Author Topic: WiFi does not connect (SOLVED)  (Read 18555 times)
Re: WiFi does not connect
« Reply #15 on: March 12, 2015, 09:27:00 pm »
Fingers crossed :)
Offline donwatson
  • Getting older
« Reply #16 on: March 16, 2015, 11:47:26 am »
Another successful login this morning  :D
I will mark this as solved
take care
Don W
PS Hope your back is better
Novatech build
External 2TiB HD
Re: WiFi does not connect (Solved)
« Reply #17 on: March 16, 2015, 01:43:34 pm »
Cool .. thanks for marking the topic solved :)
Offline donwatson
  • Getting older
« Reply #18 on: March 20, 2015, 07:56:09 pm »
Sorry about this Mark, but it is playing up again.
Switched on this evening and there is no internet connection.
I have run the commands and got the following result.
don@ldwatson ~ $ ping -c 5 192.168.0.1
connect: Network is unreachable
don@ldwatson ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:90:f5:f3:67:bf
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:408 errors:0 dropped:0 overruns:0 frame:0
          TX packets:408 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:32384 (32.3 KB)  TX bytes:32384 (32.3 KB)
wlan0     Link encap:Ethernet  HWaddr a4:db:30:c7:44:e8
don@ldwatson ~ $ iwconfig
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
don@ldwatson ~ $ sudo iwlist scan
sudo: unable to resolve host ldwatson
[sudo] password for don:
wlan0     Scan completed :
          Cell 01 - Address: 7C:4C:A5:DD:2C:7D
                    Channel:6
                    Quality=16/70  Signal level=-94 dBm
                    Encryption key:on
                    ESSID:"SKY9380E"
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=00000001320c028c
                    Extra: Last beacon: 4ms ago
                    IE: Unknown: 0008534B593933383045
                    IE: Unknown: 030106
                    IE: Unknown: 2A0104
                    IE: Unknown: 2F0104
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 32040C121860
                    IE: Unknown: 0B050200300000
                    IE: Unknown: 2D1AAC181BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1606081500000000000000000000000000000000000000
                    IE: Unknown: 7F03000008
                    IE: Unknown: DD800050F204104A0001101044000102103B000103104700103709C9AA4B662229C82524204BF8879B1021000842726F6164636F6D1023000842726F6164636F6D1024000631323334353610420004313233341054000800060050F20400011011000A42726F6164636F6D415010080002200C103C0001011049000600372A000120
                    IE: Unknown: DD090010180202000C0000
          Cell 02 - Address: 00:00:00:00:00:00
                    Channel:1
                    Quality=44/70  Signal level=-66 dBm
                    Encryption key:on
                    ESSID:"VM185937-2G"
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Mode:Master
                    Extra:tsf=0000012030f17745
                    IE: Unknown: 000B564D3138353933372D3247
                    IE: Unknown: 030101
                    IE: Unknown: 0706474220010D14
                    IE: Unknown: 2A0104
                    IE: Unknown: 32043048606C
                    IE: Unknown: 2D1AAD011BFFFF0000000000000000000000000000000406E6E70D00
                    IE: Unknown: 331AAD011BFFFF0000000000000000000000000000000406E6E70D00
                    IE: Unknown: 3D1601001100000000000000000000000000000000000000
                    IE: Unknown: 341601001100000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                    IE: Unknown: DD180050F2020101830003A4000027A4000042435E0062322F00
                        Group Cipher : TKIP
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD8A0050F204104A00011010440001021057000101103B000103104700109D1CC8C68D6A5315ACFC727103E2758A102100074E65746765617210230007564D444734383510240007564D44473438351042000D334257343432575831364442351054000800060050F204000110110007564D444734383510080002210C103C0001011049000600372A000120
          Cell 03 - Address: 20:0C:C8:7D:08:18
                    Channel:1
                    Quality=40/70  Signal level=-70 dBm
                    Encryption key:on
                    ESSID:"VM185937-2G"
                    Mode:Master
                    Extra:tsf=0000012030f27181
                    Extra: Last beacon: 768ms ago
                    IE: Unknown: 030101
                    IE: Unknown: 050400010000
                    IE: Unknown: 2A0104
                    IE: Unknown: 7F0101
                        Group Cipher : TKIP
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD220050F204104A00011010440001021057000101103C0001011049000600372A000120
don@ldwatson ~ $ rfkill list
0: hci0: Bluetooth
   Soft blocked: no
   Hard blocked: no
1: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
don@ldwatson ~ $ sudo lshw -C network
  *-network
       product: RTL8723AE PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 00
       serial: a4:db:30:c7:44:e8
       width: 64 bits
       configuration: broadcast=yes driver=rtl8723ae driverversion=3.13.0-46-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bgn
       resources: irq:18 ioport:e000(size=256) memory:f7d00000-f7d03fff
  *-network
       physical id: 0.2
       bus info: pci@0000:03:00.2
       logical name: eth0
       version: 06
       serial: 00:90:f5:f3:67:bf
       capacity: 100Mbit/s
       width: 64 bits
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8402-1_0.0.1 10/26/11 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:41 ioport:d000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
don@ldwatson ~ $
Novatech build
External 2TiB HD
Offline donwatson
  • Getting older
Re: WiFi does not connect (Solved)(updated)
« Reply #19 on: March 21, 2015, 09:17:24 am »
It is now working again this morning ??
Novatech build
External 2TiB HD
« Reply #20 on: March 21, 2015, 12:38:21 pm »
Are you "SKY9380E" or "VM185937-2G" .. and what's the make model of your router ?
Offline donwatson
  • Getting older
« Reply #21 on: March 22, 2015, 03:33:01 pm »
I have a Virgin Media Super Hub 2 (VMDG485) wireless router.
Underneath it says
2.4GHz SSID    VM185937-2G
5.0GHz SSID    VM185937-5G
Web Address : http://192.168.0.1
Is this info. any good
« Last Edit: March 22, 2015, 05:22:28 pm by Mark Greaves (PCNetSpec) »
Novatech build
External 2TiB HD
« Reply #22 on: March 22, 2015, 05:42:21 pm »
Your router is showing up twice .. have you got any guest networks configured ?
(Click image for enlarged view)
Pic Source:
http://m.setuprouter.com/router/virgin-media/netgear-vmdg485/wifi-setup-34039-large.htm
Offline donwatson
  • Getting older
« Reply #23 on: March 22, 2015, 08:13:51 pm »
I did not set up any guest accounts.
I clicked on the link and just get the same picture you have posted ?
What do O do now ?
Novatech build
External 2TiB HD
« Reply #24 on: March 22, 2015, 08:20:23 pm »
enter your routers web interface
http://192.168.0.1
aand see if you can find the page like the one pictured and see if it contains a guest network that's already configured ?
Offline donwatson
  • Getting older
« Reply #25 on: March 22, 2015, 09:02:39 pm »
I found the page in the advanced setup.
It gives a list of pages from 1st basic page through 1st guest page,
The basic page has the 'Enabled' box ticked but there are no boxes ticked on the 'Guest' pages.
Novatech build
External 2TiB HD
« Reply #26 on: March 22, 2015, 09:17:46 pm »
Just to be sure this isn't a one off hiccup, can you turn off your router and Linux PC .. then turn on your router, wait a minute or two so it's fully initialised, then turn on your Linux PC.
Then send the output from:
sudo iwlist scan
Offline donwatson
  • Getting older
« Reply #27 on: March 22, 2015, 10:02:01 pm »
It shows this
          Cell 01 - Address: 20:0C:C8:7D:08:18
                    Channel:1
                    Quality=70/70  Signal level=-28 dBm
                    Encryption key:on
                    ESSID:"VM185937-2G"
                    Mode:Master
                    Extra:tsf=000000000e5f366d
                    Extra: Last beacon: 60ms ago
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 3D1601001500000000000000000000000000000000000000
                    IE: Unknown: 341601001500000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                        Group Cipher : TKIP
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 02 - Address: 7C:4C:A5:DD:2C:7D
                    Channel:6
                    Quality=14/70  Signal level=-96 dBm
                    Encryption key:on
                    ESSID:"SKY9380E"
                    Mode:Master
                    Extra:tsf=0000000d149381c1
                    IE: Unknown: 030106
                    IE: Unknown: 2A0104
                    IE: Unknown: 2F0104
                        Group Cipher : CCMP
                    IE: Unknown: 0B0503001A0000
                    IE: Unknown: DD090010180203000C0000
          Cell 03 - Address: 3E:F6:85:B7:74:A2
                    Channel:6
                    Encryption key:off
                    ESSID:"BroadbandHamnet-20-v3"
                    Mode:Ad-Hoc
                    Extra:tsf=000000db8bb75a90
                    Extra: Last beacon: 2652ms ago
                    IE: Unknown: 001542726F616462616E6448616D6E65742D32302D7633
                    IE: Unknown: 010882040B160C121824
                    IE: Unknown: 030106
                    IE: Unknown: 06020000
                    IE: Unknown: DD070050F202000100
don@ldwatson ~ $
Novatech build
External 2TiB HD
« Reply #28 on: March 22, 2015, 11:12:19 pm »
That's better, it's only showing up once now....
On this page in your router:
http://setuprouter.com/router/virgin-media/netgear-vmdg485/wifi-setup-34039-large.htm
what is the "security mode" set to ?
WPA auto or WPA-PSK(TKIP)
and what happens if you set it to WPA2-PSK(AES) .. be aware you may need to reboot any PC's that connect wirelessly to pick up the change.
and remember, if you can't access the router via wireless at all .. you can always use an ethernet cable to change the setting back.
« Last Edit: March 22, 2015, 11:20:24 pm by Mark Greaves (PCNetSpec) »
Offline donwatson
  • Getting older
« Reply #29 on: March 23, 2015, 10:07:15 am »
The setting is WPA Auto
When I switched on this morning I got an indication that my wireless connection was @ 96% (it is down to 88% at the moment), I usually only get a signal strength of around 48% to 56% does this affect anything ?.
The gas board installed a new central heating unit recently and it is connected wirelessly. Will changing the settings to WPA2-PSK(AES) upset the settings for the heating ?
Novatech build
External 2TiB HD
