Author Topic: Legacy printers listed in a fresh Ubuntu install on Windows machine. [RESOLVED]  (Read 2250 times)
This Topic is a renamed one because, as usual, we drifted off-topic.
The original Topic was about discovering the location of archive files, and the first couple of posts dealt with this satisfactorily - they are shown immediately below.  Read on for the main discussion....
Where is the Archive in Ubuntu?
I downloaded the Ubuntu 16.04 ISO file for a new desktop that I am preparing for a friend.  The download was fine except that it did not go to Downloads as expected (that's where Firefox is set send downloaded files)  but to an Archive.  I know this because hovering the mouse over its entry in Places tell me the path-name.  But I can't find an archive directory anywhere.
I want to use Unetbootin to create a live USB but can't do so without specifying the path.
Your assistance would be appreciated.
« Last Edit: February 06, 2017, 05:06:45 pm by Keith »
Re: Where is the Archive in Ubuntu?
« Reply #1 on: February 03, 2017, 04:48:27 pm »
Run:
sudo updatedb
locate -i *.iso
that should list all files on the system (and their locations) with ".iso" as their extention.
« Last Edit: February 03, 2017, 04:51:20 pm by Mark Greaves (PCNetSpec) »
« Reply #2 on: February 03, 2017, 05:08:55 pm »
That worked perfectly - and a useful command for later, too.  Thank you Mark.
I discovered also that I ought to have ticked the "Save" button when downloading, as doing so would have sent it to the Downloads folder.  So, sorry to have troubled you - although I have learnt something very useful.
The next, related problem is:
I now need to re-install Ubuntu to remove all non-functioning references to old printers, but I know from experience that the clever installer will keep everything except anything new.  How can I delete the whole disc before installing anew, to prevent this happening?  Or is there a magic command to use during installation?
Alternatively:  is there a way of removing these obstinate printers from the printers list, thus obviating the need for a full re-install?  I can't delete them using CUPS, either.
[Edit]  tried sudo usermod -aG lpadmin <username> to no avail.
[Edit]  tried lpadmin -x KODAK-5300-AiO
« Last Edit: February 03, 2017, 06:41:57 pm by Keith »
« Reply #3 on: February 03, 2017, 08:04:28 pm »
The installer SHOULD offer you "erase Ubuntu and use entire disk" .. but if you want to be sure, fire up the LiveUSB and use GParted to delete all the partitions first.
But YES, printers can be removed .. in a web browser, go to:
http://localhost:631
and then go to
Administration > Manage Printers
If at any time you're prompted for a username an password .. enter your Ubuntu ones.
Now click the blue writing for your printer, and on the next screen click
Administration > Delete Printer
If that still doesn't get rid of em, post the output from:
sudo lpstat -s
sudo cat /etc/cups/printers.conf
« Last Edit: February 03, 2017, 08:20:12 pm by Mark Greaves (PCNetSpec) »
« Reply #4 on: February 03, 2017, 08:27:36 pm »
Sorry, I didn't scroll down to the rest of your reply:    I did indeed click on the blue printer entries in CUPS but it responded: "Address wasn't understood".  Same for all the other printers.  The reason being that the address contains the name of my own laptop on which I installed Ubuntu from the original live USB.  For example:
lorene@ox12:~$ lpstat -s
system default destination: KODAK-5300-AiO-2
device for Epson-Stylus-Photo-PX720WD: ipps://T500.local:631/printers/Epson-Stylus-Photo-PX720WD
device for HP7610: ipps://T500.local:631/printers/HP7610
device for KODAK-5300-AiO: ipps://T500.local:631/printers/KODAK-5300-AiO
device for KODAK-5300-AiO-2: usb://Eastman%20Kodak%20Company/KODAK%205300%20AiO?serial=B7BU0132&interface=1
where T500 is the name of my laptop but  ox12 is the name of the desktop I am struggling with.
« Reply #5 on: February 03, 2017, 08:31:18 pm »
Just tried to boot from the USB but it asks for username and password in a terminal, and of course the desktop values won't work.
Can I delete the partitions while actually running the desktop ?  I know that sounds silly, but clutching at straws.
« Reply #6 on: February 03, 2017, 08:36:28 pm »
Whilst booted to Ubuntu (not the liveusb) try running:
sudo lpadmin -x KODAK-5300-AiO
sudo lpadmin -x Epson-Stylus-Photo-PX720WD
sudo lpadmin -x HP7610
sudo lpadmin -x KODAK-5300-AiO-2
then post the output from
sudo lpstat -s
again.
and the output from:
sudo ls /etc/cups/ppd
Otherwise, the Ubuntu live username and password should be
username = ubuntu
password = <leave blank>
« Last Edit: February 03, 2017, 08:46:37 pm by Mark Greaves (PCNetSpec) »
« Reply #7 on: February 03, 2017, 08:45:08 pm »
I have already tried the sudo lpadmin -x KODAK-5300-AiO but it had no effect earlier.  I have just now repeated all your commands but the output from the last two commands is:
lorene@ox12:~$ sudo stat -s
stat: invalid option -- 's'
Try 'stat --help' for more information.
lorene@ox12:~$ ls /etc/cups/ppd
lorene@ox12:~$
I shall use your live USB password method and report back.
« Reply #8 on: February 03, 2017, 08:47:38 pm »
you missed out "lp" in "lpstat".
(always best to copy/paste commands)
Also post the other output I asked for.
I mean you can reinstall if you want, but that's a bit drastic.
« Last Edit: February 03, 2017, 08:49:16 pm by Mark Greaves (PCNetSpec) »
« Reply #9 on: February 03, 2017, 09:01:48 pm »
Sorry; not doing so well tonight!
lorene@ox12:~$ sudo lpstat -s
[sudo] password for lorene:
no system default destination
device for epson-stylus-photo-px720wd: ipps://T500.local:631/printers/Epson-Stylus-Photo-PX720WD
device for hp7610: ipps://T500.local:631/printers/HP7610
device for kodak-5300-aio: ipps://T500.local:631/printers/KODAK-5300-AiO
lorene@ox12:~$ sudo ls /etc/cups/ppd
lorene@ox12:~$ sudo cat /etc/cups/printers.conf
# Printer configuration file for CUPS v2.1.3
# Written by cupsd
# DO NOT EDIT THIS FILE WHEN CUPSD IS RUNNING
<Printer epson-stylus-photo-px720wd>
UUID urn:uuid:6e86a212-7594-35c6-5a08-442335d6f772
Info Epson Stylus Photo PX720WD @ T500
Location T500.local
DeviceURI ipps://T500local:631/printers/Epson-Stylus-Photo-PX720WD
State Idle
StateTime 1486154343
ConfigTime 1486154343
Type 6
Accepting Yes
Shared No
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
ErrorPolicy retry-job
Option cups-browsed true
</Printer>
<Printer hp7610>
UUID urn:uuid:8c9111a6-3eb0-30d1-7baf-d25447e134d7
Info HP Officejet 7610 series @ T500
Location T500.local
DeviceURI ipps://T500.local:631/printers/HP7610
State Idle
StateTime 1486154360
ConfigTime 1486154360
Type 6
Accepting Yes
Shared No
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
</Printer>
<Printer kodak-5300-aio>
UUID urn:uuid:f5ee2c3f-c0f6-36b1-5eed-1f4cd1269173
Info Eastman Kodak Company KODAK 5300 AiO @ T500
Location T500.local
DeviceURI ipps://T500.local:631/printers/KODAK-5300-AiO
State Idle
StateTime 1486154319
ConfigTime 1486154319
Type 6
Accepting Yes
Shared No
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
</Printer>
lorene@ox12:~$
I have highlighted the references to a completely different computer (my laptop).
« Reply #10 on: February 03, 2017, 09:11:33 pm »
Could I simply delete the list of printers from the conf file?
Answer:  Nope.  The printers still appear in the printer system settings list.
« Last Edit: February 03, 2017, 09:48:39 pm by Keith »
« Reply #11 on: February 03, 2017, 09:51:27 pm »
Okay, try this:
sudo systemctl stop cups.service
sudo cp -v /etc/cups/printers.conf /etc/cups/printers.conf.broken
then open printers.conf for editing
sudo gedit /etc/cups/printers.conf
and make it read just:-
# Written by cupsd
SAVE the file and exit gedit
now restart the cupsd daemon
sudo systemctl start cups.service
Have the printers gone ?
« Reply #12 on: February 03, 2017, 10:00:56 pm »
Perfect!!
I had tried deleting the list myself, without success.  The key was stopping CUP.
You have saved the day once more, Mark!
It looks like when updating Ubuntu to a new version by using a Live USB, the process copies lots of info from the existing system to the USB files for inclusion in the upgraded system - and that the copied info remains on the USB device.  So when I used it for a fresh install on a new system, my printers were "installed" on the new computer but with the wrong computer name.
I was just about to try changing the computer name in the conf file when your post appeared.
My sincere thanks, as usual, Mark.
« Reply #13 on: February 03, 2017, 10:15:23 pm »
Not sure your hypothesis is correct, but who cares what happened if it's fixed now eh ;)
« Reply #14 on: February 03, 2017, 10:52:25 pm »
Well,....sort of.  I install a Kodak printer via a USB connection (and its conf file is correct) but when I try to print or clean the heads via the Printers dialogue, it begins then I receive a message "Processing - Unplugged or turned off", although it works on other PCs - I shall try installing a network printer tomorrow.
