Author Topic: Just installing Lucid Puppy - wifi connection problem  (Read 1157 times)
Offline alpineswift
« on: July 06, 2015, 12:24:49 pm »
I have a Sky broadband wireless router. I am just installing Lucid Puppy. I am asked to configure network settings. Firstly can I select both ethernet and wireless? It only gives me options for one or other or MS Windows. Next, when I click for wifi and select WPA and enter a long encyption password it is unable to connect to the device ans asks if I would like to try again. Please advise.
Offline chemicalfan
Re: Just installing Lucid Puppy - wifi connection problem
« Reply #1 on: July 07, 2015, 02:09:35 pm »
If you're physically connected to the router via cable, you want Ethernet - otherwise, wireless.
Can you follow the instructions in this post (http://linuxforums.org.uk/index.php?topic=12487.msg102050#msg102050) and post the results here?
