Author Topic: File sharing mint 18 mate (resolved)  (Read 6711 times)
Offline Tramlink
  • Is the mist clearing
« on: August 30, 2016, 11:53:41 am »
Dear All,
I am trying out a clean install of mint 18 mate version and want to share files over the LAN.
Installed SAMBA and switched on shared folders.
However, I can not list the folers and when right clicking a folder the share option is not shown.
Any help apreceated.
« Last Edit: September 01, 2016, 03:11:40 pm by Tramlink »
Re: File sharing mint 18 mate
« Reply #1 on: August 30, 2016, 04:59:44 pm »
Try:
sudo apt-get install caja-share
now see if right-clicking a folder gives you a "Share" option
Offline SneakyTommy
« Reply #2 on: August 31, 2016, 10:57:58 am »
double check that you have smbmount package installed.
Offline Tramlink
« Reply #3 on: September 01, 2016, 03:11:16 pm »
Thanks chaps, have decided to revert to mint 17.3 mint 18 is unstable on this 5 year old laptop.  Freezes and restarts on its own and very slow to boot.. I really wish that they included LAN set-up as standard.
Thanks again.
