Author Topic: No flash on my mint netbook  (Read 5861 times)
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: No flash on my mint netbook
« Reply #30 on: February 26, 2015, 06:16:50 pm »
Ok done that and a box came up with this message:
Could not download all repository indexes
The repository may no longer be available or could not be contacted because of network problems. If available, an older version of the failed index will be used. Otherwise, the repository will be ignored. Check your network connection and ensure the repository address is correct in 'Repositories' under 'Settings'.
My computer: Asus notebook x102B, running on Peppermint 9.
« Reply #31 on: February 26, 2015, 07:18:52 pm »
can you post the output from:
cat /etc/lsb-release
uname -a
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #32 on: February 26, 2015, 07:27:50 pm »
Will do in a bit thanks- tea time.
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #33 on: February 26, 2015, 09:36:28 pm »
karij@karij-Inspiron-1011 ~ $ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=13
DISTRIB_CODENAME=maya
DISTRIB_DESCRIPTION="Linux Mint 13 Maya"
karij@karij-Inspiron-1011 ~ $ uname -a
Linux karij-Inspiron-1011 3.2.0-23-generic #36-Ubuntu SMP Tue Apr 10 20:41:14 UTC 2012 i686 i686 i386 GNU/Linux
karij@karij-Inspiron-1011 ~ $ sudo apt-get update
[sudo] password for karij:
Hit http://archive.canonical.com precise Release.gpg
Hit http://archive.canonical.com precise/partner i386 Packages
Hit http://archive.canonical.com precise/partner TranslationIndex
Hit http://archive.ubuntu.com precise Release.gpg
Get:1 http://archive.ubuntu.com precise-updates Release.gpg [198 B]
Hit http://archive.canonical.com precise/partner Translation-en
Get:2 http://security.ubuntu.com precise-security Release.gpg [198 B]
Get:3 http://packages.linuxmint.com maya Release.gpg [198 B]
Get:4 http://security.ubuntu.com precise-security Release [53.0 kB]
Get:5 http://packages.linuxmint.com maya Release [24.3 kB]
Get:6 http://archive.ubuntu.com precise-updates Release [194 kB]
Get:7 http://packages.linuxmint.com maya/main i386 Packages [18.2 kB]
Get:8 http://security.ubuntu.com precise-security/main i386 Packages [527 kB]
Get:9 http://packages.linuxmint.com maya/upstream i386 Packages [10.6 kB]
Get:10 http://packages.linuxmint.com maya/import i386 Packages [41.5 kB]
Ign http://packages.linuxmint.com maya/import TranslationIndex
Ign http://packages.linuxmint.com maya/main TranslationIndex
Ign http://packages.linuxmint.com maya/upstream TranslationIndex
Hit http://archive.ubuntu.com precise/main i386 Packages
Hit http://archive.ubuntu.com precise/restricted i386 Packages
Hit http://archive.ubuntu.com precise/universe i386 Packages
Hit http://archive.ubuntu.com precise/multiverse i386 Packages
Hit http://archive.ubuntu.com precise/main TranslationIndex
Hit http://archive.ubuntu.com precise/multiverse TranslationIndex
Hit http://archive.ubuntu.com precise/restricted TranslationIndex
Hit http://archive.ubuntu.com precise/universe TranslationIndex
Get:11 http://archive.ubuntu.com precise-updates/main i386 Packages [914 kB]
Ign http://packages.linuxmint.com maya/import Translation-en_GB
Ign http://packages.linuxmint.com maya/main Translation-en_GB
Ign http://packages.linuxmint.com maya/upstream Translation-en_GB
Get:12 http://security.ubuntu.com precise-security/restricted i386 Packages [8,939 B]
Get:13 http://security.ubuntu.com precise-security/universe i386 Packages [114 kB]
Get:14 http://security.ubuntu.com precise-security/multiverse i386 Packages [2,651 B]
Hit http://security.ubuntu.com precise-security/main TranslationIndex
Hit http://security.ubuntu.com precise-security/multiverse TranslationIndex
Hit http://security.ubuntu.com precise-security/restricted TranslationIndex
Hit http://security.ubuntu.com precise-security/universe TranslationIndex
Hit http://security.ubuntu.com precise-security/main Translation-en
Hit http://security.ubuntu.com precise-security/multiverse Translation-en
Hit http://security.ubuntu.com precise-security/restricted Translation-en
Hit http://security.ubuntu.com precise-security/universe Translation-en
Get:15 http://archive.ubuntu.com precise-updates/restricted i386 Packages [13.6 kB]
Get:16 http://archive.ubuntu.com precise-updates/universe i386 Packages [262 kB]
Get:17 http://archive.ubuntu.com precise-updates/multiverse i386 Packages [16.6 kB]
Hit http://archive.ubuntu.com precise-updates/main TranslationIndex
Hit http://archive.ubuntu.com precise-updates/multiverse TranslationIndex
Hit http://archive.ubuntu.com precise-updates/restricted TranslationIndex
Hit http://archive.ubuntu.com precise-updates/universe TranslationIndex
Hit http://archive.ubuntu.com precise/main Translation-en_GB
Hit http://archive.ubuntu.com precise/multiverse Translation-en_GB
Hit http://archive.ubuntu.com precise/restricted Translation-en_GB
Hit http://archive.ubuntu.com precise/universe Translation-en_GB
Hit http://archive.ubuntu.com precise-updates/main Translation-en_GB
Hit http://archive.ubuntu.com precise-updates/multiverse Translation-en_GB
Hit http://archive.ubuntu.com precise-updates/restricted Translation-en_GB
Hit http://archive.ubuntu.com precise-updates/universe Translation-en_GB
Err http://packages.medibuntu.org precise Release.gpg
  Something wicked happened resolving 'packages.medibuntu.org:http' (-5 - No address associated with hostname)
Ign http://packages.medibuntu.org precise Release
Ign http://packages.medibuntu.org precise/free i386 Packages/DiffIndex
Ign http://packages.medibuntu.org precise/non-free i386 Packages/DiffIndex
Ign http://packages.medibuntu.org precise/free TranslationIndex
Ign http://packages.medibuntu.org precise/non-free TranslationIndex
100% [Connecting to packages.medibuntu.org]
« Reply #34 on: February 26, 2015, 10:06:32 pm »
can you post the contents of this file:
gedit /etc/apt/sources.list
Offline chemicalfan
« Reply #35 on: February 27, 2015, 09:46:21 am »
You should enable the "backports" repo to ensure you get the latest packages (such as firefox). If you open Update Manager, the click on the View menu, then select Software Sources. In the window that pops up, check the "backports" box (in the middle of the window). Next, go to either the PPA or Additional Repositories button (not sure which), and look for the line that talks about Medibuntu, and uncheck it, then click OK, then click on the Refresh button to update all sources. That should give you some more package updates, and should clear up the issue with the medibuntu repositories being offline (they don't exist anymore).
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #36 on: April 19, 2015, 04:42:56 pm »
Thanks guys. Sorry been busy lately. On the laptop right now- will do that on netbook later/tomorrow.
Offline Melissa
  • Vintage geek
  • Gender: Female
« Reply #37 on: June 16, 2015, 10:42:03 pm »
I forgot all about that guys sorry- had  loads to do lately and not been using the netbook. I will do all that by this weekend and get back to you.
