...Like its Windows counterparts, the Linux trojan is extremely stealthy. It can't be detected using the common netstat command. To conceal itself, the backdoor sits dormant until attackers send it unusually crafted packets that contain "magic numbers" in their sequence numbers. The malware may have sat unnoticed on at least one victim computer for years, although Kaspersky Lab researchers still have not confirmed that suspicion. The trojan is able to run arbitrary commands even though it requires no elevated system privileges."It's a very interesting piece of code," Baumgartner said. "Not only does it run on Linux, but you can't detect it in the usual ways."Even a regular user with limited privileges can launch it, allowing it to intercept traffic and run commands on infected machines. Capabilities include the ability to communicate with servers under the control of attackers and functions allowing attackers to run commands of their choice and perform remote management.Even after its discovery, the Linux component remains a mystery. The underlying executable file is written in the C and C++ languages and contains code from previously written libraries, a property that gives the malicious file self-reliance. The code is also stripped of symbol information, making it hard for researchers to reverse engineer or analyze. As a result, Baumgartner said the trojan may have capabilities that have not yet been uncovered.....
It can't be detected using the common netstat command. To conceal itself, the backdoor sits dormant until attackers send it unusually crafted packets that contain "magic numbers" in their sequence numbers. The malware may have sat unnoticed on at least one victim computer for years, although Kaspersky Lab researchers still have not confirmed that suspicion.[snip]Administrators who want to check for Turla-infected Linux systems can check outgoing traffic for connections to news-bbc.podzone[.]org or 80.248.65.183, which are the addresses of known command and control channels hardcoded into the Linux trojan. Admins can also build a signature using a tool called YARA that detects the strings "TREX_PID=%u" and "Remote VS is empty !"
