Author Topic: Trying to install Fuse (ZX Spectrum emulator) on Mint 16 MATE  (Read 10477 times)
Re: Trying to install Fuse (ZX Spectrum emulator) on Mint 16 MATE
« Reply #30 on: November 12, 2014, 12:31:15 am »
OK, now try method 2.
Any gdebi errors, don't move on to the next packages .. tell me the error, and which package caused it.
Offline Morgan700
« Reply #31 on: November 12, 2014, 12:36:24 am »
I didn't get as far as the gdebi part:
lee@lee-P4i65G ~ $ sudo apt-get remove fuse-emulator-gtk fuse-emulator-common spectrum-roms libspectrum8
[sudo] password for lee:
Reading package lists... Done
Building dependency tree
E: Unable to locate package fuse-emulator-gtk
E: Unable to locate package fuse-emulator-common
« Reply #32 on: November 12, 2014, 12:41:07 am »
Don't worry about that command.. just install the 4 packages through gdebi IN THE ORDER MENTIONED.
If any of them are already installed, so gdebi shows a "Remove/Uninstall" button .. remove it, then install it again .. then move on to the next.
Any throw a missing deepndencyy error, STOP, and post the error.
did that make sense ?
FYI - There *must* be a problem with your software repositories, as half of these (if not all) should be in your default reps ???
« Last Edit: November 12, 2014, 12:44:13 am by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #33 on: November 12, 2014, 12:51:02 am »
The first two came up as "already installed" so I removed and then installed them. The other two went straight through, so all four installed fine.
« Reply #34 on: November 12, 2014, 12:53:25 am »
OK, you should be good to go...
BUT
I'm still convinced you have a deeper issue with your software repositories .. these *should* have all been in your default repos.
Do you want to look into that ?
Offline Morgan700
« Reply #35 on: November 12, 2014, 12:58:07 am »
Thanks, Fuse is installed and running.  :)
Sure, tell me what to do about the repositories. I did remove a couple the other day (I was trying to get my gamepad configured but it all went wrong so I deleted the repositories associated with that particular program I had downloaded for that purpose).
« Reply #36 on: November 12, 2014, 01:03:33 am »
Hmm .. I'm a little confused here, Saucy *is* end of life, but Ubuntu doesn't *seem* to have disabled the repos yet.
So I'm baffled why your system couldn't resolve the dependencies on its own...
Can you post the output from:
« Last Edit: November 12, 2014, 01:05:23 am by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #37 on: November 12, 2014, 01:08:10 am »
sudo apt-get update gives:
lee@lee-P4i65G ~ $ sudo apt-get update
Hit http://repository.spotify.com stable InRelease
Ign http://ppa.launchpad.net karmic InRelease
Ign http://ppa.launchpad.net saucy InRelease
Ign http://dl.google.com stable InRelease
Hit http://repository.spotify.com stable/non-free i386 Packages
Hit http://dl.google.com stable Release.gpg
Hit http://repo.steampowered.com precise InRelease
Hit http://repo.steampowered.com precise/steam Sources
Hit http://repo.steampowered.com precise/steam i386 Packages
Hit http://ppa.launchpad.net karmic Release.gpg
Hit http://ppa.launchpad.net saucy Release.gpg
Hit http://dl.google.com stable/main i386 Packages
Ign http://packages.linuxmint.com petra InRelease
Ign http://extra.linuxmint.com petra InRelease
Get:1 http://packages.linuxmint.com petra Release.gpg [198 B]
Get:2 http://extra.linuxmint.com petra Release.gpg [198 B]
Ign http://repository.spotify.com stable/non-free Translation-en_GB
Get:3 http://packages.linuxmint.com petra Release [18.5 kB]
Get:4 http://extra.linuxmint.com petra Release [3,090 B]
Get:5 http://extra.linuxmint.com petra/main i386 Packages [655 B]
Hit http://ppa.launchpad.net karmic/main i386 Packages
Ign http://dl.google.com stable/main Translation-en_GB
Hit http://ppa.launchpad.net saucy/main Sources
Get:6 http://packages.linuxmint.com petra/main i386 Packages [28.7 kB]
Hit http://ppa.launchpad.net saucy/main i386 Packages
Get:7 http://packages.linuxmint.com petra/upstream i386 Packages [23.3 kB]
Get:8 http://packages.linuxmint.com petra/import i386 Packages [40.4 kB]
Ign http://extra.linuxmint.com petra/main Translation-en_GB
Ign http://ppa.launchpad.net karmic/main Translation-en_GB
Ign http://ppa.launchpad.net saucy/main Translation-en_GB
Ign http://repo.steampowered.com precise/steam Translation-en_GB
Ign http://packages.linuxmint.com petra/import Translation-en_GB
Ign http://packages.linuxmint.com petra/main Translation-en_GB
Ign http://packages.linuxmint.com petra/upstream Translation-en_GB
Fetched 115 kB in 8s (13.5 kB/s)
W: Duplicate sources.list entry http://dl.google.com/linux/chrome/deb/ stable/main i386 Packages (/var/lib/apt/lists/dl.google.com_linux_chrome_deb_dists_stable_main_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
lee@lee-P4i65G ~ $
« Reply #38 on: November 12, 2014, 01:17:24 am »
What's the output from:
for X in /etc/apt/sources.list.d/*.list; do echo; echo; echo "** $X:"; echo; cat $X; done
Offline Morgan700
« Reply #39 on: November 12, 2014, 01:19:40 am »
I get:
lee@lee-P4i65G ~ $ for X in /etc/apt/sources.list.d/*.list; do echo; echo; echo "** $X:"; echo; cat $X; done
** /etc/apt/sources.list.d/getdeb.list:
# deb http://archive.getdeb.net/ubuntu/ saucy-getdeb apps
** /etc/apt/sources.list.d/google-chrome.list:
### THIS FILE IS AUTOMATICALLY CONFIGURED ###
# You may comment out this entry, but any other modifications may be lost.
deb http://dl.google.com/linux/chrome/deb/ stable main
** /etc/apt/sources.list.d/google-earth.list:
deb http://dl.google.com/linux/earth/deb/ stable main
** /etc/apt/sources.list.d/google.list:
** /etc/apt/sources.list.d/jon-severinsson-ffmpeg-saucy.list:
deb http://ppa.launchpad.net/jon-severinsson/ffmpeg/ubuntu saucy main
deb-src http://ppa.launchpad.net/jon-severinsson/ffmpeg/ubuntu saucy main
** /etc/apt/sources.list.d/mjblenner-ppa-hal-saucy.list:
deb http://ppa.launchpad.net/mjblenner/ppa-hal/ubuntu saucy main
deb-src http://ppa.launchpad.net/mjblenner/ppa-hal/ubuntu saucy main
** /etc/apt/sources.list.d/nilarimogard-webupd8-saucy.list:
deb http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu saucy main
deb-src http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu saucy main
** /etc/apt/sources.list.d/noobslab-themes-saucy.list:
deb http://ppa.launchpad.net/noobslab/themes/ubuntu saucy main
deb-src http://ppa.launchpad.net/noobslab/themes/ubuntu saucy main
** /etc/apt/sources.list.d/official-package-repositories.list:
# Do not edit this file manually, use Software Sources instead.
#id:linuxmint_main
deb http://packages.linuxmint.com/ petra main upstream import
#id:linuxmint_extra
deb http://extra.linuxmint.com/ petra main
# deb http://archive.ubuntu.com/ubuntu/ saucy main restricted universe multiverse
# deb http://archive.ubuntu.com/ubuntu/ saucy-updates main restricted universe multiverse
# deb http://security.ubuntu.com/ubuntu/ saucy-security main restricted universe multiverse
# deb http://archive.canonical.com/ubuntu/ saucy partner
** /etc/apt/sources.list.d/spotify.list:
deb http://repository.spotify.com/ stable non-free
** /etc/apt/sources.list.d/steam.list:
deb http://repo.steampowered.com/steam/ precise steam
deb-src http://repo.steampowered.com/steam/ precise steam
** /etc/apt/sources.list.d/ubuntu-x-swat-x-updates-saucy.list:
deb http://ppa.launchpad.net/ubuntu-x-swat/x-updates/ubuntu saucy main
deb-src http://ppa.launchpad.net/ubuntu-x-swat/x-updates/ubuntu saucy main
** /etc/apt/sources.list.d/webupd8team-java-saucy.list:
deb http://ppa.launchpad.net/webupd8team/java/ubuntu saucy main
deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu saucy main
** /etc/apt/sources.list.d/xorg-edgers-ppa-saucy.list:
deb http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu saucy main
deb-src http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu saucy main
lee@lee-P4i65G ~ $
« Reply #40 on: November 12, 2014, 01:28:08 am »
run:
cd /etc/apt/sources.list.d
sudo rm -v google.list
sudo rm -v google.list.save
(that last command may fail with a "doesn't exist" error .. just move on to the next command)
has this error:-
disappeared ?
Offline Morgan700
« Reply #41 on: November 12, 2014, 01:35:53 am »
Yes, Mark, it's disappeared now.
Out of interest, the sudo rm -v google.list.save command gave:
rm: cannot remove ‘google.list.save’: No such file or directory
« Reply #42 on: November 12, 2014, 01:38:18 am »
That error just meant a backup hadn't been created yet .. it's unimportant.
OK, we'll leave it at that for now as I can't see any other errors, but if you have any future problems installing software, gimme a shout.
And once more I'm going to repeat, you 'really' should look to upgrade to Mint17 / Ubuntu 14.04 / Peppermint 5 /etc. .. as Ubuntu 13.10 (so therefore Mint 16) is "end of life" and Ubuntu will take down the repositories VERY soon.
Mint17 / Ubuntu 14.04 / Peppermint 5 are all LTS releases, so will be good to go for 5 years.
« Last Edit: November 12, 2014, 01:40:08 am by Mark Greaves (PCNetSpec) »
Offline Morgan700
« Reply #43 on: November 12, 2014, 01:40:27 am »
Thanks again Mark. I am looking to upgrade to Mint 17 as soon as I can. Have a good night.
« Reply #44 on: November 12, 2014, 01:47:08 am »
You're most welcome, and you have a good night too :)
