Author Topic: Novatech laptop Driver CD only for Windows. [SOLVED]  (Read 12896 times)
Offline ahead
  • Full Member
« on: December 31, 2015, 07:44:25 pm »
I have recently bought a Novatech laptop with no OS, I have installed Mint 17.3.
The driver installation disc is only supported by Windows. I have just spoken to Novatech I told them that the reason I bought this machine with no OS was to avoid using Windows. Their tech guy says that he doesn't know how to install compatible drivers to Clevo as used on this computer by way of Linux. At the moment most, not all, of the Fn buttons don't work i.e. the screen brightness and so called 'airplane' functions are inoperative.
The drivers he says are needed are Clevo model W950JN. Is there a way round this, do you think?
Advice as to how to get the function keys working would really be appreciated - Very Happy New Year and thanks!!
« Last Edit: January 13, 2016, 06:53:46 am by ahead »
Re: Novatech laptop Driver CD only for Windows.
« Reply #1 on: December 31, 2015, 07:58:58 pm »
Do any of the keys that need the Fn key pressing work ?
Is there anything in the BIOS about changing the function/action key mode ?
Offline ahead
  • Full Member
« Reply #2 on: January 01, 2016, 09:46:08 am »
Hello mark - I went into the BIOS at boot up looking for any mention of Fn/action and couldn't find anything, however, i must have pressed a key because the laptop won't boot up at all now. I just get a black screen saying:
'Reboot and select proper boot device or insert boot media in selected boot device and press a key'
When I get back into the BIOS, under Boot heading it says:
UEFI Boot [enabled] - (this is highlighted)
Network Stack [Disabled] - (this  is not highlighted)
What have I done?  :'(
« Reply #3 on: January 01, 2016, 12:27:53 pm »
Did you change the boot order, or disable booting from the hard drive ?
There's normally a setting in there somewhere called something like "reset BIOS defaults" or similar .. try that.
« Last Edit: January 01, 2016, 12:31:56 pm by Mark Greaves (PCNetSpec) »
Offline ahead
  • Full Member
« Reply #4 on: January 01, 2016, 05:14:07 pm »
I don't know what has happened, the black screen says reboot and select proper boot device but when I reboot and open the BIOS no option for booting is shown. The manual says that f7 is supposed to reset the BIOS defaults but nothing changes when I press it. I don't know what I pressed in error this morning but the machine is not responding to anything.
« Reply #5 on: January 01, 2016, 07:23:30 pm »
when you say there are NO boot options ? .. is there a key you can press to access the boot device selection screen ? .. and if you plug in a LiveUSB is that listed ?
Offline ahead
  • Full Member
« Reply #6 on: January 01, 2016, 07:47:17 pm »
No, there are no boot options. Under the Boot Heading it says: ;Boot Option Priorities' under that is 'UEFI Setting'.
Click on that I get: 'UEFI Enabled' under that 'Network Stack Disabled,
Live USB is not detected but I can boot of the installation CD.
I can't find a key to access boot device selection screen.
« Reply #7 on: January 02, 2016, 03:14:07 am »
The boot device selection screen is usually accessed via an "F" key immediately after the POST (power on self test) screen
On my HP, I turn ON the laptop, and immediately hit the F9 key .. I'm then presented with a list of boot options
But on your system, what is displayed if you use the arrow keys to highlight "Boot Option Priorities", then hit the enter key ?
« Last Edit: January 02, 2016, 03:21:17 am by Mark Greaves (PCNetSpec) »
Offline ahead
  • Full Member
« Reply #8 on: January 02, 2016, 08:32:48 am »
When I boot up the  only response I get is from F2 that takes me straight into the set up utility. When I scroll across to 'Boot' heading the page is headed with 'Boot Option Priorities' this is not highlighted and I can't click it. Under this is a highlighted '> UEFI Setting' if I hit return I get the option of 'Enabled' or Not Enabled' To the right there is a comment: 'If UEFI Boot set Enable, it's in UEFI Mode with secure boot.'
At no stage have I been presented with a list of boot options. The closest I get to that is the heading I described, above.
EDIT: On boot up with the Linux disc in the CD drive on pressing F2 and entering 'Setup' under the 'BOOT' heading I now get:
'Boot Option #1              [UEFI: TSSTcorp CDDVDW SU-")*HB]
There is no mention of a boot option from the HDD.
« Last Edit: January 02, 2016, 10:37:09 am by ahead »
Offline SeZo
« Reply #9 on: January 02, 2016, 11:12:52 am »
Is it possible that your machine came with the UEFI disabled (as it came with no OS) and you installed Linux using that mode?
If so then the grub was installed onto the MBR and in UEFI that is not read.
Try switching the UEFI boot to disabled.
As for boot options try all the F? keys (not just the F2, except F7) to see which takes you to the boot device selection.
Offline ahead
  • Full Member
« Reply #10 on: January 02, 2016, 01:31:47 pm »
Bingo! That works - UEFI now disabled - many thanks to you and Mark for all your input. I feel a bit awkward always asking for help, can I revert to the original problem of the non-functioning fn buttons?
I am unable to operate the screen brightness.  There is no sound,  though the fn button shows the volume control is working. Some others work some don't, I can itemise these if required.
Offline donwatson
  • Getting older
« Reply #11 on: January 02, 2016, 02:58:27 pm »
On my Novatech the Fn+F8 makes the screen darker, and Fn+F9 makes the screen brighter. These correspond with the symbols on the keys.
If I turn on the laptop and immediately hold the F12 key it shows the boot options.
This boot option only works ONCE. The next startup will revert to the BIOS setup.
Try looking up the threads I started as I am sure I have had all these problems before and got them sorted on this forum  ;)
PS I use the loudspeaker icon in the toolbar to raise/lower the volume
« Last Edit: January 02, 2016, 03:04:12 pm by donwatson »
Novatech build
External 2TiB HD
Offline ahead
  • Full Member
« Reply #12 on: January 02, 2016, 06:13:47 pm »
Thanks donwatson, I know what fn keys to use, it's just some of them don't work as the driver/setup disc supplied with the machine is not recognised by the OS I've installed. Ironically the sound volume fn key works but I have to install a sound driver.
Offline donwatson
  • Getting older
« Reply #13 on: January 02, 2016, 06:58:28 pm »
Yeah, I got 3 disks from Novatech 2 were for Windross (0ne of them for Win 8.1) and a Generic grivers disc for the Novatech computer.
With Marks help I have what I want running now.  ;D
Novatech build
External 2TiB HD
Offline ahead
  • Full Member
« Reply #14 on: January 02, 2016, 07:49:57 pm »
Getting back to your original question I found nothing in the BIOS about changing  the keys. In addition, as I said, there is no sound but the volume slider works via a fn key in the absence of sound.
