsg1-2) ...
Processing triggers for shared-mime-info ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
Processing triggers for man-db ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for desktop-file-utils ...
Processing triggers for mime-support ...
 fuse-emulator-gtk
Are these "gtk dependency" issues anything I need to be concerned about or will Linux just work around them?
« Reply #16 on: November 08, 2014, 03:51:50 pm »
If it's working I wouldn't worry about it, it's obviously happy to use your older version of libspectrum8
If it isn't, we can *try* installing the later version of libspectrum8 if you like.
BTW, As the window for the emulator is a bit small .. you can drag it larger, but it won't appear to get bigger untill you reach twice the size.
« Last Edit: November 08, 2014, 03:55:29 pm by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #17 on: November 08, 2014, 04:53:22 pm »
I'll leave it for now, it's working. :)
I did notice the re-sizing thing. Figured it out.
Offline Morgan700
« Reply #18 on: November 10, 2014, 12:42:14 am »
Ok, since last night I've been getting this message when I run the updater or the Synaptic Package Manager:
You have 1 broken package on your system!
Use the "Broken" filter to locate it.
When I check this, it's the "fuse-emulator-gtk" package which is listed. I'm not quite sure what to do here.
« Reply #19 on: November 10, 2014, 01:33:18 am »
What's the output from:
uname -a
dpkg -l | grep gdebi
Offline Morgan700
« Reply #20 on: November 10, 2014, 04:11:06 pm »
uname -a gives:
Linux lee-P4i65G 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013 i686 i686 i686 GNU/Linux
dpkg -l | grep gdebi gives:
ii  gdebi                                       0.9.1ubuntu1                            all          simple tool to install deb files - GNOME GUI
ii  gdebi-core                                  0.9.1ubuntu1                            all          simple tool to install deb files
« Reply #21 on: November 11, 2014, 01:41:01 pm »
Download this file:
http://mirrors.kernel.org/ubuntu/pool/universe/libs/libspectrum/libspectrum8_1.1.1-1_i386.deb
and double-click it to install.
Then see if you still get that "broken package" message.
« Last Edit: November 11, 2014, 01:42:50 pm by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #22 on: November 11, 2014, 02:43:26 pm »
When I run that, I get:
Broken dependencies
Your system has broken dependencies. This application can not continue until this issue is fixed.
To fix it run 'gksudo synaptic' or 'sudo apt-get install -f' in a terminal window.
I feel like I'm stuck in a loop here. :)
« Reply #23 on: November 11, 2014, 05:01:05 pm »
run:
sudo apt-get remove fuse-emulator-gtk fuse-emulator-gtk fuse-emulator-common
then:
sudo apt-get install libasound2 libc6 libcairo2 libgdk-pixbuf2.0-0 libglib2.0-0 libgtk-3-0 libpango-1.0-0 libpng12-0 libsdl1.2debian libspectrum8 libx11-6 libxml2 zlib1g
then create a folder on your desktop called fuse-temp2 with:
mkdir ~/Desktop/fuse-temp2
then as you're running Mint 32bit download the following 4 files and place them in the fuse-temp2 directory on your desktop:-
https://launchpad.net/ubuntu/+archive/primary/+files/fuse-emulator-common_1.1.1%2Bdfsg1-2_all.deb
https://launchpad.net/ubuntu/+archive/primary/+files/fuse-emulator-gtk_1.1.1%2Bdfsg1-2_i386.deb
http://mirrors.kernel.org/ubuntu/pool/multiverse/s/spectrum-roms/spectrum-roms_20081224-3_all.deb
now run:
cd ~/Desktop/fuse-temp2
sudo dpkg -i *.deb
« Last Edit: November 11, 2014, 08:36:05 pm by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #24 on: November 11, 2014, 11:37:36 pm »
Thanks for your patience Mark but I hit a snag or two with your previous instructions. Here's the the terminal dialogue:
lee@lee-P4i65G ~/Desktop/fuse-temp2 $ sudo dpkg -i *.deb
[sudo] password for lee:
(Reading database ... 197309 files and directories currently installed.)
Preparing to replace fuse-emulator-common 1.1.1+dfsg1-2 (using fuse-emulator-common_1.1.1+dfsg1-2_all.deb) ...
Unpacking replacement fuse-emulator-common ...
Preparing to replace fuse-emulator-gtk 1.1.1+dfsg1-2 (using fuse-emulator-gtk_1.1.1+dfsg1-2_i386.deb) ...
Unpacking replacement fuse-emulator-gtk ...
Preparing to replace libspectrum8:i386 1.1.1-1 (using libspectrum8_1.1.1-1_i386.deb) ...
Unpacking replacement libspectrum8:i386 ...
Preparing to replace spectrum-roms 20081224-3 (using spectrum-roms_20081224-3_all.deb) ...
Unpacking replacement spectrum-roms ...
dpkg: dependency problems prevent configuration of libspectrum8:i386:
 libspectrum8:i386 depends on libaudiofile1 (>= 0.3.6); however:
  Package libaudiofile1 is not installed.
dpkg: error processing libspectrum8:i386 (--install):
  Package libspectrum8:i386 is not configured yet.
 libspectrum8:i386
 fuse-emulator-gtk
« Reply #25 on: November 12, 2014, 12:00:50 am »
OK, run:
sudo apt-get remove fuse-emulator-gtk fuse-emulator-common libspectrum8
Now navigate to the fuse-temp2 directory on your desktop and double click on the:-
file .. when gdebi opens, click the "Install" button (gdebi should resolve any dependencies for you).
Then run:
sudo dpkg -i *.deb
OR
Method 2:-
Run:
sudo apt-get remove fuse-emulator-gtk fuse-emulator-common spectrum-roms libspectrum8
Then navigate to the fuse-temp2 directory on your dessktop, and use gdebi to install those 4 packages one at a time IN THIS ORDER:-
fuse-emulator-common_1.1.1+Bdfsg1-2_all.deb
fuse-emulator-gtk_1.1.1+Bdfsg1-2_i386.deb
« Last Edit: November 12, 2014, 12:13:42 am by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #26 on: November 12, 2014, 12:13:02 am »
The Package Manager says (in red):
Error: Dependency is not satisfiable:
Offline Morgan700
« Reply #27 on: November 12, 2014, 12:15:26 am »
Sorry Mark, I just saw your "Method 2" bit. Should I proceed with that?
« Reply #28 on: November 12, 2014, 12:18:23 am »
NO
What happens if you download this:
http://mirrors.kernel.org/ubuntu/pool/main/a/audiofile/libaudiofile1_0.3.6-2_i386.deb
then double-click it to install through gdebi ?
Offline Morgan700
« Reply #29 on: November 12, 2014, 12:29:14 am »
It installed fine. :)
