Author Topic: anti Linux WiFi  (Read 7355 times)
Offline nek
anti Linux WiFi
« on: February 22, 2015, 05:19:17 pm »
Has anyone had problems connecting to public wifi from linux and yet none when connecting the same laptop from windows?
Re: anti Linux WiFi
« Reply #1 on: February 22, 2015, 05:23:44 pm »
Nope, but then I don't use Windows ;)
I *can* say I've never had problems connecting to any wireless network though.
What distro/versin/architecture and wireless adapter and driver are you using ?
Offline nek
which...
« Reply #2 on: February 22, 2015, 05:32:45 pm »
Only used windows to test a crazy idea...
Doesn't work with mageia 2 and knoppix 6. Works with window 7 (yuck!)
With linux it stopped working after they 'upgraded' the wifi.
Something funny going on.
Re: anti Linux WiFi
« Reply #3 on: February 22, 2015, 05:38:15 pm »
Does
iwlist scan
run as root show the wireless network ?
or is it purely a "connection" issue ?
Offline nek
Re: anti Linux WiFi
« Reply #4 on: February 22, 2015, 05:47:23 pm »
The very first time it seem to work, connection no problem, loaded bbc sport,  then stopped working after a few pages.
The next few times one or two pages and then no more connection.
Now not even one page.
Head scratching.
Offline chemicalfan
Re: anti Linux WiFi
« Reply #5 on: February 23, 2015, 01:00:43 pm »
What distro are you running? I used to have this problem on an old version of Ubuntu on my AAO (crappy internet Atheros adaptor)
Offline nek
Re: anti Linux WiFi
« Reply #6 on: February 23, 2015, 04:08:13 pm »
Mageia 2 and and sometimes knoppix 6 (live). No problems with any old internet cafe. Just this recently upgraded public wifi.
I'd just got my new usb belkin with realtek chipset working fine with both linuxes and the old wifi network, about ten days before they 'upgraded'.
Re: anti Linux WiFi
« Reply #7 on: February 23, 2015, 06:41:20 pm »
Have you tried (at least temporarily) disabling IPv6 when connecting to that access point ?
http://ask.xmodulo.com/disable-ipv6-linux.html
Still might be handy to know what
iwlist scan
says for that access point
along with the output from:
ifconfig
iwconfig
whilst connected
« Last Edit: February 23, 2015, 07:03:54 pm by Mark Greaves (PCNetSpec) »
Offline chemicalfan
Re: anti Linux WiFi
« Reply #8 on: February 24, 2015, 09:52:56 am »
Pretty sure Mageia 2 isn't supported anymore (IIRC, releases have 18 months of support). Any reason you're sticking with an older version? Bit of a security risk, especially if you're using public wifi!
Knoppix 6 is old too, we're up to 7.4 now!
Offline nek
Re: anti Linux WiFi
« Reply #9 on: February 27, 2015, 07:13:06 pm »
iwlist scan
ifconfig
iwconfig
whilst connected
Tried those many times, nothing stands out, no encrpytion, usual stuff.
Except... sometimes doesn't see the network at all, yet network is there.
To make it more puzzling, tried same network at different location (miles distant), mageia still doesn't work at all but the knoppix did, two days in a row. Day after tried both at original location, no joy.
Think it must be something to do with providers hardware/software setup. Or is a little green man pressing a button...
Re: anti Linux WiFi
« Reply #10 on: February 27, 2015, 10:18:19 pm »
Can't help if you're not going to provide the output asked for ;)
As well as the output asked for above, can you also post the output from:
sudo lshw -C network
