Author Topic: [SOLVED] Unable to mount partition at boot  (Read 8182 times)
Offline pooky2483
« on: May 02, 2017, 12:22:04 am »
I'm tryint to mount the partition I've named 'HOME' but I'm having problems.
sudo blkid
/dev/sda1: UUID="646f747b-e9d0-4016-be6f-bc81e3ccf046" TYPE="swap" PARTUUID="a06af458-ae19-44be-8742-3c13ad1195c3"
/dev/sda2: UUID="095ba79a-1767-49a2-ae8f-976272ca9766" TYPE="ext4" PARTUUID="1786eb4a-689f-4159-ae64-9c1033124212"
/dev/sda3: UUID="a1d15776-2c0d-4982-8fc9-3c5683c819d8" TYPE="ext4" PARTUUID="e852b203-fd36-4d00-88e8-e157ac6f649a"
/dev/sda4: UUID="62EA-E0B8" TYPE="vfat" PARTUUID="7a7d9fb0-9af0-4603-832e-b5e723fefc80"
/dev/sda5: UUID="028d16f2-a397-4ec0-be8c-9c02f78c9ca0" TYPE="ext4" PARTLABEL="HOME" PARTUUID="ee7d7dde-540b-429a-b44d-9a50d8ea3b69"
sudo kate /etc/fstab
# / was on /dev/sda3 during installation
UUID=a1d15776-2c0d-4982-8fc9-3c5683c819d8 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sda4 during installation
UUID=62EA-E0B8  /boot/efi       vfat    umask=0077      0       1
# swap was on /dev/sda1 during installation
UUID=646f747b-e9d0-4016-be6f-bc81e3ccf046 none            swap    sw              0       0
/dev/sda5: PARTLABEL="HOME" PARTUUID="ee7d7dde-540b-429a-b44d-9a50d8eaa3b69" TYPE="ext4"
I've also tried 028d16f2-a397-4ec0-be8c-9c02f78c9ca0 with just LABEL & UUID
« Last Edit: May 07, 2017, 09:24:13 pm by pooky2483 »
Re: Unable to mount partition at boot
« Reply #1 on: May 06, 2017, 12:34:50 pm »
Where do you want it mounted ?
Offline pooky2483
« Reply #2 on: May 06, 2017, 04:05:47 pm »
I don't quite get your question, 'Where do I want it mounted', I didn't know I had a choice of where it could be mounted!
These are the drives/partitions;
The one in RED is the one I want to auto-mount.
Offline SeZo
« Reply #3 on: May 06, 2017, 07:20:32 pm »
Are you trying to mount that partition as /home ?
If so then add to /etc/fstab:
UUID=028d16f2-a397-4ec0-be8c-9c02f78c9ca0 /home           ext4    defaults        0       2
That will mount that parition as /home on next boot
Note, both UUID and PARTUUID points to the same partition
Offline pooky2483
« Reply #4 on: May 07, 2017, 01:55:48 am »
Thanks SeZo, I've just updated fstab and will know the result next time I reboot.
Offline pooky2483
Re: [SOLVED] Unable to mount partition at boot
« Reply #5 on: May 07, 2017, 09:24:45 pm »
Cheers SeZo, it worked :-)
