Website
Home
Forum
Help
Search
Calendar
Media
Blog
Login
Register
Support
Android devices
Is there an Easy way to Root an Android tablet using Linux?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is there an Easy way to Root an Android tablet using Linux? (Read 5748 times)
Tramlink
Hero Member
Gender:
Is the mist clearing
on:
March 08, 2015, 11:24:40 am »
Dose any one know if there is an Easy way to Root an Android tablet using Linux?
Logged
Mark Greaves (PCNetSpec)
Hero Member
Gender:
"-rw-rw-rw-" .. The Number Of The Beast
Re: Is there an Easy way to Root an Android tablet using Linux?
Reply #1 on:
March 08, 2015, 02:21:58 pm »
Which make/model of Android tablet ?
Logged
WARNING
: You are logged into reality as 'root'
Reply #1 on:
Tramlink
Hero Member
Gender:
Reply #2 on:
March 08, 2015, 03:00:19 pm »
Make novotech model- PWS700EJ
Logged
Hero Member
Gender:
Reply #3 on:
March 08, 2015, 04:53:17 pm »
See this page:
http://hexamob.com/news/android-rooting-methods-for-actions-pws700ej-with-android-version-4-0-ice-cream/
Now if you check out the link to the Bin4ry Root Method:
http://hexamob.com/how-to-root/bin4ry/
it suggests it can be done from Linux
I must add, I've not tested these instructions (and I'm no Android device rooting guru) .. so on your head be it.
Logged
WARNING
Tramlink
Hero Member
Gender:
Reply #4 on:
March 08, 2015, 10:17:59 pm »
OK will check it out...... thanks.
Logged
Reply #4 on:
Print
Pages: [
1
Go Up
« previous
next »
Support
Android devices
