Author Topic: How to check for existence of a file on Mint?  (Read 3574 times)
Offline ahead
  • Full Member
« on: August 24, 2016, 08:38:06 am »
Hello,
I visit betting sites and have heard that there is a file or cookie called IEsnare which some bookies install on customers' computers to track their betting activity. How do I check and remove the possible existence of this please?  I have Mint 17.
Thank you
Re: How to check for existence of a file on Mint?
« Reply #1 on: August 24, 2016, 07:03:40 pm »
By the looks of this
http://www.thegamblingtimes.com/board/day-day-life/10018-iesnare-make-sure-youre-not-being-snooped.html
just run:
sudo updatedb
then see if you get any returns from
locate iesnare
locate mpsnare
Offline ahead
  • Full Member
« Reply #2 on: August 24, 2016, 07:39:25 pm »
graham@graham-HP-ProBook-455-G2 ~ $ locate mpsnare
Hello Mark, this is what comes up:
/home/graham/.macromedia/Flash_Player/#SharedObjects/FPPRWF76/ci-mpsnare.iovation.com
/home/graham/.macromedia/Flash_Player/#SharedObjects/FPPRWF76/mpsnare.iesnare.com
/home/graham/.macromedia/Flash_Player/#SharedObjects/FPPRWF76/ci-mpsnare.iovation.com/stm.sol
/home/graham/.macromedia/Flash_Player/#SharedObjects/FPPRWF76/mpsnare.iesnare.com/stm.sol
/home/graham/.macromedia/Flash_Player/macromedia.com/support/flashplayer/sys/#ci-mpsnare.iovation.com
/home/graham/.macromedia/Flash_Player/macromedia.com/support/flashplayer/sys/#mpsnare.iesnare.com
/home/graham/.macromedia/Flash_Player/macromedia.com/support/flashplayer/sys/#ci-mpsnare.iovation.com/settings.sol
/home/graham/.macromedia/Flash_Player/macromedia.com/support/flashplayer/sys/#mpsnare.iesnare.com/settings.sol
Regards, Graham
Offline SeZo
« Reply #3 on: August 24, 2016, 08:08:20 pm »
If you are on Firefox then just install BetterPrivacy and set it to remove the Flash-cookies on Firefox exit.
BetterPrivacy is a Firefox add-on that is able to delete a special kind of cookies: Local Shared Objects in short LSO's (usually known as Flash-cookies)
Offline ahead
  • Full Member
« Reply #4 on: August 25, 2016, 08:58:15 am »
Thanks SeZo, I have installed that it seems to be doing the trick.
