Author Topic: Dual boot question  (Read 3121 times)
Offline Degsy
  • Sr. Member
Dual boot question
« on: December 23, 2015, 07:06:12 pm »
Hi,
My desktop has Ubuntu 14.04 with Peppermint 5 dual booted, the Peppermint has never really worked very well on it so I primarily used Ubuntu. Is it straightforward to replace 5 with Peppermint 6 on this installation.
I have downloaded the iso and burned to disk, it boots fine to a live session on my laptop so your advice would be really helpful.
Thanks,
Degsy.
Emegra
  • Guest
Re: Dual boot question
« Reply #1 on: December 24, 2015, 09:09:32 pm »
Hi Degsy
That should be fairly straightforward first identify the peppermint partition in gparted then delete that partition then install Peppermint 6 on the unallocated space, but as always backup any important files on your Ubuntu partition first
Good luck
Offline Degsy
  • Sr. Member
« Reply #2 on: December 25, 2015, 09:16:21 am »
Thank you, Graeme, will give that a go.
All the best for the festive season.
Degsy
