Author Topic: [SOLVED] Unable to rip DVD's  (Read 5546 times)
Offline Sunderlandgreen
Re: [SOLVED] Unable to rip DVD's
« Reply #15 on: March 30, 2017, 09:32:27 am »
By installing libdvdcss on Handbrake, you can only remove the CSS encryption equipped on DVD disc, however, as for other DVD protection such as Sony ArccOS, UOPs, and Disney X-project DRM, you will fail to do the job even you have installed libdvdcss. You can have a try at MakeMKV or Free DVDAid which is clean and free and also can bypass all DVD copy protection and region.
Offline pooky2483
« Reply #16 on: April 06, 2017, 09:04:48 pm »
Thanks for that, I will have a look at them, I actually think I have MakeMKV installed on my Desktop Kubuntu.
