Author Topic: Just reinstalled ubuntu. What next?  (Read 2203 times)
Offline Angus23
« on: March 02, 2016, 02:51:54 pm »
I,  just decided to reinstall my 'buntu. What steps should I follow now? Packages and so?
« Last Edit: March 02, 2016, 03:14:55 pm by Angus23 »
Re: Just reinstalled ubuntu. What next?
« Reply #1 on: March 02, 2016, 04:36:19 pm »
first thing you should do is a full system update .. you can do this via the updatemanager or by running the following commands in a terminal
sudo apt-get upgrade
sudo apt-get dist-upgrade
then when they've completed REBOOTING
Then I guess you should see if there are any proprietary drivers available by running Additional Drivers" from the menu.
Then install the restricted-extras packages to pull in the additional codecs etc:
sudo apt-get install ubuntu-restricted-extras ubuntu-restricted-addons
Beyond those I'm not quite sure what you're asking ?
Offline Angus23
« Reply #2 on: March 04, 2016, 02:23:20 am »
Thanks! That was amazing!
« Reply #3 on: March 04, 2016, 12:28:47 pm »
No problem :)
