Author Topic: Install/Upgrade Linux Kernel To 3.18.3 Stable In Ubuntu/Linux Mint/Peppermint  (Read 5350 times)
Offline MohdSohail
  • Mohd Sohail
  • Linux is faster, easier & fun. linuxandubuntu.com
Recently Linus Torvalds announced Linux Kernel 3.18.3. The Kernel includes several bug fixes. Latest Linux Kernel includes new features, bug fixes and improve security. Updating/Upgrading Linux Kernel is recommended.
Read on LinuxAndUbuntu
What is Linux Kernel?
Those who don't know what is the Linux Kernel they should know it because Linux kernel is the essential part of any Linux operating system. It is responsible for resource allocation, low-level hardware interfaces, security, simple communications, basic file system management, and more. Written from scratch by Linus Torvalds (with help from various developers), Linux is a clone of the UNIX operating system. It is geared towards POSIX and Single UNIX Specification compliances.
Latest Stable Linux Kernel Version 3.18.3
The Linux Kernel 3.18.3 release has many changes. Check the complete changelog here.
Install Linux Kernel 3.18.3
Because it is not available via PPA, the needed deb packages of Kernel 3.18.1 are available via kernel.ubuntu.com. Follow the instructions for your system’s architecture exactly, in order to get a successful installation.
To install or update Latest Stable Kernel 3.18.1 on Ubuntu 15.04 vivid vervet, Ubuntu 14.10 Utopic Unicorn, Ubuntu 14.04 Trusty Tahr (LTS) , Linux Mint 17.1 Rebecca, Linux Mint 17 Qiana, Pinguy OS 14.04, Elementary OS 0.3 Freya, Elementary OS 0.2 Luna, Peppermint Five, Deepin 2014, LXLE 14.04, Linux Lite 2.0, Linux Lite 2.2 and other Ubuntu derivative systems, open a new Terminal window and bash (get it?) in the following commands:
For 32-bit systems: Downlaod .deb files
$ wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.18.3-vivid/linux-headers-3.18.3-031803_3.18.3-031803.201501161810_all.deb
$ wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.18.3-vivid/linux-headers-3.18.3-031803-generic_3.18.3-031803.201501161810_i386.deb
$ wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.18.3-vivid/linux-image-3.18.3-031803-generic_3.18.3-031803.201501161810_i386.deb
Install the files now-
$ sudo dpkg -i linux-headers-3.18.3*.deb linux-image-3.18.3*.deb
Atfer install complete, update grub and reboot your computer and choose new kernel in grub :
$ sudo update-grub
$ sudo reboot
For Linux system 64 bit :
$ wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.18.3-vivid/linux-headers-3.18.3-031803-generic_3.18.3-031803.201501161810_amd64.deb
$ wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.18.3-vivid/linux-image-3.18.3-031803-generic_3.18.3-031803.201501161810_amd64.deb
$ sudo update-grub
$ sudo reboot
How to UnInstall Linux Kernel 3.18.3
sudo apt-get remove 'linux-headers-3.18.3*' 'linux-image-3.18.3*'
You've done it! Now you can check your Linux Kernel version after restarting system with the following command -
$ uname
Also Read How To Install Software In Linux : An Introduction
« Last Edit: January 20, 2015, 04:32:52 pm by MohdSohail »
Offline chemicalfan
Probably should mention that upgrading the kernel isn't the most stable thing you can do. The other components of the OS such as X and glibc are packaged with the distro-provided kernel in mind, and may even be patched accordingly. Just because Linus regards the kernel as a "stable" release, doesn't mean that your distro does.
