Author Topic: No flash on my mint netbook  (Read 6082 times)
Offline Melissa
  • Vintage nerd
  • Gender: Female
« on: February 16, 2015, 08:33:49 pm »
I am well pissed off- was prompted to update Firefox, so did so, now adobe not working. Went into package manager and chose it but still not working. It is FREEZING downstairs and wanted to watch iplayer under the duvet- please help Mark! Now I have to go sit in freezing lounge and eat my supper there and watch prog there.
My computers:
Acer Chromebook
Asus notebook x102B, running on Peppermint 9.
Re: No flash on my mint netbook
« Reply #1 on: February 16, 2015, 08:37:06 pm »
Can you post the output from:
dpkg -l | grep flash
uname -a
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #2 on: February 16, 2015, 08:40:58 pm »
[email protected] ~ $ dpkg -l | grep flash
iU  flashplugin-downloader                 11.2.202.442ubuntu0.12.04.1             Adobe Flash Player plugin installer (transitional package)
iU  flashplugin-installer                  11.2.202.442ubuntu0.12.04.1             Adobe Flash Player plugin installer
ii  mint-flashplugin-11                    11.0.1.152                              Adobe Flash plugin 11
[email protected] ~ $ uname -a
Linux karij-Inspiron-1011 3.2.0-23-generic #36-Ubuntu SMP Tue Apr 10 20:41:14 UTC 2012 i686 i686 i386 GNU/Linux
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #3 on: February 16, 2015, 08:48:44 pm »
Checked firefox plug in page and it was deactivated- god knows why. I ticked it reebooted and it works but says its vulnerable. At least I can have my supper up here under duvet and watch it. Will be back later Mark!
My computers:
Acer Chromebook
« Reply #4 on: February 16, 2015, 08:57:57 pm »
OK, I think it's picking up thee older version from mint-flashplugin-11 .. run:
sudo apt-get remove --purge flashplugin-installer flashplugin-downloader mint-flashplugin-11
sudo apt-get install flashplugin-installer
then run:
sudo updatedb
then post the output from:
locate libflashplayer.so
« Last Edit: February 16, 2015, 09:00:37 pm by Mark Greaves (PCNetSpec) »
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #5 on: February 16, 2015, 10:08:24 pm »
[email protected] ~ $ sudo apt-get remove --purge flashplugin-installer flashplugin-downloader mint
[sudo] password for karij:
Sorry, try again.
Sorry, try again.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
[email protected] ~ $ sudo apt-get install flashplugin-installer
[email protected] ~ $ sudo updatedb
[email protected] ~ $ locate libflashplayer.so
/etc/alternatives/libflashplayer.so
/home/karij/usr/lib/flash-plugin/libflashplayer.so
/opt/mint-flashplugin-11/libflashplayer.so
/usr/lib/mozilla/plugins/libflashplayer.so
/var/lib/dpkg/alternatives/libflashplayer.so
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #6 on: February 16, 2015, 10:10:02 pm »
See above for the sudo stuff! Thanks Mark- I thought too that it was still trying to recognise the older version. I had the caps on hence the p/w problem. I wish the netbook had a caps lock- I can't tell if it's on - no light as the laptop has.
My computers:
Acer Chromebook
« Reply #7 on: February 16, 2015, 10:23:30 pm »
run:
and if that completes without errors, try the instructions in my last posting again
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #8 on: February 16, 2015, 11:10:38 pm »
[email protected] ~ $ sudo dpkg --configure -a
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Setting up libnspr4-0d (4.10.7-0ubuntu0.12.04.1) ...
Setting up update-notifier-common (0.119ubuntu8.7) ...
Configuration file `/etc/apt/apt.conf.d/10periodic'
 ==> File on system created by you or by a script.
 ==> File also in package provided by package maintainer.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
*** 10periodic (Y/I/N/O/D/Z) [default=N] ?
My computers:
Acer Chromebook
« Reply #9 on: February 16, 2015, 11:12:03 pm »
Type
N
then hit enter.
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #10 on: February 16, 2015, 11:12:32 pm »
I am getting this message:
See attachment! Low disk space.
My computers:
Acer Chromebook
« Reply #11 on: February 16, 2015, 11:15:18 pm »
Have you had a look at your screenshot .. it doesn't show the message.
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #12 on: February 16, 2015, 11:21:08 pm »
Type
N
then hit enter.
Oh dang! My hands are so cold I hit y by accident- sorry Mark. It's only 40 f here... :'(
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #13 on: February 16, 2015, 11:22:32 pm »
Yeahhh..sorry it didn't grab the message and now the disk space box vanished. Next time it pops up I will post what it says.
My computers:
Acer Chromebook
« Reply #14 on: February 16, 2015, 11:24:11 pm »
Yeah Y is okay too .. in fact it was probably a better idea :)
What's the output from:
df -h
