Author Topic: Help  (Read 10793 times)
Offline jamebowz
Re: Help
« Reply #15 on: May 20, 2015, 04:46:28 pm »
Ok I done that
Offline jamebowz
Re: Help
« Reply #16 on: May 20, 2015, 04:47:01 pm »
Emegra
  • Guest
Re: Help
« Reply #17 on: May 20, 2015, 05:05:51 pm »
Jamie that picture is incomplete and doesn't tell us much if anything
is there any particular reason you're using your phone to communicate with this site if so can you explain please.
Also can you please answer the questions that we ask you
Are you able to open any web pages ? I want to know this to be certain you have an active connection to the internet
If so it would be helpful if you logged into this site on the PC you're having trouble with so you can send us the relevant data we need to help you directly.
You cannot do this on your phone
PS
Please don't post any photos unless someone specifically asks for it thanks :)
« Last Edit: May 20, 2015, 05:09:00 pm by Emegra »
Offline jamebowz
Re: Help
« Reply #18 on: May 20, 2015, 07:12:39 pm »
Oh ok am very very sorry, and I didn't know u can login at pc on this sorry, and yes I can open Web pages ill send u the error I will get ok
Offline jamebowz
Re: Help
« Reply #19 on: May 20, 2015, 07:30:55 pm »
It's not letting me login to this site on my pc
Re: Help
« Reply #20 on: May 20, 2015, 07:34:37 pm »
It should do...
So what happens when you try to log on with
username = jamebowz
password = <whatever password you used>
Offline jamebowz
Re: Help
« Reply #21 on: May 20, 2015, 07:35:27 pm »
Says wrong email or password, then i Tryed forgot password an it says my username and email don't exist
Emegra
  • Guest
Re: Help
« Reply #22 on: May 20, 2015, 07:39:47 pm »
you should be able to log in using the same username & password as you used on your phone
also can you make sure you don't have Caps Lock on ?
Re: Help
« Reply #23 on: May 20, 2015, 07:42:00 pm »
I just tried entering the password reminder with your username (jamebowz) and had no problem
an email has been sent to your gmail account .. click the link in that email to reset your password.
Offline jamebowz
Re: Help
« Reply #24 on: May 20, 2015, 08:16:08 pm »
Ok thanks
Offline jamebowz
Re: Help
« Reply #25 on: May 20, 2015, 08:19:37 pm »
ok am in useing pc now
Emegra
  • Guest
Re: Help
« Reply #26 on: May 20, 2015, 08:29:13 pm »
OK please follow these instructions Mark posted earlier
Open a terminal (Ctrl+Alt+T) and run the following command:
enter your password when prompted, then hit enter.
A long list of repositories will scroll past .. and at the end will be any errors/warnings.
Copy the bottom say 20 lines that contain any errors, and post them back here.
Remember you can use copy/paste to and from the terminal
when  entering your password into the terminal nothing will be echoed to screen (not even ******) but it IS going in, so just type it and hit enter.
Offline jamebowz
Re: Help
« Reply #27 on: May 20, 2015, 09:35:20 pm »
Reading package lists... Done
Building dependency tree
E: Unable to locate package update
Offline jamebowz
Re: Help
« Reply #28 on: May 20, 2015, 09:38:55 pm »
its when i do sudo apt-get install update        i get that
Re: Help
« Reply #29 on: May 20, 2015, 09:50:29 pm »
You REALLY need to take more care when entering commands.
we want you to run:
It may help if you copy the command and paste it into your terminal ;)
« Last Edit: May 20, 2015, 09:52:54 pm by Mark Greaves (PCNetSpec) »
