Author Topic: [SOLVED] Unable to install Openshot  (Read 9669 times)
Offline pooky2483
« on: November 26, 2014, 03:19:15 pm »
I am running Kubuntu 12.04 and I tried to install openshot via Muon Software Centre which failed so I tried through Terminal, that failed too.
I get;
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo apt-get install openshot
Reading package lists... Done
Building dependency tree
 openshot : Depends: python-mlt3 but it is not going to be installed or
                     python-mlt2 but it is not installable
I've tried other solutions...
sudo apt-get install -f
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove
Anyone got any ideas what to try next to fix it.
« Last Edit: December 03, 2014, 06:33:53 am by pooky2483 »
Offline chemicalfan
Re: Unable to install Openshot
« Reply #1 on: November 26, 2014, 04:35:29 pm »
What error do you get with:
sudo apt-get install python-mlt3
Edit: By the look of the openshot error, that package may be broken as it refers to both python-mlt3 & python-mlt2
Edit 2: mlt2 is only available in lucid, and mlt3 is only available in precise. Try:
That's available in trusty, and may do the job...?
« Last Edit: November 26, 2014, 04:39:03 pm by chemicalfan »
« Reply #2 on: November 26, 2014, 08:06:47 pm »
I think in precise you have to install python-mlt3 before openshot .. so try:
sudo apt-get remove --purge openshot
Offline pooky2483
« Reply #3 on: November 26, 2014, 11:14:35 pm »
Mark, I get to stage 2 and get this...
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo apt-get remove --purge openshot
  libmovit2 python-pygoocanvas libvidstab1.0 recordmydesktop libmlt-data libmlt4
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED
  openshot*
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 269240 files and directories currently installed.)
Removing openshot ...
Purging configuration files for openshot ...
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo apt-get install python-mlt3
 python-mlt3 : Depends: libmlt++3 but it is not going to be installed
Offline pooky2483
« Reply #4 on: November 26, 2014, 11:20:08 pm »
I can install python-mlt but not mlt3
« Reply #5 on: November 27, 2014, 12:18:20 am »
OK, as chemicalfan said .. try:
then:
Offline pooky2483
« Reply #6 on: November 27, 2014, 08:55:46 am »
Afraid that didn’t work...
[sudo] password for pooky2483:
python-mlt is already the newest version.
  python-pygoocanvas recordmydesktop
Offline chemicalfan
« Reply #7 on: November 27, 2014, 09:06:35 am »
Can you run:
sudo apt-get install -f openshot
Hoping it might install the package regardless of the unmet dependency (as I think it's met by python-mlt, it's just the package info that's broken)
Offline pooky2483
« Reply #8 on: November 27, 2014, 01:57:03 pm »
Nope... I get;
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo apt-get install -f openshot
Offline chemicalfan
« Reply #9 on: November 27, 2014, 02:55:22 pm »
There's a similar bug registered here - https://bugs.launchpad.net/ubuntu/+source/mlt/+bug/1009409
Hasn't been updated for a while, no mention of 14.04 but seems to still apply.
Try adding the Openshot PPA - http://openshot.org/ppa/ and then updating and trying to install it again
Offline pooky2483
« Reply #10 on: November 27, 2014, 04:09:25 pm »
That didn’t work, failed at the last command...
pooky2483@pooky2483-Kubuntu-1204-3:~$  sudo apt-get install openshot openshot-doc
 openshot : Depends: python-mlt5 but it is not installable or
Offline chemicalfan
« Reply #11 on: November 27, 2014, 04:25:45 pm »
I've been an idiot, I was sure you were running Kubuntu 14.04, not 12.04  :-[
Ok, so what happens if you run:
sudo apt-get install -f libmlt++3
Offline pooky2483
« Reply #12 on: November 27, 2014, 08:36:15 pm »
Still unable to install openshot...
« Reply #13 on: November 27, 2014, 09:49:07 pm »
error messages will help ;)
Offline pooky2483
« Reply #14 on: November 28, 2014, 05:12:02 pm »
Sorry Mark, just been getting the same errors as earlier.
