Author Topic: [SOLVED] After 'fixing' a previous problem, I now have another problem.  (Read 12129 times)
Offline pooky2483
The problem I previously had is HERE
I believe the new problem is related as I now no longer have VLC installed and when I tried to install it through Muon Package Manager, I get this;
The "vlc" package could not be marked for installation or upgrade:
Depends: vlc ,but is not installable
Recommends: vlc ,but is not installable
Yes, the warnings appear twice for some reason.
« Last Edit: April 02, 2017, 10:40:54 pm by pooky2483 »
Re: After 'fixing' a previous problem, I now have another problem.
« Reply #1 on: January 13, 2017, 12:29:45 pm »
Run:
sudo apt-get clean
now what's the output from:
sudo apt-get install vlc
Offline pooky2483
« Reply #2 on: January 23, 2017, 09:10:40 pm »
Hi Mark, sorry for not getting back to you sooner, me & Mrs pooky have had the flu since Christmas,we've almost got over it and now she's ill in hospital.
I'll get back to you as soon as I can.
« Reply #3 on: January 23, 2017, 09:58:23 pm »
No worries .. wish the missus all the best and a speedy recovery from me.
Offline jackbackband
« Reply #4 on: January 28, 2017, 02:38:24 am »
Throw all the insults you like at me but I call it the chemtrail flu. My immediate family for three months now have had bronchitis like chest infections with my heavily pregnant daughter now in intensive care. I've never seen anything like this and the doctors at the surgery and those at the hospital haven't either and it's right acros
s the U.K.
Offline pooky2483
« Reply #5 on: February 04, 2017, 01:52:55 am »
I tried the suggestion above and was given this;
 vlc : Depends: vlc-nox (= 2.1.6-0ubuntu14.04.2) but it is not going to be installed
       Depends: libvlccore7 (>= 2.1.0) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 2.1.6-0ubuntu14.04.2) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 2.1.6-0ubuntu14.04.2) but it is not going to be installed
Offline zebedeeboss
  • Stercus accidit
« Reply #6 on: February 04, 2017, 02:49:19 am »
Hi pooky2483,
Try
sudo apt-get -f install
that should fix any broken packages messages you are getting
Regards Zeb...
Be Kind Whenever Possible...   It is Always Possible - Dalai Lama
Linux User #565092
x64 Desktop - Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz - 32Gb RAM - NVIDIA GTX 960 4Gb - 34"  WQHD 3440x1440
x64 Laptop - Intel(R) Dual Core i5-4200U - 8Gb RAM - Intel Integrated Graphics - 15.6"  HD 1920x1080
Offline pooky2483
« Reply #7 on: February 04, 2017, 10:06:56 pm »
Nope... I still get the error I posted above!
« Reply #8 on: February 04, 2017, 10:12:57 pm »
What happens if you run:
sudo apt-get install --reinstall vlc-nox libvlccore7 vlc-plugin-notify vlc-plugin-pulse vlc
Offline pooky2483
« Reply #9 on: February 06, 2017, 07:42:17 pm »
I entered
And got;
Reading package lists... Done
Building dependency tree
 libvlccore7 : Depends: vlc-data (= 2.1.6-0ubuntu14.04.2) but 2.2.4-3ubuntu2~ubuntu14.04.1york1 is to be installed
« Reply #10 on: February 07, 2017, 12:34:45 am »
I have the feeling this is going to be PPA related again .. try:
sudo apt-get install --reinstall vlc-nox libvlccore7 vlc-plugin-notify vlc-plugin-pulse vlc vlc-data
Offline pooky2483
« Reply #11 on: April 02, 2017, 10:40:35 pm »
I finally got round to looking at VLC on my desktop again and looked for anything installed which was VLC related and found libvlccore8 so I decided to go for it and purge it.
I then selected to install VLC from Muon Update Manager and IT WORKED!
I now have VLC installed.
« Last Edit: April 02, 2017, 10:58:12 pm by pooky2483 »
