Author Topic: Help  (Read 12316 times)
Offline jamebowz
Help
« on: May 18, 2015, 12:07:42 am »
Am new to Linux, and It won't let me update help please
Re: Help
« Reply #1 on: May 18, 2015, 12:20:22 am »
Which Linux distribution are we talking about ? .. Ubuntu, Mint, etc.
And what do you mean by "it won't let you update" ?
Re: Help
Offline jamebowz
Re: Help
« Reply #2 on: May 18, 2015, 06:59:23 am »
Am on Ubuntu, and it says GPG error when updating
Re: Help
« Reply #3 on: May 18, 2015, 09:42:23 am »
Open a terminal (Ctrl+Alt+T) and run the following command:
enter your password when prompted, then hit enter.
A long list of repositories will scroll past .. and at the end will be any errors/warnings.
Copy the bottom say 20 lines that contain any errors, and post them back here.
Remember you can use copy/paste to and from the terminal
when  entering your password into the terminal nothing will be echoed to screen (not even ******) but iit IS going in, so just type it and hit enter.
Offline jamebowz
Re: Help
« Reply #4 on: May 18, 2015, 06:26:48 pm »
I got GPG error
Re: Help
Re: Help
« Reply #5 on: May 18, 2015, 08:37:39 pm »
I repeat .. copy and paste the EXACT error from the above command.
Offline jamebowz
Re: Help
« Reply #6 on: May 19, 2015, 10:46:17 pm »
Unable to locate the package
Re: Help
« Reply #7 on: May 19, 2015, 11:11:02 pm »
You're not making this easy ;)
Open a terminal and run this command:
then post back here the last 20 lines that are returned in the terminal
If you don't do this I cannot help you as I don't know what the problem is.
If you don't understand what I'm asking you to do .. say which part you don't understand, and I'll try to clarify.
Offline jamebowz
Re: Help
« Reply #8 on: May 20, 2015, 01:17:32 am »
How am I ment to copy an past on my phone to here to show u
Re: Help
Emegra
  • Guest
Re: Help
« Reply #9 on: May 20, 2015, 05:53:16 am »
Hi jamebowz
You won't be able to do this on your phone, you'll have to do this on the PC that's giving you the problem
is there any reason you can't use the PC ?
Offline jamebowz
Re: Help
« Reply #10 on: May 20, 2015, 08:30:01 am »
I can do Sudo apt-get update,    says unable to locate package
Offline chemicalfan
Re: Help
« Reply #11 on: May 20, 2015, 08:40:13 am »
Is the computer connected to the internet?
Emegra
  • Guest
Re: Help
« Reply #12 on: May 20, 2015, 10:02:44 am »
I'm thinking the same as chemicalfan here
That's probably because your not connected to the internet
can you open any webpages on the internet ?
How are you connected to the internet ethernet or wireless ?
Offline jamebowz
Re: Help
« Reply #13 on: May 20, 2015, 04:20:22 pm »
Yes I have the Internet on
Offline chemicalfan
Re: Help
« Reply #14 on: May 20, 2015, 04:41:24 pm »
Interesting...
Please can you post the output from:
cat /etc/apt/sources.list
