Author Topic: Is kernel upgrade possible ? (Solved again)  (Read 39085 times)
Re: Is kernel upgrade possible ? (Solved)
« Reply #30 on: April 27, 2015, 12:07:02 am »
If it used to work, but now doesn't .. I'd assume one of 3 things
a) a driver update has broken things  <-- we've messed with this, so seems unlikely
b) interference from another wireless source  <-- unlikely if other PC's aren't affected
c) a hardware issue  <-- unlikely to be the router if it previously worked and continues to work on other PC's . so we're left with a failing wireless adapter in the PC
(it would be nice to prove this theory with a USB wireless card if you have one ?)
Offline donwatson
  • Getting older
« Reply #31 on: April 27, 2015, 10:31:11 am »
Thanks Mark,
It looks as if c) is the way to go.
Where can I purchase a USB wireless card ? Novatech ? ebay ?
I will have a look around meantime and see what I can find.
take care
Don W
Novatech build
External 2TiB HD
Offline chemicalfan
Offline donwatson
  • Getting older
« Reply #33 on: April 27, 2015, 06:36:56 pm »
Thanks chemicalfan,
I had a look this afternoon and saw that one. I shall order it now. :)
take care
Don W
Ordered  ;)
« Last Edit: April 27, 2015, 06:43:09 pm by donwatson »
Novatech build
External 2TiB HD
Offline donwatson
  • Getting older
« Reply #34 on: April 29, 2015, 12:52:39 pm »
The USB adaptor arrived this morning, but the software disc is written in MS Windows (all 8 versions)
I found the number for  TP-Link but I can't speak to anyone as the lines are busy.
I can speak to someone (after a while) on the 0845 number but I am not willing to pay for that.
Any ideas how to get Linux drivers ?
Also I don't know where to disable the internal wireless card, any help please
take care
Don W
« Last Edit: April 29, 2015, 01:22:04 pm by donwatson »
Novatech build
External 2TiB HD
Offline chemicalfan
« Reply #35 on: April 29, 2015, 02:06:24 pm »
Have you tried just plugging it in (maybe rebooting)? Drivers hopefully should be in the Linux kernel already
Offline donwatson
  • Getting older
« Reply #36 on: April 29, 2015, 03:42:27 pm »
Hi chemicalfan,
I have done a reboot and the internal led on the adapter flashes.
I also have a led light above the keyboard that indicates that the built in card is working.
Should I disconnect the internal card ? and how ?
take care
Don W
PS I think you're right and the adapter is working.
Novatech build
External 2TiB HD
« Reply #37 on: April 30, 2015, 01:57:35 am »
Plug the adapter in and post the output from:
lsusb
sudo lshw -C network
Offline chemicalfan
« Reply #38 on: April 30, 2015, 08:50:24 am »
You should be able to use the new one with the old one still enabled (it'll be wlan1 instead of wlan0). If you really want to disable, you can add the driver to the blacklist so it doesn't load
Offline donwatson
  • Getting older
« Reply #39 on: April 30, 2015, 10:37:41 am »
don@ldwatson ~ $ lsusb
Bus 002 Device 005: ID 5986:0401 Acer, Inc
Bus 002 Device 004: ID 0bda:8723 Realtek Semiconductor Corp.
Bus 002 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 0bda:8179 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
don@ldwatson ~ $ sudo lshw -C network
[sudo] password for don:
  *-network
       product: RTL8723AE PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 00
       serial: a4:db:30:c7:44:e8
       width: 64 bits
       configuration: broadcast=yes driver=rtl8723ae driverversion=3.16.0-34-generic firmware=N/A ip=192.168.0.2 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:18 ioport:e000(size=256) memory:f7d00000-f7d03fff
  *-network
       physical id: 0.2
       bus info: pci@0000:03:00.2
       logical name: eth0
       version: 06
       serial: 00:90:f5:f3:67:bf
       capacity: 100Mbit/s
       width: 64 bits
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8402-1_0.0.1 10/26/11 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:41 ioport:d000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
  *-network
       physical id: 2
       bus info: usb@1:1.2
       logical name: wlan1
       serial: 30:b5:c2:10:a8:d3
       configuration: broadcast=yes driver=r8188eu multicast=yes wireless=unassociated
 :D thats all folks  :D
Novatech build
External 2TiB HD
« Reply #40 on: May 01, 2015, 01:33:23 pm »
So is there a problem now ?
No need to remove the onboard card, but you can usually disable it either in the BIOS of via a keyboard combo, or via a physical switch somewhere on the laptop
Offline donwatson
  • Getting older
« Reply #41 on: May 02, 2015, 04:40:47 pm »
Thanks Mark,
No problem as far as I can see. I have had a couple of days away and haven't logged in.
I will see what happens this week with it, it has worked ok during an intense online session and didn't drop out at all.
I will mark this solved if that is ok.
take care
Don W
Novatech build
External 2TiB HD
Re: Is kernel upgrade possible ? (Solved again)
« Reply #42 on: May 02, 2015, 10:04:41 pm »
Your topic Don so mark it however you like .. happy to hear the problem is solved :)
Can I ask you to confirm this is the one you bought:
http://www.amazon.co.uk/computers/dp/B008IFXQFU
and that it worked "out of the box"  ?
This info may help someone else in the future .. thanks.
« Last Edit: May 02, 2015, 10:13:37 pm by Mark Greaves (PCNetSpec) »
Offline donwatson
  • Getting older
« Reply #43 on: May 03, 2015, 01:51:32 pm »
Yes Mark,
That is the one I bought.  :D I just plugged it in to a USB port and it works. There is a Windows installation disk included that I didn't need.
I have just met another connection problem after logging in this morning.
I am writing this on the Windows machine as the connection on the Linux machine was 2% when I started and it was taking an age to connect to a site.
I never have a problem with this Windows machine, it never leaves the room here and sits next to the router. It has been plugged in overnight and shows 100% charge, as I am entering this the computer still shows fully charged.
The Linux machine is the one I take downstairs and I am having problems with. It too was plugged in overnight and the LED on the front indicated the battery was fully charged. I took it downstairs, plugged in to the mains and switched on. After logging on the battery condition read 86% and charging and the internet connection came on at 2%. I tried to log on here but after a couple of minutes I still didn't have a connection. I shut down and came back upstairs with it and logged on here to write this.
I have now switched the Linux computer on and logged in. It shows the battery adapter is online and charging (86%).
The internet bar shows nothing and when I hover the mouse over it it says
WiFi network connection 'VM 185937-2G 1' active: VM 185937-2G(3%)
The LED above the keyboard showing the internet connection is lit and the TP-LINK adaptor is flashing.
I can clean the computer out and start again as the only thing I needed was the photographs/videos from my grand-daughters wedding and that is safely done and dusted. I could in fact wait until June and put on Peppermint 6 if you wish (I could put it on now in fact as a sort of idiots try out. If I can work it anyone can)  ;)
EDIT I have started up the Linux machine again and logged in. The status bar showed  'VM 185937-2G 1' active: VM 185937-2G(2%). I left click on the bar and it shows the connections. The top one WiFi Networks (Realtek 82.11n NIC), I clicked on disconnect and the status bar jumped to 92%. Working fine now  ;)
« Last Edit: May 03, 2015, 02:56:19 pm by donwatson »
Novatech build
External 2TiB HD
« Reply #44 on: May 03, 2015, 10:00:50 pm »
Can you not physically turn off the internal realtek one with a hardware switch or key combo ?
What's the output from:
