// Implements the joint conditional cummulative density functions for CP-nets// For node j in the lexicographic topological sort as defined by the dag code:// the table gives P( s, t | n, c, j ).// The number of rows in each table is the triangular number of min(c, j).#ifndef TABLES_H#define TABLES_H#include <random> // Mersenne Twister#include <chrono> // Used to initialize MTconst unsigned long int factorial[17] = {1, 1, 2, 6, 24, 120, 720, 5040, 40320, 362880, 3628800, 39916800, 479001600, 6227020800, 87178291200, 1307674368000, 20922789888000};void random_outcome_pair(uint64_t& o, uint64_t& oo, const unsigned int n, const unsigned int hd = 0);uint64_t random_k_subset(uint64_t T, const int N, const int n); class cpnet_ccdf{ public: cpnet_ccdf(const int length); cpnet_ccdf(cpnet_ccdf &obj); ~cpnet_ccdf(); int length() { return length_; }; void store(double p, const int s, const int t) { P[row_] = p; S[row_] = s; T[row_] = t; ++row_; }; void adjust_last() { P[length_ - 1] = 1.0; }; void print(); friend std::ostream& operator<<(std::ostream& os, const cpnet_ccdf& obj); friend std::istream& operator>>(std::istream& is, cpnet_ccdf& obj); // test void random_st(int& s, int& t); // static uint64_t random_cpt(const int k); // use rand_cpt in degen_multi.cc void random_node(const int n, int& q, uint64_t& U, uint64_t& A, unsigned long int** cpt, int j); // void random_node(const int n, int& q, uint64_t& U, uint64_t& A, uint64_t& cpt); // void random_toporder_node(const int n, const int j, int& q, uint64_t& U, uint64_t& A, uint64_t& cpt); private: int length_; int row_; double *P; int *S; int *T;};// all tables for all available values of (n, c, j, q) go hereclass cpnet_dist{ public: cpnet_dist(int maxn, int maxk); ~cpnet_dist(); cpnet_ccdf* dist(int n, int c, int j, int q) { return DIST[n][c][j][q]; }; void init(int n, int c, int j, int q, int len); void print(); void dump(); void dump(std::string fname); static void dagcode_to_dag(const unsigned int n, const uint64_t dc[], unsigned int ch_ix[], char ch[], unsigned long imp[]); static void dc_and_cpts_to_xml(const unsigned int n, const uint64_t dc[], unsigned long int** cpts, std::string working_directory, std::string fname); void free_cpt(const int n, long unsigned int** cpt); void generate_random_cpnet(const int n, const int c, uint64_t dc[], long unsigned int* cpt[]); // void random_toporder_cpnet(const int n, const int c, uint64_t dc[], uint64_t cpt[]); private: const int MAX_N; const int MAX_K; cpnet_ccdf***** DIST = nullptr;};bool degen_multi( unsigned int m, // number of inputs (indegree) unsigned int nAsst, // number of rows unsigned int* C ); // array of outputs defining functionvoid rand_cpt( unsigned long int cpt[], // Return value const int k, // Number of parents const long unsigned int size_cpt ); // Number of rows = d^kvoid print_cpt( const unsigned long int cpt[], // CPT to output const unsigned long int size_cpt ); // Number of rows = d^k#endif // TABLES_H
I get the source code on a personal page, do you need it?
Quote from: Azadeh on February 01, 2016, 04:44:34 pmI get the source code on a personal page, do you need it?It would probably help.
