Author Topic: Where do I find GEDIT? [SOLVED]  (Read 1722 times)
Offline ahead
  • Full Member
« on: March 05, 2016, 09:53:14 am »
I am using Mint 17.3 Rosa and want to use GEDIT. I have checked in the Software Manager and it says that it is installed but where do I find it? I have searched in all the likely places but I cant get it - nowhere to be found! Any ideas, please?
« Last Edit: March 05, 2016, 02:57:21 pm by ahead »
Offline donwatson
  • Getting older
Re: Where do I find GEDIT?
« Reply #1 on: March 05, 2016, 10:25:23 am »
Hi ahead,
I go to 'Menu' > 'Accessories' > 'Text Editor' and voila' there it is.
take care
Don W
BTW I use Peppermint 6
« Last Edit: March 05, 2016, 10:27:57 am by donwatson »
Novatech build
External 2TiB HD
Offline arochester
« Reply #2 on: March 05, 2016, 10:43:24 am »
Or, open a Terminal and input: gedit
To find the path to the executable use the command: which gedit
« Reply #3 on: March 05, 2016, 02:52:18 pm »
I'm not sure 100% sure Mint uses gedit as its default text editor any more, they may have changed to pluma or xedit .. you should be able to find out what text editor they're using by default by looking for "Text Editor" in your menus, then clicking "Help > About"
If when you run:
gedit
in a terminal it doesn't open .. install it with:
sudo apt-get install gedit
« Last Edit: March 05, 2016, 03:25:56 pm by Mark Greaves (PCNetSpec) »
Offline ahead
  • Full Member
Re: Where do I find GEDIT? [SOLVED]
« Reply #4 on: March 05, 2016, 02:56:17 pm »
Thank you, all sorted now with your help!
