Author Topic: No flash on my mint netbook  (Read 5934 times)
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: No flash on my mint netbook-SOLVED
« Reply #15 on: February 16, 2015, 11:25:42 pm »
Phew..thought you were gonna tell me off for being a right doofus!
karij@karij-Inspiron-1011 ~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda1       6.5G  6.0G  224M  97% /
udev            490M  4.0K  490M   1% /dev
tmpfs           199M  940K  198M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            497M  1.6M  495M   1% /run/shm
« Last Edit: February 17, 2015, 01:18:42 am by Melissa »
My computer: Asus notebook x102B, running on Peppermint 9.
« Reply #16 on: February 16, 2015, 11:30:47 pm »
You need to free up some space on your had drive
a) if possible move some of your saved files from your home folder off to something like a USB stick
b) empty your recycle bin
d) run these 2 commands
sudo apt-get clean
sudo apt-get autoremove -y
then post the output from:
df -h
again
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #17 on: February 16, 2015, 11:53:24 pm »
karij@karij-Inspiron-1011 ~ $ sudo apt-get clean
[sudo] password for karij:
karij@karij-Inspiron-1011 ~ $ sudo apt-get autoremove -y
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED
  icoutils kate-data katepart kde-runtime kde-runtime-data kdelibs-bin
  kdelibs5-data kdelibs5-plugins kdoctools kubuntu-debug-installer
  libattica0.3 libclucene0ldbl libdlrestrictions1 libkatepartinterfaces4
  libkcmutils4 libkde3support4 libkdeclarative5 libkdecore5 libkdesu5
  libkdeui5 libkdewebkit5 libkdnssd4 libkemoticons4 libkfile4 libkhtml5
  libkidletime4 libkio5 libkjsapi4 libkjsembed4 libkmediaplayer4
  libknewstuff3-4 libknotifyconfig4 libkntlm4 libkparts4 libkprintutils4
  libkpty4 libkrosscore4 libktexteditor4 libkutils4 libnepomuk4
  libnepomukdatamanagement4 libnepomukquery4a libnepomuksync4 libnepomukutils4
  libntrack-qt4-1 libntrack0 libphonon4 libplasma3 libpolkit-qt-1-1
  libqapt-runtime libqapt1 libqca2 libqt4-designer libqt4-qt3support libsolid4
  libsoprano4 libstreamanalyzer0 libstreams0 libthreadweaver4 libvirtodbc0
  ntrack-module-libnl-0 odbcinst odbcinst1debian2 oxygen-icon-theme phonon
  phonon-backend-gstreamer plasma-scriptengine-javascript qapt-batch
  shared-desktop-ontologies soprano-daemon virtuoso-minimal
  virtuoso-opensource-6.1-bin virtuoso-opensource-6.1-common
0 upgraded, 0 newly installed, 73 to remove and 496 not upgraded.
After this operation, 145 MB disk space will be freed.
(Reading database ... 189492 files and directories currently installed.)
Removing icoutils ...
Removing kubuntu-debug-installer ...
Removing qapt-batch ...
Removing kde-runtime ...
Removing kdelibs5-plugins ...
Removing katepart ...
Removing kate-data ...
Removing kde-runtime-data ...
Removing kdelibs-bin ...
Removing kdelibs5-data ...
Removing kdoctools ...
Removing plasma-scriptengine-javascript ...
Removing libplasma3 ...
Removing libknewstuff3-4 ...
Removing libkhtml5 ...
Removing libkatepartinterfaces4 ...
Removing libktexteditor4 ...
Removing libkutils4 ...
Removing libkprintutils4 ...
Removing libkmediaplayer4 ...
Removing libkdewebkit5 ...
Removing libkde3support4 ...
Removing libkparts4 ...
Removing libnepomukutils4 ...
Removing libnepomuksync4 ...
Removing libnepomukquery4a ...
Removing libnepomukdatamanagement4 ...
Removing libknotifyconfig4 ...
Removing libkfile4 ...
Removing libkemoticons4 ...
Removing libkio5 ...
Removing libnepomuk4 ...
Removing libkrosscore4 ...
Removing libkidletime4 ...
Removing libkdnssd4 ...
Removing libkdeclarative5 ...
Removing libkcmutils4 ...
Removing libkdeui5 ...
Removing libattica0.3 ...
Removing libstreamanalyzer0 ...
Removing libsoprano4 ...
Removing libclucene0ldbl ...
Removing libkdesu5 ...
Removing libkpty4 ...
Removing libkntlm4 ...
Removing libkjsembed4 ...
Removing libkjsapi4 ...
Removing libkdecore5 ...
Removing libdlrestrictions1 ...
Removing libntrack-qt4-1 ...
Removing phonon ...
Removing phonon-backend-gstreamer ...
Removing libphonon4 ...
Removing libqapt-runtime ...
Removing libpolkit-qt-1-1 ...
Removing libqapt1 ...
Removing libqca2 ...
Removing libqt4-qt3support ...
Removing libqt4-designer ...
Removing libsolid4 ...
Removing libstreams0 ...
Removing libthreadweaver4 ...
Removing virtuoso-minimal ...
Removing soprano-daemon ...
Removing libvirtodbc0 ...
Virtuoso has been deleted (if it existed at all) because its usage count became zero
Removing oxygen-icon-theme ...
Removing shared-desktop-ontologies ...
Removing virtuoso-opensource-6.1-bin ...
Removing virtuoso-opensource-6.1-common ...
Removing odbcinst1debian2 ...
Removing libntrack0 ...
Removing ntrack-module-libnl-0 ...
Removing odbcinst ...
Processing triggers for man-db ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for gnome-menus ...
Processing triggers for desktop-file-utils ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for hicolor-icon-theme ...
Processing triggers for shared-mime-info ...
/dev/sda1       6.5G  5.0G  1.2G  82% /
none            497M  1.3M  495M   1% /run/shm
Yeah, it's small SSD. Got another HD to be pout in it it- 2 years' now, but need to persuade someone from LUG group to put it in for me and then help me load Mint back on!
Rubbish bin is empty and got very little files on it.
Most of my files are on my Maxtor portable HD.
« Reply #18 on: February 17, 2015, 12:00:07 am »
Run:
sudo apt-get remove --purge flashplugin-installer flashplugin-downloader mint-flashplugin-11
sudo apt-get install flashplugin-installer
then run:
sudo updatedb
dpkg -l | grep flash
locate libflashplayer.so
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #19 on: February 17, 2015, 12:46:34 am »
karij@karij-Inspiron-1011 ~ $ sudo apt-get remove --purge flashplugin-installer flashplugin-downloader mint-flashplugin-11
  flashplugin-downloader* flashplugin-installer* mint-flashplugin-11*
0 upgraded, 0 newly installed, 3 to remove and 495 not upgraded.
After this operation, 17.2 MB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 178496 files and directories currently installed.)
Removing flashplugin-downloader ...
Removing flashplugin-installer ...
Purging configuration files for flashplugin-installer ...
Removing mint-flashplugin-11 ...
Processing triggers for update-notifier-common ...
karij@karij-Inspiron-1011 ~ $ sudo apt-get install flashplugin-installer
Suggested packages:
  x-ttcidfont-conf ttf-mscorefonts-installer ttf-xfree86-nonfree xfs
0 upgraded, 1 newly installed, 0 to remove and 495 not upgraded.
Need to get 6,988 B of archives.
After this operation, 140 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu/ precise-updates/multiverse flashplugin-installer i386 11.2.202.442ubuntu0.12.04.1 [6,988 B]
Fetched 6,988 B in 0s (27.0 kB/s)
Preconfiguring packages ...
Selecting previously unselected package flashplugin-installer.
(Reading database ... 178472 files and directories currently installed.)
Unpacking flashplugin-installer (from .../flashplugin-installer_11.2.202.442ubuntu0.12.04.1_i386.deb) ...
flashplugin-installer: downloading http://archive.canonical.com/pool/partner/a/adobe-flashplugin/adobe-flashplugin_11.2.202.442.orig.tar.gz
Installing from local file /tmp/tmpg1miVo.gz
Flash Plugin installed.
Setting up flashplugin-installer (11.2.202.442ubuntu0.12.04.1) ...
karij@karij-Inspiron-1011 ~ $ sudo updatedb
karij@karij-Inspiron-1011 ~ $ dpkg -l | grep flash
ii  flashplugin-installer                  11.2.202.442ubuntu0.12.04.1             Adobe Flash Player plugin installer
karij@karij-Inspiron-1011 ~ $ locate libflashplayer.so
/home/karij/usr/lib/flash-plugin/libflashplayer.so
/usr/lib/flashplugin-installer/libflashplayer.so
« Reply #20 on: February 17, 2015, 12:51:58 am »
Dunno where this has come from "/home/karij/usr/lib/flash-plugin/libflashplayer.so" but it shouldn't be there.
Delete it with:
rm -v /home/karij/usr/lib/flash-plugin/libflashplayer.so
now close ALL web browser instances, then reopen Firefox.
and test Flash.
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #21 on: February 17, 2015, 12:59:07 am »
karij@karij-Inspiron-1011 ~ $ rm -v /home/karij/usr/lib/flash-plugin/libflashplayer.s
rm: cannot remove `/home/karij/usr/lib/flash-plugin/libflashplayer.s': No such file or directory
« Reply #22 on: February 17, 2015, 01:05:55 am »
Try it again, but this time without chopping the "o" off the end of the command ;)
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #23 on: February 17, 2015, 01:13:37 am »
er.so
removed `/home/karij/usr/lib/flash-plugin/libflashplayer.so'
Sorry it's freezing here, hands are like ice~!
« Reply #24 on: February 17, 2015, 01:16:08 am »
So have you closed ALL web browser instances, reopened Firefox, and tested flash ?
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #25 on: February 17, 2015, 01:16:24 am »
Looks all in order, thanks Mark!
« Reply #26 on: February 17, 2015, 01:17:03 am »
You're welcome :)
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #27 on: February 25, 2015, 09:43:58 pm »
Now the adobe is ok of sorts but I noticed some lagging on BBC iplayer last night ( but a live streaming event worked ok but not tonight), then I got that my firefox is out of date, when I was on it before but we just did it a few days ago...
I am talking about Mint netbook.
Offline chemicalfan
« Reply #28 on: February 26, 2015, 09:41:09 am »
Please can you post the result of:
dpkg -l | grep firefox
Also, are you sure all updates are done? Load up Update Manager and click on the Refresh button at the top
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #29 on: February 26, 2015, 06:14:19 pm »
arij@karij-Inspiron-1011 ~ $ dpkg -l | grep firefox
ii  firefox                                35.0.1+build1-0ubuntu0.12.04.1          Safe and easy web browser from Mozilla
ii  firefox-gnome-support                  20.0+build1-0ubuntu0.12.04.3            Safe and easy web browser from Mozilla - GNOME support
ii  firefox-locale-en                      20.0+build1-0ubuntu0.12.04.3            English language pack for Firefox
Yeah I thought updates done, will go on update manager now.
