Author Topic: Advice before starting - please  (Read 9054 times)
Offline Mark
« on: July 08, 2017, 10:17:59 am »
Hello, I must start by saying I am totally new to Linux...
My question is.
I have some cron jobs which automate 2 different commands at 2 different times that run fine at the moment.
When the command I am issuing has completed in the script there is a return value, which I would like to extract and apply math to use in the rest of my script, maybe issue another command based on the logic.
Would I be right in using Expect ?
after the command the reply would be "some text : value"      the value will be numbers.
the reason I am asking is I don't want to install expect and it not be the right application for it and possibly mess up my small Linux install that's working.
Many thanks
