Author Topic: Returns to options of Create a document & Create a folder  (Read 2793 times)
Offline rami
« on: December 17, 2015, 11:57:15 am »
in one windows by right click in the mouse.
in linux lubuntu 15.10.
How exactly do that?
« Last Edit: December 17, 2015, 12:05:58 pm by rami »
Re: Returns to options of Create a document & Create a folder
« Reply #1 on: December 17, 2015, 01:55:22 pm »
So you're saying if you right-click on an empty space in a folder you don't get the "Create New Folder" and "Create New Document" options ?
Have you ever had these options ?
What happens if you right-click on an empty space on the desktop ?
Offline rami
« Reply #2 on: December 17, 2015, 11:05:24 pm »
"Have you ever had these options ?"
yes
"What happens if you right-click on an empty space on the desktop ?"
I get another menu of
Shortcuts
Applications
system
« Reply #3 on: December 19, 2015, 05:33:03 pm »
Run:
leafpad ~/.config/pcmanfm/lubuntu/pcmanfm.conf
look for an entry:-
show_wm_menu=1
and change it to
show_wm_menu=0
SAVE the file .. then log off and on again (or reboot).
Another method...
open a terminal and run:
pcmanfm --desktop-pref
select the "Advanced" tab .. and untick "Show Menus"
« Last Edit: December 19, 2015, 05:37:10 pm by Mark Greaves (PCNetSpec) »
