Author Topic: [SOLVED] Unable to print  (Read 2111 times)
Offline pooky2483
« on: April 28, 2016, 09:42:24 pm »
I have been having problems printing, my printer only prints half a page (top half) and then... nothing.
I am using an HP OfficeJetPro 6830.
I have uninstalled ALL printers (including FAX) via CUPS and then tried to reinstall them, printer and FAX, via CUPS but that does not solve the problem. I am also not able to complete the printer install using HPLIP 3.16.3 as I get a message telling me that I have not got libtools installed, yet, I HAVE.
I have HPLIP 3.15.9 installed.
« Last Edit: May 06, 2016, 10:21:48 pm by pooky2483 »
Re: Unable to print
« Reply #1 on: April 29, 2016, 01:49:24 am »
That's not the default hplip version for 14.04 .. have you installed it manually ? .. if so did the stock version not work or something ?
or are you no longer on 14.04 ?
Offline pooky2483
Re: Unable to print
« Reply #2 on: April 29, 2016, 04:31:03 pm »
Yes, I did a manual install of 3.15.9 (I think, what's the version that installs on fresh install?). And what do you mean by 'the stock version'?
I'm still using 14.04
« Last Edit: April 29, 2016, 04:34:22 pm by pooky2483 »
Offline pooky2483
Re: Unable to print
« Reply #3 on: April 29, 2016, 09:24:18 pm »
Just tried to re-install hplip 3.15.9 and I get the same error as when trying to install the latest version, libtool not installed...
It IS though!
Offline pooky2483
Re: Unable to print
« Reply #4 on: April 29, 2016, 10:14:18 pm »
Just thought I'd have another try...
Managed to get the printer working.
The only difference this time was, I didn't tick 'share Printer'.
Re: Unable to print
« Reply #5 on: April 30, 2016, 01:51:45 pm »
Glad you got it sorted pooky2483 .. What I meant by "stock" was "standard/default" ;)
Offline pooky2483
Re: Unable to print
« Reply #6 on: May 06, 2016, 10:21:26 pm »
I had the same problem on the fresh install of Kubuntu 14.04 I did yesterday.
Same problem with HPLIP, so I used CUPS to completely remove all printers and installed them using CUPS and again, unticked 'share printer' and it worked.
No idea what the cause of the problem is/was.
Re: [SOLVED] Unable to print
« Reply #7 on: May 07, 2016, 03:24:47 pm »
Cool, at least you figured a way around it :)
