Author Topic: [SOLVED] Unable to install Openshot  (Read 9667 times)
Re: Unable to install Openshot
« Reply #30 on: December 01, 2014, 03:23:07 pm »
What's the output from:
apt-cache policy libmlt6
Offline pooky2483
« Reply #31 on: December 01, 2014, 03:45:30 pm »
pooky2483@pooky2483-Kubuntu-1204-3:~$ apt-cache policy libmlt6
libmlt6:
  Installed: (none)
  Candidate: 0.9.3+git20140926.bbf724b6-0ubuntu0~sunab~precise1
  Version table:
     0.9.3+git20140926.bbf724b6-0ubuntu0~sunab~precise1 0
        500 http://ppa.launchpad.net/sunab/kdenlive-release/ubuntu/ precise/main amd64 Packages
        100 /var/lib/dpkg/status
« Reply #32 on: December 01, 2014, 04:48:46 pm »
And therein lies the problem.
You've added a PPA (kdenlive) that has a more recent version of libmlt than the one in the default repos (and the one openshot is expecting to find).
So the only way to install openshot from the default repos would be to purge that PPA .. but that will break or remove kdenlive
Your other option would be to try adding the openshot PPA and installing version 1.4.3 from there .. this seems to have dependencies that might match (it can handle mlt2, 3, and 5 .. whereas the default 12.04 version can only handle mlt2, and 3)
run:
sudo add-apt-repository ppa:openshot.developers/ppa
then post the output from:
sudo aptitude install -s openshot
again
« Last Edit: December 01, 2014, 05:13:58 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #33 on: December 01, 2014, 05:06:09 pm »
Would I be able to roll back kdenlive and hopefully libmlt too then install openshot then do an update.
Or remove kdenlive, install openshot and then reinstall kdenlive?
Maybe the only way to find out is to try it...
What do you think, Mark?
« Reply #34 on: December 01, 2014, 05:13:35 pm »
please see the edit in my last posting.
Offline pooky2483
« Reply #35 on: December 01, 2014, 05:30:36 pm »
Seen it, followed it and not yet entered anything on the prompt
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo aptitude install -s openshot
The following NEW packages will be installed:
  libmlt++3{a} libmlt6{ab} melt{a} openshot python-mlt3{a}
The following packages will be REMOVED:
  recordmydesktop{u}
0 packages upgraded, 5 newly installed, 1 to remove and 1 not upgraded.
Need to get 24.8 MB/25.5 MB of archives. After unpacking 64.1 MB will be used.
The following packages have unmet dependencies:
 libmlt6 : Conflicts: libmlt4 but 0.7.6+git20120204-2 is installed.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     libmlt++3 [Not Installed]
2)     libmlt6 [Not Installed]
3)     melt [Not Installed]
4)     openshot [Not Installed]
5)     python-mlt3 [Not Installed]
Accept this solution? [Y/n/q/?]
« Reply #36 on: December 01, 2014, 05:37:30 pm »
You can accept it, but you'll loose recordmydesktop
Offline pooky2483
« Reply #37 on: December 01, 2014, 05:51:10 pm »
That's OK as I've got Vokoscreen, which you recommended.
Offline pooky2483
« Reply #38 on: December 01, 2014, 05:52:08 pm »
I accepted it and got this;
Accept this solution? [Y/n/q/?] y
  libmovit2{u} libvidstab1.0{u} python-pygoocanvas{u} recordmydesktop{u}
0 packages upgraded, 0 newly installed, 4 to remove and 1 not upgraded.
Need to get 0 B of archives. After unpacking 1,641 kB will be freed.
Do you want to continue? [Y/n/?] y
Would download/install/remove packages.
What does that mean???
« Reply #39 on: December 01, 2014, 05:55:03 pm »
yeah just accept it .. the other packages are already orphaned.
Offline pooky2483
« Reply #40 on: December 01, 2014, 05:57:07 pm »
I have done and got this at the end;
It's confusing as I've already pressed 'y'
« Reply #41 on: December 01, 2014, 06:07:58 pm »
Ooops sorry, we were running it in "simulated dry run" mode (-s option).
(where it tells you what WOULD be done if you ran it properly)
Run:
sudo aptitude install openshot
Offline pooky2483
« Reply #42 on: December 01, 2014, 06:24:05 pm »
Done, but it doesn’t look like openshot has been installed, I've checked for it but it's not there. Is the next step to install?
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo aptitude install openshot
[sudo] password for pooky2483:
  recordmydesktop{u}
(Reading database ... 271918 files and directories currently installed.)
Removing libmovit2 ...
Removing libvidstab1.0 ...
Removing python-pygoocanvas ...
Removing recordmydesktop ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for man-db ...
Emegra
  • Guest
« Reply #43 on: December 01, 2014, 06:28:24 pm »
Hi pooky
Have you tried opening Openshot from the terminal ?
« Reply #44 on: December 01, 2014, 06:29:55 pm »
now what does:
report
And what does:
sudo aptitude install -s libmlt6
report
« Last Edit: December 01, 2014, 06:32:39 pm by Mark Greaves (PCNetSpec) »
