Author Topic: Adblock V Adblock+ (Solved)  (Read 2097 times)
Offline donwatson
  • Getting older
« on: June 18, 2015, 03:52:27 pm »
Can anyone recommend which of the 2 Ad blockers I should install ?
My surfing is taking longer and longer every day.
Mark,
Can you delete the post in General Discussions
« Last Edit: June 18, 2015, 07:59:58 pm by donwatson »
Novatech build
External 2TiB HD
Re: Adblock V Adblock+
« Reply #1 on: June 18, 2015, 05:30:54 pm »
Personally I use Adblock+ (ABP) in both Firefox and Chrome.
Offline donwatson
  • Getting older
« Reply #2 on: June 18, 2015, 07:59:37 pm »
Thanks Mark,
I have added Adblock+ to both browsers
Novatech build
External 2TiB HD
Re: Adblock V Adblock+ (Solved)
« Reply #3 on: June 18, 2015, 08:49:57 pm »
No problem :)
Offline Rich J
  • Still a Linux Luvvie!
« Reply #4 on: June 19, 2015, 08:05:48 am »
Mark,
FYI
Adblock Edge works well in Firefox  ;)
Rich
Offline donwatson
  • Getting older
« Reply #5 on: June 19, 2015, 10:36:24 am »
Thank Rich  :D
Novatech build
External 2TiB HD
