Author Topic: cannot connect inter net  (Read 4856 times)
Offline pat
« on: October 04, 2016, 03:51:03 pm »
I am a newbi. having probs connecting internet via wifi. Have sky hub, have no probs with windows, have install linumint18(mate)
can any one help please
thanks
Re: cannot connect inter net
« Reply #1 on: October 05, 2016, 05:06:27 pm »
Can you open a terminal and post the output from
sudo lshw -C network
iwconfig
iwlist scan
rfkill list
Offline pat
« Reply #2 on: October 07, 2016, 07:15:45 pm »
sorry about taking so long to get back to you mark.   how can I cut and paste the replies to to your code questions from a usb stick
« Last Edit: October 07, 2016, 07:19:17 pm by pat »
« Reply #3 on: October 07, 2016, 09:24:58 pm »
Connect to your router with an ethernet cable
Or copy the output to a text file then copy it to another PC
Offline davidmichaels
« Reply #4 on: November 07, 2018, 09:45:53 am »
Have you tried switching your firewall off? Because sometime firewall causes some issues while connecting to the internet.
